Old 12-11-2012, 04:14 PM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
DIY Cabin Air Filter Inspection/Replacement
While wiring up @post_break's subwoofer in his FR-S, I took the liberty of showing him how to inspect his cabin air filter. What we found was alarming, so I wanted to check mine. Mine was absolutely filthy at 7500 mi. Pictures are below. Update: The OEM filter may be carbon activated. More info below.
Here is a quick and dirty guide on how to inspect your cabin air filter and replace it. Click images for large
Purpose
Inspecting and replacing the cabin air filter is important as the air we breath while motoring passes through this. A clean filter reduces the contaminants we breath and puts less stress on the A/C system
Tools
Pliers
Cabin Air Filter (Toyota Part SU003-02112 or Subaru Part 72880AJ010)
DIY
The air filter is behind the glove box on the passenger side of the car. Make room for yourself by opening the door wide and clearing the footwell.
20121211-CabinAirFilter7500mi-01 by VictorN07, on Flickr
Empty the glove box.
20121211-CabinAirFilter7500mi-02 by VictorN07, on Flickr
There is a single spring/gas hook that gives the glovebox that smooth opening action.
20121211-CabinAirFilter7500mi-03 by VictorN07, on Flickr
Take some pliers and squeeze the pin while pulling the hook off.
20121211-CabinAirFilter7500mi-04 by VictorN07, on Flickr
This is a picture of the stopper that prevents the glovebox from just falling to the floor. Note that I already removed it from the car. There is a stopper on each side of the glovebox. Squeeze the glovebox in and push down to get the glovebox out. You can remove the box or let it hang upside down. I propped mine on my manual books.
20121211-CabinAirFilter7500mi-05 by VictorN07, on Flickr
The white part is where the cabin air filter sits. Remove the cover by releasing the clip on the left and right side of the cover.
20121211-CabinAirFilter7500mi-06 by VictorN07, on Flickr
Another picture of the inside of the cover
20121211-CabinAirFilter7500mi-07 by VictorN07, on Flickr
Here is a picture of the air filter in place. Place your finger in the trapezoidal open space below the center of the filter and pull the filter out.
20121211-CabinAirFilter7500mi-08 by VictorN07, on Flickr
Take the new filter and insert it into the slot. Keep in mind these filters are directional and ensure the up arrow is pointing up. Reassemble everything and you are good to go. Finished!
More Information
The following are pictures of my filter after only 7500 mi. I did not expect it to be this dark already. I believe these should be replaced every 15000 mi. You may find leaves/bugs in yours. Replacing these are important because the air you breath while you drive passes through this!
I didn't have another filter on hand so I just banged this against the fence to shake out the dust. I will just say, dust, dust everywhere!
Update: as @Draco-REX pointed out in a later post, the OEM filter may be carbon activated. It could be gray from the factory. If anyone has purchased a new filter and its gray from the factory then let us know.
20121211-CabinAirFilter7500mi-09 by VictorN07, on Flickr
20121211-CabinAirFilter7500mi-10 by VictorN07, on Flickr
20121211-CabinAirFilter7500mi-11 by VictorN07, on Flickr
20121211-CabinAirFilter7500mi-12 by VictorN07, on Flickr
20121211-CabinAirFilter7500mi-13 by VictorN07, on Flickr
20121211-CabinAirFilter7500mi-14 by VictorN07, on Flickr
20121211-CabinAirFilter7500mi-15 by VictorN07, on Flickr
20121211-CabinAirFilter7500mi-16 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following 36 Users Say Thank You to F1point4 For This Useful Post:
adamg (07-07-2015), Anthonytpt (12-18-2013), BabaYaga (10-11-2014), Black Tire (02-18-2013), Captain Stall (12-17-2013), chanomatik (08-28-2013), ChiefG (06-05-2015), chrisp1992 (11-03-2016), daiheadjai (05-29-2015), Efferalgan (08-10-2014), fuddbutter (12-11-2012), Guff (12-30-2013), hmong337 (07-01-2015), jcw99 (07-09-2014), jwoodland (08-19-2014), kwood9000 (12-12-2012), Laika (12-11-2012), MaximaZero (08-17-2014), Overdrive (09-18-2017), PerCompLLC (09-15-2017), Ramster (10-29-2013), Rayme (02-04-2013), Roadliner (06-30-2013), saj (04-06-2016), Sarlacc (02-19-2013), Sigh-on-Rice (11-20-2016), skye67 (07-20-2014), slim blanco (02-15-2015), so26 (02-04-2013), Subie_Nubie (02-26-2017), tbrocato (03-01-2014), Tristor (05-27-2018), VIPER (04-01-2015), WillRacer1jz (11-02-2015), xn7485 (12-11-2012), yomny (01-28-2015)
Old 12-11-2012, 05:22 PM   #2
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I am not surprised. Houston has been incredibly dusty recently. PITA trying to keep my car clean.
FrX is offline   Reply With Quote
Old 12-11-2012, 06:25 PM   #3
xn7485
Drives: 1995 Acura Integra GS-R
I like all your DIY's, keep them up!
xn7485 is offline   Reply With Quote
The Following 2 Users Say Thank You to xn7485 For This Useful Post:
F1point4 (12-12-2012), FRSapex (06-08-2014)
Old 12-11-2012, 08:58 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Looks like a carbon activated filter. The one in my BRZ isn't, but that doesn't mean yours isn't. More and more cabin filters are coming with charcoal embedded in them for better filtration. Since yours isnt full of twigs and sand, I think the grey is just a carbon filter, especially since it is so evenly grey.
The Following User Says Thank You to Draco-REX For This Useful Post:
Do Boy (12-11-2012)
Old 12-11-2012, 09:18 PM   #5
F1point4
Photo Specialist
F1point4's Avatar
Duly noted. Thanks for pointing it out. I think the next step is to secure a new filter and figure out if its gray that way from the factory
Old 12-12-2012, 06:40 AM   #6
Hardrock4445
Hardrock4445's Avatar
That is a charcoal filter. See them all the time at work. Looks pretty clean to me!
Hardrock4445 is offline   Reply With Quote
Old 12-12-2012, 09:11 AM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
This is what a new carbon-activated filter looks like:
Notice the even grey.
jcw99 (07-09-2014)
Old 12-12-2012, 10:35 AM   #8
Turbowned
Turbowned's Avatar
I just used my friend's carbon-filtered breather mask while he was painting a car in his shop, it felt like breathing the purest air, ever. Good stuff.
Old 12-13-2012, 01:31 PM   #9
Mikes86
Drives: 2013 fr-s
Does it feel pretty heavy? The carbon filter ones Toyota has are pretty heavy like its heavier than u think it really should be the non carbon ones are really light, I'll check mine later this weekend and see if its carbon one or not...
Mikes86 is offline   Reply With Quote
Old 02-04-2013, 08:18 PM   #10
so26
Drives: Raven FR-S 6MT
I figured I'd add this here to keep info all in one place (I hope the OP doesn't mind). Anyway, I replaced the orginal OEM cabin filter with a FRAM Fresh Breeze Cabin Air Filter. Of course they don't make one that fits the twins yet so I found one that was a close fit and trimmed it to size. Turns out that model CF10370 that fits recent Ford Mustangs is pretty close in size.
[ame="http://www.amazon.com/CF10370-Fresh-Breeze-Cabin-Filter/dp/B001CEJGYO"]FRAM CF10370 Fresh Breeze Cabin Air Filter : Amazon.com : Automotive[/ame]
Pic with OEM filter on top of Fram filter
Sideview
After trimming the excess material with a pair of scissors I glued a piece of cardboard to the cut end.
I haven't tried it out yet but I'll let you know when I do. There is a lot of rock salt on the roads now so I hope the new filter will cut down on the amount of salt dust entering the cabin. BTW, after 11000mi the original filter was very dirty just like OP's filter.
Update: It seems like the filter is working nicely. Hopefully Fram will come out with a model for the twins.
so26 is offline   Reply With Quote
The Following User Says Thank You to so26 For This Useful Post:
Rayme (02-04-2013)
Old 04-05-2013, 05:02 PM   #11
foxhu
I just cleaning for spring... theres leafs in it and dust and everything!!!!! I am at 6000 miles and it's so dirty. I live in NYC guess it is the dirtiest place in USA LOL!@!@!@!
foxhu is offline   Reply With Quote
Old 04-06-2013, 12:09 AM   #12
zooki
Drives: waiting on a 2021...
I just received a new cabin air filter from Toyota as part of the 15,000 mile service, and it was NOT charcoal activated. I pulled my original out and it was as dirty & gray as the OP's was.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 04-06-2013, 01:11 AM   #13
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
25,000 miles
I'll be back!!
F3dzo is offline   Reply With Quote
The Following User Says Thank You to F3dzo For This Useful Post:
bestwheelbase (06-26-2013)
Old 04-10-2013, 10:55 AM   #14
reeves
The factory BRZ cabin filter (part# 72880AJ010) is available on Amazon for those who don't live near a dealership: [ame="http://www.amazon.com/Genuine-2013-Subaru-Cabin-Microfilter/dp/B00939JDEI/ref=sr_1_4"]Genuine 2013 Subaru BRZ Cabin Air Microfilter : Amazon.com : Automotive[/ame]
reeves is offline   Reply With Quote
The Following 2 Users Say Thank You to reeves For This Useful Post:
jcw99 (07-09-2014), Sportsguy83 (02-26-2014)
air filter, cabin air filter, diy
Safety Inspection Sticker Mount Philz0r Hawaii 13 06-12-2015 02:29 PM
brake pad inspection sickmint79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-05-2013 09:22 PM
inspection sticker question wallace03 Off-Topic Lounge [WARNING: NO POLITICS] 6 12-02-2012 04:48 PM
PIC 10K TRD Air Filter Inspection Yruyur Scion FR-S / Toyota 86 GT86 General Forum 8 10-07-2012 01:53 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
