Forced Induction Turbo, Supercharger, Methanol, Nitrous |
12-01-2012, 02:04 AM | #1 |
Seriously...what's the first thing to break???
I'm asking mostly because my turbo kit is soon to be here, and I am wondering what, if anything has broken due to the strain of 400+ HP and 300+ ftlbs of torque. It's been tough to follow every turbo build thread and I had followed AP's thread up until they broke a shift fork or something in the transmission from accidentally jumping the car. I don't consider the clutch as a component to worry about because I already have a Clutchmasters FX400 6 puck clutch ready to install once my turbo kit arrives. My question is based more around the driveline/gears/and crank bearing surfaces.
My first concern is for the final drive gears. Has anyone who has been running these power figures monitored rear diff condition and wear on the gears? Does the transmission show signs of wear or stiff shifting? How about the bearings in the rear axle carriers? I know some of this may have been answered, but the search function is pretty much showing me nothing of note. Or is this car really built for this kind of punishment? |
12-01-2012, 02:25 AM | #2 |
KCCO From Canada
Drives: Asphalt FRS
so far i don't think anything has broken. i would say that most likely the first thing to break will be axleshafts on a bad launch, but they haven't gone yet. so far all the big power guys are only changing clutches
12-01-2012, 02:44 AM | #3 |
Slight thread jack, how about on a AT? From what I've read, the AT can handle a bit more upgraded power than MT due to the torque converter vs clutch.
12-01-2012, 02:58 AM | #4 |
Drives: Whiteout FR-S
Heat is the enemy with an Auto, if an external oil cooler is possible i would recommend it. Engine oil cooler wouldn't hurt either for auto or manual. I don't think anybody really knows what's going to go first but rear end would be possible if you do a lot of launching. Best advice i have is to use quality fluids, change them regularly, and don't beat on the car all the time.
The Following User Says Thank You to JoeBoxer For This Useful Post: | BRZranger (12-01-2012) |
12-01-2012, 07:09 AM | #5 |
Damn...I still need an oil cooler...wonder what P&L is cooking up, last time I talked to them they said they had a prototype...
12-01-2012, 08:44 AM | #6 |
Drives: DGM BRZ Limited
With the sounds from all the fast cars, looks like the stock diff mounts and motor mounts will need an upgrade right after the clutch. And don't bang up the gearbox, because it isn't designed for constant beating on high hp.
12-01-2012, 09:56 AM | #7 |
987 Motorsports
Drives: '13 WO FR-S
i think the head gaskets will eventually go from all the boost or the piston rings won't be able to handle the boost after some time. the two normal items to go on a boxer motor. in due time though. you can put plenty of miles on before these will show signs of wear.
12-01-2012, 05:21 PM | #8 |
"That 100 shot of NOS blew the welds on the intake"
12-02-2012, 10:31 PM | #9 | |
Reverse Burnouts
Drives: 2013 Argento FRS
yeah the auto i think has seen 400whp without an issue, but it was ONE pull, i would like to see the amount of heat generated from that pull in the transmission vs stock
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
12-02-2012, 10:49 PM | #10 |
Boosted
Drives: Sideways
I just bought forged pistons and gaskets to go along with it. I think I'll be safe for a while. As soon as I get a clutch in there, I'll jump from 325whp to 400 and I'll call it a day power wise.
Hopefully just oil changes and being smart about everything from here on out. I'll likely upgrade stuff here and there to make sure everything operates smoothly for as long as possible.
12-03-2012, 09:32 PM | #11 |
Drives: 2014 Wrb Brz limited 6m
12-04-2012, 03:38 AM | #12 |
Drives: AVO BRZ
Damn you guys I'm going to watch F&F1 tonight now.
12-04-2012, 04:22 PM | #13 | |
Drives: car
12-04-2012, 04:45 PM | #14 |
Drives: 2013 Raven FRS
Could you tell me right quick what would be a better motor for my Skyline, a Gallo 12 or a Gallo 24?
Similar Threads | ||||
Stupidest thing you have done in your car | nix | Scion FR-S / Toyota 86 GT86 General Forum | 95 | 12-07-2012 08:46 PM |
Such a thing as too much carbon fiber? | xenocharger | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 11-09-2012 11:43 PM |
Hit a deer today. Best thing to do? | mark82890 | BRZ First-Gen (2012+) -- General Topics | 33 | 11-08-2012 09:08 PM |
Last thing you bought for your 86/BRZ? | Surok | AUSTRALIA | 63 | 10-12-2012 04:44 AM |
First thing you are going to do when you get your BRZ? | Norcalmav23 | BRZ First-Gen (2012+) -- General Topics | 74 | 04-02-2012 11:05 PM |
