Tracking / Autocross / HPDE / Drifting What these cars were built for! |
01-02-2013, 05:43 PM | #1 | ||
The "Pedal Dance" testing
I don't remember the original post (and a quick search didn't find it...), but someone had posted up a sequence to turn off additional electronics in the car. The sequence is as follows:
- Turn on the car. The car must be FULLY warmed up. You must do the entire sequence within 30 seconds of starting the car. - Pull the e-brake 3 times. Hold/lock the e-brake on the 3rd pull. - Press the brake pedal 3 times. Hold it down the third time. - Pull the hand brake 3 more times. Hold/lock the hand brake on the 3rd pull - Press the brake pedal 2 more times. - On the last press of the brake pedal, two yellow lights should have come on. I purposely used staggered brake compounds to test whether the brake dance does anything; here are my conclusions. - The pedal dance eliminates electronic brake force distribution. - The pedal dance also eliminates the "panic brake" function. - I tried trail braking mid-turn with the "normal" electronic aids off, but without the pedal dance. This resulted in a spin; the car literally locked up the rear brakes. My speculation is that the car recognized the fronts locking up, and put additional force on the rear brakes. The problem here, is that I had purposely put a much lower friction pad in the back, so it kept sending more and more brake pressure to the back, until it just locked. Once it locked, it stayed locked, even though I was not stepping on the brakes. - I tried this again a few more times. Same result. - I then tried again, but with a rear brake bias. This time, pressing on the brakes mid-turn or trail braking always resulted in the car straightening out and/or plowing. - With the pedal dance, I can trail brake or brake in the middle of a turn for rotation just fine, regardless of pad setup. Moral of the story: if you're driving on a track or at an autocross, do the pedal dance! (Remember, ALL aids will be off) All testing was done on a closed course, at the "Balcony", courtesy of Willow Springs Raceway. *edit* From another post: Quote:
The Following 126 Users Say Thank You to CSG Mike For This Useful Post: | 1slo_frs (09-22-2013), 2pointSLOW86 (01-20-2015), 350zgoingFRS_lol (11-06-2014), 37 (08-20-2013), Allch Chcar (06-27-2017), Anthony (08-25-2013), Anthonytpt (02-07-2013), Antihero983 (05-11-2016), Arsenal Autosport (04-25-2013), atomicalex (08-20-2018), Atropine (08-17-2014), Aznsky (01-02-2013), BatStig (07-14-2014), BBDGriptonia (02-09-2016), bear89103 (08-05-2013), bedabi (12-27-2013), bestwheelbase (01-11-2013), Bg8780 (07-23-2013), Black Tire (02-23-2013), Blokatos (05-15-2016), Blu-by-U (03-15-2015), Bonburner (01-22-2013), Bristecom (06-09-2013), buzznasa (03-11-2014), CamryDS (04-30-2013), CARNZ (02-01-2014), cbryant514 (06-27-2017), chanomatik (01-24-2013), ChrisD (06-23-2015), cmspooner (03-23-2013), cobrabyte (01-03-2013), coyote (01-02-2013), Dadhawk (02-25-2013), DanoFA20 (01-27-2014), dave77 (01-05-2014), digital_assassin (08-16-2014), dowroa (11-28-2017), dp1 (07-20-2016), Drakiv (05-11-2018), evil_1998 (05-24-2013), FearBoy (11-26-2013), finch1750 (03-18-2014), Flat Black VW (01-18-2013), flippy (01-15-2016), Fly Guy (04-26-2013), fourvalleys (12-21-2013), Freedom (12-25-2015), Frost (01-28-2014), FRSToyota86 (01-20-2015), FrX (01-03-2013), fx35s (12-27-2014), Ganthrithor (11-12-2013), garfull (06-09-2014), GeorgeJFrick (10-13-2015), Gords_zenith (01-09-2013), GT86_PRAGUE (10-20-2015), Guff (05-02-2013), hpde_addict (07-22-2016), HunterGreene (05-01-2013), Hyper4mance2k (10-13-2014), JaguarXJ6 (01-07-2014), JARunning (10-07-2015), jcw99 (06-13-2018), JEFFSTYLE (10-04-2014), JiB (01-09-2013), JohnJuan (11-13-2014), juliog (02-15-2014), Karigan (04-29-2014), karma003 (04-11-2013), Keenercarguy (12-24-2015), Kimsey47 (11-13-2013), Lawnik (04-12-2013), LeftFootBrake (01-06-2013), LucidMomentum (09-23-2014), Mandy (03-16-2013), Mikem53 (05-23-2013), mikochu (08-13-2013), Milotic (07-31-2020), mkiisupra (01-06-2013), mokinbird87 (02-01-2016), MrAmalto (08-25-2014), MSTiFK8R (01-17-2013), nataku (01-25-2013), neurokinetik (03-15-2013), normancw (10-29-2013), Oldfatguy (09-06-2013), P@ul (04-30-2014), Pseud0logik (05-08-2014), PWBRZ (08-13-2014), QFry (02-12-2013), Ramster (02-26-2015), raul (09-09-2014), RazBRZ (12-03-2014), Razzle (05-14-2014), rice_classic (01-02-2013), Sarlacc (01-10-2014), sato (07-09-2017), Scooby South (03-16-2013), Sisko's_Baseball (09-24-2020), Sleepless (07-01-2022), SMOKETREES (01-18-2013), SocalMonsta (03-14-2015), softgrip (03-16-2016), solidONE (03-22-2013), Squishy86 (03-25-2013), Stephen02 (08-05-2022), stockysnail (10-02-2015), supra2nv (11-16-2015), TallTerror13 (02-17-2014), tech4pdx (03-22-2013), TorontoNat (01-18-2018), Touge Monster (01-18-2013), track_warrior (01-20-2013), Trap63 (04-29-2014), Tristor (05-21-2018), troek (01-21-2014), weepel (09-13-2021), whataboutbob (01-17-2013), WillRacer1jz (03-14-2013), wise345 (01-13-2016), WolfpackS2k (09-05-2013), WolfsFang (01-31-2013), woode (12-29-2013), Xero-Limit (04-26-2013), xkalelx (05-11-2016), zoomzoomers (03-14-2013) |
01-02-2013, 05:52 PM | #2 |
Drives: Nissan 350Z (sold) 13' Whiteout FRS
Wow those are some very helpful results!
I'm assuming the electronics go back to normal after you restart the car? I wonder how this was figured out and whether or not we can make it simpler. |
01-02-2013, 05:54 PM | #3 |
Yes, the electronics go back to normal after restarting the car. You'll need to do it every time you start the car when you want all aids to be off.
The Following User Says Thank You to CSG Mike For This Useful Post: | dave77 (01-05-2014) |
01-02-2013, 05:55 PM | #4 |
Site Moderator
Drives: Stuff
They do. This is a diagnostic mode really.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
01-02-2013, 05:56 PM | #5 |
pic of the two yellow lights please?
01-02-2013, 05:59 PM | #6 |
Drives: Attitude
01-02-2013, 06:10 PM | #7 |
Drives: MY00 Impreza 2.5RS
I don't know why, but the process reminds me of this.
The Following 16 Users Say Thank You to TOMIMOTO For This Useful Post: | Anthonytpt (02-07-2013), chanomatik (01-24-2013), danthedirt (01-02-2013), djdnz (03-06-2013), EN2_Squirrel (01-21-2013), finch1750 (01-03-2013), Fly Guy (04-26-2013), Guff (06-07-2013), jbsali (04-08-2013), JiB (11-03-2013), karma003 (04-11-2013), PoorMansRacing (11-21-2013), Scooby South (04-08-2013), SirBrass (11-23-2013), suaveflooder (03-16-2013), tmcmullins (04-08-2013) |
01-02-2013, 06:23 PM | #8 |
01-02-2013, 06:28 PM | #9 |
Site Moderator
Drives: Stuff
Close. Trac off and VSC off. Ie the same two lights that light up when you hold the traction/VSC off button for 5 seconds.
-Dave
01-02-2013, 06:46 PM | #10 |
Overthinking it
Drives: BRZ in CS
Does it affect ABS?
01-02-2013, 07:28 PM | #11 |
Drives: Slowly
Having experienced the lock up to which you refer in other vehicles, I appreciate this post.
When I read the thread title, I was however expecting to see this old video: [ame="http://www.youtube.com/watch?v=Ts29KKhKXds"]Walter Rohl - YouTube[/ame] |
The Following 8 Users Say Thank You to coyote For This Useful Post: | disgruntld (01-20-2013), DrDuquette (01-25-2014), FRSBRZGT86FAN (11-16-2014), pascalbrax (03-25-2013), Quentin (10-23-2014), so26 (01-02-2013), track_warrior (01-20-2013), troek (01-21-2014) |
01-02-2013, 07:36 PM | #12 |
Drives: 2013 FR-S Ultramarine
How is the brake bias with EBD off? I read somewhere that people were worried it would shift with ABS and/or EBD off.
Nathan |
01-02-2013, 07:38 PM | #13 | |
Nope. |
01-02-2013, 08:17 PM | #14 |
Drives: brz 13
worked for me, thanks
Similar Threads | ||||
Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 11:24 AM |
Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
