Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
12-05-2012, 11:11 AM | #1 |
Drives: Whiteout FR-S MT
Durability of cast wheels
I'm interested in a couple of wheels for my daily driven FR-S, but concerned about durability of light weight cast wheels. The top 3 wheels I'm considering are:
17x8 Wedssport TC105n - Flow Form Cast 17x8 OZ Alleggerita HLT - Flow form Cast 17x8 OZ Ultraleggra - Cast Can anyone give some insight on how these wheels fair when used on a daily driver. How do they stand to pot holes and chips on the finish? Thanks in advance. |
12-05-2012, 11:15 AM | #2 |
Drives: 4Runner
All three are a good quality wheel. I wouldn't expect any issues with whatever you choose.
I believe the WedSports are the lightest of the bunch. Running around 15 lbs.
diirk
waiting on a Neptune Premium MT |
12-05-2012, 12:02 PM | #3 |
Kouki-Monster
I've never even wrecked a cheapo cast wheel, much less a quality one. I've had MSR, Tenzo, some weird JDM brands .. never an issue.
Rich Anderson
EMPOWER AUTO |
12-05-2012, 12:29 PM | #4 |
I'm here for the beer
Drives: 2013 Scion FRS, 1971 Datsun 240z
You'll be fine with cast wheels, they aren't super delicate like people make them out to be. The brands you have listed are from well known manufacturers and certainly know a thing or two about producing a good quality wheel.
12-05-2012, 12:39 PM | #5 |
Drives: White Out FR-S
Unless you're going sideways all day long or are burning out your tires all day long, or turbo your car to ridiculous numbers, all three of those cast wheels are perfectly fine. Had a set of superleggeras and i only bent the lip slightly because of a raised manhole cover while they were repaving.
Want a strong set of cast 5x100s from OZ? get Chronos or Gravel. Old school rally wheels in white with red lettering. Made heavy for heavy use. |
12-05-2012, 12:43 PM | #6 |
Drives: 13 FRS
Our 18" Weds are really light for "cast" Def a good wheel
12-05-2012, 01:04 PM | #7 |
Thanks for all the responses!
Now I have one more question. I know the TC105n won't allow you to install a hub centric ring and a center cap together. So, if you have to choose one or the other which would you pick and why? Also, the OZs listed, do they allow you to install both ring and cap? |
12-05-2012, 01:30 PM | #8 | |
Drives: Attitude
One thing to note about durability is that cast wheels tend to bend whereas forged wheels tend to crack. |
12-05-2012, 02:57 PM | #9 |
Praise Helix!
Hmm, that makes me wonder if someone out there with a 3D printer could custom make wheel caps for wheels that aren't fit to run both.
12-05-2012, 03:34 PM | #10 | |
Does anyone have any experience with the TC105n mounted with the center caps? Since they are mounted from the inside of the wheel I wonder if they behave like a hub centric ring. |
12-05-2012, 06:47 PM | #11 | |
Drives: Attitude
The only way the center cap (if mounted from the inside like you say it is) could act as a hubcentric ring would be if the center cap had a machined 56.1mm area to slip over the hub. |
12-05-2012, 06:58 PM | #12 |
I see a lot of bent Ultraleggeras. Seeing as how they're so light and gravity cast, it makes me question how durable they are.
Personally I'd go with one of the flow-form cast wheels. They're light, but should be relatively strong for their weight. |
12-05-2012, 09:32 PM | #13 |
Drives: Asphalt FR-S
I think you got that backwards from my experience.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 |
12-06-2012, 05:10 PM | #14 |
Drives: Subaru Legacy GT
Just remember this
Flow Form > Low-Pressure > Gravity From that list, I'd go with the Weds. Stay away from cheapo reps, most uses gravity cast... |
Similar Threads | ||||
FA20 OEM pistons, are they Forged or Cast ? | adprokid | Engine, Exhaust, Transmission | 54 | 10-11-2014 05:51 PM |
Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 10:08 PM |
FR-S A/T strength/durability? | 07stealth350z | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-18-2012 12:58 PM |
Car Cast W/Adam Corolla review | Gaen | BRZ Photos, Videos, Wallpapers, Gallery Forum | 4 | 06-03-2012 04:02 AM |
Any Disney Cast Members here? | MF_DEUCE | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 11-18-2011 01:48 AM |
