Old 11-09-2012, 03:09 PM   #1
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
TSB / Recall
ichitaka05 have taking over this thread.
If you need me to add new TSB or Recall, please mention me or PM me. When you do, please format it this way:
Which Brand: Scion/Subaru/Toyota
TBS #:
Error Code:
Attachment: Prefer PDF, but jpeg or any other format that easier for member to see.
Here's an example:
Subaru
TSB # 11-184-18
Error Code P119F and P219A
https://www.ft86club.com/forums/atta...8&d=1550507327
FR-S TSB
S-SB-0009-12 : DRL Customization
S-SB-0019-12 : Dash Mounted Speaker Grille Appearance
S-SB-0023-12 : Chirping Noise from High Pressure Fuel Pump (Original)
S-SB-0023-12-Rev2 : Chirping Noise from High Pressure Fuel Pump (Revised)
S-SB-0007-16 : Chirping Noise from High Pressure Fuel Pump (NEW)
S-SB-0002-13 : Condensation in Rear Combination Lamp
S-SB-0014-13 : Rattle Noise From MT Shift Lever
S-SB-0033-13 : Hard Start, Rough Idle, Camshaft Sensor or Misfire DTCs
S-SB-0040-13 : Intermittent RPM Drop
S-SB-0041-13 : Taillight Lens Cracking
S-SB-0001-14 : Window Freezing, Losing Initialization
S-SB-0009-14 : Outside Door Weatherstrip
S-SB-0021-15 : Idle Fluctuation in Park or Neutral
S-SB-0012-17 : Abnormal Noise When Clutch Pedal is Depressed
S-TT-0043-12 (Not a TSB): Body panels that aren’t flush. LINK to DIY.
86 TSB
T-SB-0154-18 : MIL ON DTC P219A and P119F
BRZ TSB
15-158-12 : Navigation/GPS Antenna Changes
12-131-12 : Condensation in Rear Combination Lamp
09-54-12 : Chirping Noise from High Pressure Fuel Pump
09-54-12R : Chirping Noise from High Pressure Fuel Pump (Revised on 5/9/2013)
09-54-12R2 : Chirping Noise from High Pressure Fuel Pump (Revised on 10/28/2013)
02-132-12 : DTCs Relating to the AVCS (Active Valve Control System)
12-140-12 : Popping Sound from Trunk / Rear Shelf Area
11-130-13R : Difficulty Starting, Rough Idle, Cam Position, Misfire
11-136-14 : Idle Stability
07-79-13R : Frozen Power Windows
02-136-12R : Oil Seepage Diagnosis and Repair Procedures
16-96-15 : Idle Fluctuation in Park or Neutral
03-77-17 : "Rotational" Sounds from Clutch Release Bearing
15-167-13R : Auto-Dimming Compass Mirror and HomeLink
12-168-14 : Appearance Imperfection Of Inside Rear View Mirror
SB17-067 : Leakage countermeasure for VALVE ASSY OIL CTRL
11-184-18 : DIG P119F and P219A ECM Reprogramming
05-61-16 : Front Suspension Mounts
FR-S Recall
Recall_G0E : Ignition Key Interlock System
Incorrect Load Carrying Capacity Label/FMVSS 110 : SOUTHEAST ONLY. The Load Carrying Capacity Modification Label may not reflect the correct added weight of the installed accessories.
BRZ Recall
11-184-18 : ECM Reprogramming for Coolant Thermostat
RCRIT-18V935-9940 : Harman Kardon Head Unit FMVSS 111 Noncompliance Recall
Other Information
01-168-09R : Replacement Key and Immobilizer Information
07-68-12 : Alternate Procedure for Removal of Front Side Marker Lamp
Passenger window auto up/down switch
P0351-P0354_ Ignition Coil _A_ Primary _ Secondary Circuit
NHTSA Campaign Number: 18V772000: Engine Valve Spring Failure may cause Engine Stall
File Type: pdf 01-168-09R_Replacement_Key_and_Immobilizer_Info.pdf (968.4 KB, 8521 views)
File Type: pdf 07-68-12_Removal_of_Front_Side_Marker_Lamp.pdf (717.5 KB, 7624 views)
File Type: pdf S-SB-0002-13_Tail_Light_Condensation.pdf (2.60 MB, 11431 views)
File Type: pdf S-SB-0014-13_Rattle_Noise_From_MT_Shift_Lever.pdf (155.0 KB, 13040 views)
File Type: pdf 11-130-13R_DifficultyStarting_RoughIdle_CamPosition_Misfire.pdf (2.56 MB, 16615 views)
File Type: pdf S-SB-0033-13_DifficultyStarting_RoughIdle_CamPosition_Misfire.pdf (2.45 MB, 15246 views)
File Type: pdf S-SB-0001-14-Window Freezing Losing Initialization.pdf (1.72 MB, 10605 views)
File Type: pdf S-SB-0009-14_Outside_Door_Weatherstrip.pdf (221.8 KB, 11422 views)
File Type: pdf P0351-P0354_ Ignition Coil _A_ Primary _ Secondary Circuit.pdf (177.0 KB, 4957 views)
File Type: pdf S-SB-0021-15-Idle Fluctuation in park or neutral.pdf (303.7 KB, 8748 views)
File Type: pdf Recall_G0E-Ignition_Key_Interlock_System.pdf (969.4 KB, 3236 views)
File Type: pdf S-SB-0007-16-Chirp or Squeak Noise From HPFP.pdf (380.7 KB, 3948 views)
File Type: pdf S-SB-0041-13-Taillight Lens Cracking.pdf (1.35 MB, 2493 views)
File Type: pdf SB17-067_Leakage countermeasure for VALVE ASSY OIL CTRL.pdf (400.0 KB, 2275 views)
File Type: pdf Subaru TSB 05-61-16 Suspension mounts.pdf (310.8 KB, 1238 views)
Sigh-on-Rice is offline   Reply With Quote
The Following 174 Users Say Thank You to Sigh-on-Rice For This Useful Post:
2much (05-26-2013), 350zgoingFRS_lol (05-06-2014), 73TORANA! (07-08-2014), Adam_L (03-29-2018), alexand3r (01-18-2015), amram (03-31-2014), Anthonytpt (02-24-2013), ap5512 (11-13-2012), ATL BRZ (11-18-2012), atomicalex (01-11-2019), azian_advanced (07-31-2013), B L U E S L A T E (01-04-2013), BaeK (03-21-2014), BBDGriptonia (12-23-2015), bedabi (08-28-2015), Ben_G (11-09-2012), bhmax (07-11-2017), Blue14inTracy (03-27-2014), Bonburner (11-14-2012), Borrowed Time (08-14-2016), Bristecom (11-14-2012), burningjello (05-02-2017), Calidrifter (03-26-2016), Calum (06-15-2014), CamryDS (04-12-2016), carma143 (05-20-2015), Chewie4299 (06-30-2013), Chimera (06-30-2016), Choco (01-21-2015), civicdrivr (03-11-2013), Clutch (02-19-2019), Dadhawk (12-21-2012), DandoX (04-27-2018), Deepseadiver (11-12-2012), dennis.s.s (06-16-2013), dexter_5000 (09-17-2017), DoomsdayJesus (09-24-2013), Drift&Drag (02-27-2014), EndlessAzure (10-29-2017), ericmpena (12-02-2013), Eurasianman (06-05-2014), eurominican (05-07-2015), FastOnFastOff (11-19-2013), fatherfork (01-08-2014), fduboss302 (04-11-2014), Fenix (02-15-2016), finch1750 (12-06-2012), flippy (09-23-2015), FRSBRZGT86FAN (09-30-2015), frslee (04-05-2013), FRSupra (06-06-2013), ft86Fan (05-01-2013), ftc~brz (04-24-2014), fx35s (11-18-2013), GMT (12-19-2012), GOT FR-S (07-05-2013), grst1 (12-05-2012), Guff (11-22-2012), hakkoo (03-17-2014), HotLeopardMama (02-04-2016), HunterGreene (11-19-2012), iBRZ (12-01-2012), ICEBONEZ (01-28-2014), irax (03-25-2015), iRep8OH8 (03-09-2014), jakev9041 (07-02-2013), Jayde (11-14-2012), JazzleSAURUS (07-27-2017), jcw99 (07-11-2014), JD001 (08-05-2017), JDMenrique (01-01-2013), JEFFSTYLE (07-02-2021), jmelgar23 (08-26-2014), johnb831 (12-03-2012), jonbonazza (12-03-2013), JSUB (04-14-2014), kakacarrotcake (01-25-2017), kash (04-01-2013), kgc (12-27-2017), Kimsey47 (06-07-2013), Kiske (04-09-2014), Krispeee (01-29-2014), kwood9000 (11-14-2012), lazyluka (03-04-2014), LeeMaster (12-28-2012), Lonewolf (01-21-2013), Lorico (02-07-2016), LXXXV1 (04-01-2014), Mango22 (01-28-2013), MannyO (11-25-2012), MaXimus (02-16-2014), melon (06-16-2014), mezdup (11-20-2012), MooseWRX (03-10-2014), Mr. (01-02-2014), mweidner311 (05-22-2014), mx5 2nr (05-30-2014), nalc (07-17-2013), neurokinetik (07-05-2014), NickFRS (12-21-2012), notout86 (02-28-2014), OAKOS Automotive (05-09-2014), ohnoimcaught (07-25-2013), OnkelC (11-15-2014), Open Loop (03-19-2019), Ornelas66 (08-11-2017), P86RAVES (07-17-2014), Packofcrows (07-01-2015), Peaty (07-19-2016), PerCompLLC (05-21-2019), PLZdontscream (05-25-2014), PureShield (02-09-2016), PWBRZ (05-27-2014), Ramster (03-10-2014), rapidcars (05-29-2014), raptor87 (12-07-2013), raul (03-29-2013), RaveSaint5 (10-15-2014), raz0rbladez909 (11-19-2014), rice_classic (11-22-2012), Ricky Racer (01-14-2013), robwbright (04-20-2014), roflcopter (12-05-2012), russv (11-14-2012), rxpx2012 (01-13-2014), sato (04-30-2016), Scik (03-16-2013), scionfrs2014 (01-14-2014), Scooby South (03-07-2013), Shaun. (06-26-2013), shaunsweeney (01-13-2014), shiro (10-17-2013), ShoShin (12-14-2012), Sileighty_guru (11-21-2012), Simpleviet (03-18-2015), SirBrass (12-10-2013), slim blanco (06-08-2016), slizoth (11-09-2012), Snoopy_TXR (05-25-2015), so26 (11-18-2012), solidONE (04-08-2013), sparks (11-14-2012), Splat (06-18-2013), Sportsguy83 (11-18-2012), srizzors25 (01-08-2015), Sugi (03-06-2015), SuperDave (07-30-2015), Surok (06-01-2013), swfrs (01-17-2019), t.chk (11-26-2013), taosracer (04-17-2016), tbrocato (02-12-2014), TemeCal (01-23-2014), Texaz Boy (01-30-2014), TM (06-07-2013), torqdork (05-31-2013), totally (03-28-2014), ToxicSneakers (01-27-2013), Trap63 (06-07-2018), trigger happy (11-28-2013), tripjammer (03-05-2013), Tugboat (12-03-2012), Votlon (05-03-2016), whataboutbob (09-28-2015), whtchocla7e (11-22-2012), WillRacer1jz (10-17-2014), WilOTheWisp (01-03-2015), Wo6M (06-17-2013), Wolfking (01-21-2013), wu_dot_com (12-14-2012), xXDeathMaliCeXx (06-18-2014), Yuck (01-18-2013), Z3D (02-05-2013), zoomzoomers (03-06-2013)
Old 11-09-2012, 03:29 PM   #2
NetMagi
NetMagi's Avatar
Drives: 13 Firestorm FR-S
somebody please sticky this. .
we need 'one' post to keep updated for the TSB's.
-Rich H.
Current: 16 Porsche Cayman, 09 Tacoma 4WD, 13 Highlander 4WD, 12 Yamaha WR250R
Past: 13 10-Series FR-S, 13 FR-S, 11 S4, 07 Corolla, 98 Tacoma 4WD, 03 Corolla, 89 Camry, 90 Celica GT-S, 87 Celica GT-S
NetMagi is offline   Reply With Quote
Old 11-13-2012, 12:31 PM   #3
Sigh-on-Rice
Added rear deck popping TSB under Subaru. Thanks to this thread.
Old 11-14-2012, 05:48 AM   #4
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Good to know you can turn the DRL on or off.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 11-22-2012, 09:40 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@Dave-ROR @Guff, please make this thread a sticky.
Thanks!
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Helix (06-15-2014), Sigh-on-Rice (11-22-2012)
Old 11-22-2012, 02:28 PM   #6
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Fantastic. I had no idea the body panels not sitting flush was a TSB! I just noticed this on my car the right front quarter panel doesn't sit flush with the passenger door line.
The Following User Says Thank You to rice_classic For This Useful Post:
polarstorm (06-06-2013)
Old 11-22-2012, 02:59 PM   #7
jesperswe
Drives: GT86
Great!
jesperswe is offline   Reply With Quote
Old 11-28-2012, 01:17 PM   #8
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
great, thank you. just scheduled my appointment for 5000mi first service, rear taillight condensation, chirping and switching off DRLs.
mezdup is offline   Reply With Quote
Old 12-05-2012, 09:18 AM   #9
stopdrop
Nice to know my VIN # came about 1000 #'s "after" all the "countermeasures in production" for the above BRZs were put into place..
stopdrop is offline   Reply With Quote
Old 12-05-2012, 01:23 PM   #10
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
After they turned my DRLs off, the brights now light up only as bright as the DRLs used to be. The techs and myself cannot figure that out
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 12-05-2012, 01:40 PM   #11
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
ECU must be replaced for the DRL change. Sounds like they didn't replace it and just performed the rest of the TSB.
kwood9000 is offline   Reply With Quote
The Following User Says Thank You to kwood9000 For This Useful Post:
Batman (12-05-2012)
Old 12-05-2012, 01:57 PM   #12
Batman
Easy, Tiger.
Batman's Avatar
Got it, thanks! I'll start yelling lol
Old 12-13-2012, 05:09 PM   #13
Sportsguy83
Drives: Limited BRZ
I'd be interested in a copy of this two:
07-68-12 Alternate Procedure for Removal of Front Side Marker Lamp
01-168-09R Replacement Key and Immobilizer Information for Authorized Subaru Dealers
@Sigh-on-Rice
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Sigh-on-Rice (12-14-2012)
Old 12-14-2012, 01:12 PM   #14
Sigh-on-Rice
@Sigh-on-Rice
Thank you for the information. I added them to the first post.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Sportsguy83 (12-14-2012)
chirping, high pressure fuel pump
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 10:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 12:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) -- General Topics 1 06-07-2012 07:00 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) -- General Topics 8 06-05-2012 10:09 PM
Did anyone get a call from toyota about a recall yet? AustinTCLN Scion FR-S / Toyota 86 GT86 General Forum 2 06-04-2012 11:45 PM
