Old 12-20-2012, 01:44 AM   #1
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
Enkei RPF1 17x7+42 anyone?
Hi everyone, I am interested in seeing if anyone has bought the enkei rpf1 in 17x7 for stock class auto x. If so does anyone have a pic to see what these look like? I am thinking they look almost the same as the 17 x 8. Thanks
Gearhd79 is offline   Reply With Quote
Old 12-20-2012, 07:37 AM   #2
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
I know they are in the works. Interested to see what size tires everyone is going to go with. 225/40/17, 235/40/17, etc...
n8dog11914 is offline   Reply With Quote
Old 12-20-2012, 07:52 AM   #3
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
Tire rack has them In stock in black (the color I want) so i am hoping someone has them now or will be getting them directly. I might just run a Dunlop star spec2 in stock size 215 45 17
Old 12-20-2012, 07:53 AM   #4
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
I plan on buying these wheels next year (group buy anyone?)
Will probably run either 225/45 RS-3's or 235/40 Dunlops ZII's
Aznsky is offline   Reply With Quote
Old 12-20-2012, 09:15 AM   #5
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I'm not exactly sure what you mean by what they will look like ... but they will look exactly like any other RPF1... but an inch narrower than the X8's... and with 6mm additional offset than the stock wheel, adding a total of 12mm of track width front and rear, which is approx. a 1/4"... or 1/8" per side, which means it wont be very noticeable.
I'll be putting a 245/40 R-comp on them for next season... not sure yet if that will be a Hoosier, Goodyear, or BFG.... since I don't have the funds to properly test them, I'll probably stick with the Hoosiers.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 12-20-2012, 09:33 AM   #6
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Different width/offets look different due to the 12 spokes' design. Some setups or flat, some convex, some concave. That appearance matters to some people enough to not buy a certain size (but not me!)
I'll be sticking with 215 RS3s as street tires don't oversize well for autocross. If I was doing Hoosiers (RTR though, I cant stand Rcomps in stock haha), 245s would be the choice.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 12-20-2012, 09:58 AM   #7
xwd
Nice to see they finally have the 17x7s in stock.
Street tires with stiff sidewalls work fine for autocross. The guys successful running in RTR last year were running 235/245 Star Specs on 17x7 rims. The RS3s aren't quite as good oversized as the Star Specs though.
Old 12-20-2012, 10:32 AM   #8
Kido1986
Dodging cones
Kido1986's Avatar
I saw the results were listing the Dunlops but where did you see them listing their tire size setup?
In Florida, the RS3 gets so damn hot most of the year that it tends to outdo the Star Spec since it's so warm.
I have to buy tires very very soon and I'd go Dunlop if I could try the new SS2 but they are lagging so far behind on their release here
Old 12-20-2012, 11:03 AM   #9
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
Dunlops are way off in availability im fairly sure ... As far as looks, not that big a deal for me but I just think the spokes might stick out way past the rim in a 7" width.
Old 12-20-2012, 11:09 AM   #10
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
Also for what it's worth based on what I've read and seen this rim has the best offset for running in stock class
Old 12-20-2012, 12:31 PM   #11
Kido1986
Dodging cones
Kido1986's Avatar
Technically, yes. +42 is the most aggressive offset you can run on this car legally for stock class. Though I doubt anyone loses/wins a position in their event over 12mm wider/shorter stance on each end of the car.
My wheels are 1.65mm too far offset technically for stock class but no one local has had a complaint. I'm sure my wins were all due to that 3.3mm stance increase :P
Old 12-20-2012, 01:25 PM   #12
SVThis
SVThis's Avatar
Drives: Scion FRS
I'm a little concerned what they'll look like also but I'll buy them anyways. They can't look much worse than the stock wheels. I'm planning on running 225/45/17 Star Spec II's. My kid works at Tire Rack in technical support and I told him to grab a set for me when they come in.
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 12-20-2012, 01:31 PM   #13
SVThis
SVThis's Avatar
Drives: Scion FRS
If I'm ever down in Orlando I'll be sure to protest you.
Old 12-20-2012, 01:38 PM   #14
Kido1986
Dodging cones
Kido1986's Avatar
Hahah, thanks
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei RPF1 Type-II 17x7.0 +48 hankster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 10-05-2013 02:23 AM
Enkei RPF1 18x9.5 +38 maj75 Wheels and Tires 16 05-22-2013 09:28 AM
CA-Enkei RPF1 17x8 ET 35 $899!!!! diirk Wheels and Tires 6 11-21-2012 09:15 PM
