Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 01-27-2013, 02:28 PM   #1
Diode Dynamics
Diode Dynamics's Avatar
Lightbulb Diode Dynamics HDHalo FRS & BRZ Angel Eye Kits! Made in USA! New Styles Available
Scion FR-S / Subaru BRZ Angel Eyes
[ame]http://www.youtube.com/watch?v=yhE1PHkW5tI[/ame]
Angel Eyes can be installed on any vehicle as an accent for your headlights. They can be found on BMWs and are a nice modification for any vehicle. The angel eyes from Diode Dynamics are the highest quality and brightness available. Look around, you will not find better angel eyes anywhere for these great prices! Our rings were custom-designed for reliability and long life, and have been tested on your vehicle for perfect fitment.
Our newest product, RGB MULTICOLOR angel eyes come with a remote control, in order to pick the color or effect you want. The controller has a static memory, so you can leave the angel eyes switched to WHITE for every time you start your car and drive around, then get out and change up the color! You can choose 16 different colors, with variable brightness, or pick a show mode, including strobe, flash, and fade. They also come with a custom wiring harness, for plug-and-play wiring, and a standard RGB controller unit with remote. We also offer a radio-frequency remote for easier use and installation.
Kit includes:
  • Two (2) Multicolor RGB SMD Rings, fitted for your vehicle
  • Infrared multicolor remote, to change the color OR NEW RF Remote!
  • Diode Dynamics Plug-and-Play Wiring Harness
  • Installation guide
  • Three year limited warranty
We use custom-manufactured SMD rings through our top LED manufacturer, with high-grade AAA resistors and LED chips. They are highly durable, with a black backing color. The LEDs go all the way around the ring, for no "break" in the light as with other angel eye designs, and are ten times brighter than old fiber-optic type rings.
Installation requires you to open the headlight, by using heat from either your oven or a heat gun. It sounds bad, but really isn't too hard. Simply remove all screws, heat the seal, and pull apart. We have installation videos and other helpful guides available at diodedynamics.com/install. The wiring is a plug-and-play installation, using our Diode Dynamics Angel Eye Harness and quick disconnects. You will not have to do any soldering, wire stripping, crimping or anything. Our wiring harness makes wiring a breeze!
Don't want to do it yourself? Looking for a kit for a different model? We can do any vehicle for you, with our large inventory of ring sizes. Contact us for information.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
FR-S Angel Eye Kit
BRZ Angel Eye Kit
(pictures show two RGB strips installed along with the RGB angel eye kit)
FR-S Angel Eye Kit
BRZ Angel Eye Kit
Videos of kits in action
[ame="http://www.youtube.com/watch?feature=player_embedded&v=mjnwNEr_-lE"]RGB Multicolor Angel Eyes from Diode Dynamics - YouTube[/ame]
[ame="http://www.youtube.com/watch?feature=player_embedded&v=L1o-N7MSLhM"]Camaro Custom Lighting (Multicolor Angel Eye Halos, Switchback LEDs, LED Fogs) - YouTube[/ame]
Remote control comparison
[ame="http://www.youtube.com/watch?feature=player_embedded&v=F2qA3-DcH1E"]Diode Dynamics RGB Controllers: Standard (IR) vs Upgraded (RF) Comparison - YouTube[/ame]
Scion FR-S Angel Eye Kit
Subaru BRZ Angel Eye Kit
Research Angel Eye Technology
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
Thanks for looking!
Nick C.
Diode Dynamics
Old 01-27-2013, 04:08 PM   #2
Mo707
Mo707's Avatar
My friend just bought something similar to this and i helped him install them on his BMW but he has to get out of the car to change the color. Any way we can extend the receiver through the firewall and into the cabin? Would that void the warranty?
Mo707 is offline   Reply With Quote
Old 01-27-2013, 04:16 PM   #3
Diode Dynamics
You could, but if you purchase the RF remote, you can control it from anywhere (up to 20-30 yards away from the vehicle even). It uses radio frequency instead of infrared with a sensor.
Please check out the "remote control comparison" video above! (last video in post)
Thank you!
Paul
Old 01-27-2013, 04:28 PM   #4
Mo707
Mo707's Avatar
Thank you!
Paul
What's the difference between the two?
Old 01-27-2013, 04:34 PM   #5
Diode Dynamics
Please watch the video above! It will answer your question fully.
The standard remote is infrared (needs to be pointed at sensor) and the upgraded remote is RF (no pointing at a sensor).
Paul
Old 01-27-2013, 07:12 PM   #6
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
What about the LED strip in front of the high beam? Is that included as well, or is it an additional option/cost?
kmbkk is offline   Reply With Quote
Old 01-27-2013, 10:16 PM   #7
Diode Dynamics
The small strips are available as a $30 add-on. They plug right into the kit with no additional wiring needed.
Thanks,
Paul
Old 01-27-2013, 10:40 PM   #8
F n' A Automotive
F n' A Automotive's Avatar
Drives: 11 STi Sedan
Friendly comment for Diode.. We and our customers LOVE the RGB strips they supply us with. Very simple to work with, and great quality!
F n' A Automotive is offline   Reply With Quote
The Following 2 Users Say Thank You to F n' A Automotive For This Useful Post:
Diode Dynamics (05-20-2014), Vanga (01-29-2013)
Old 01-28-2013, 10:58 AM   #9
Diode Dynamics
Thanks guys! We have invested a lot into our manufacturing in order to make sure they are the best!
Paul
Old 01-28-2013, 11:23 AM   #10
Xdragonxb0i
Drives: ex500r
We would have to bake open the headlight housing to install this?
Xdragonxb0i is offline   Reply With Quote
Old 01-28-2013, 11:28 AM   #11
Mo707
Mo707's Avatar
Yeah.
Old 01-28-2013, 07:50 PM   #12
Diode Dynamics
Correct- the FRS headlights are EXTREMELY easy to work with though. Easiest headlights we've opened in quote a while.
Paul
Old 02-02-2013, 11:06 PM   #13
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
Those look pretty good. I'm conflicted with color though... Purple or Red on a RAVEN FRS. Was thinking overlays, but halo's look pretty damn cool.
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Old 02-03-2013, 11:16 AM   #14
Diode Dynamics
I personally recommend RGB multi-color kit, endless color possibilities and plenty of show modes available. You could change them to any color via remote control
Thanks!
Angel Eyes installed on and off with ignition!! Roborat Cosmetic Modification (Interior/Exterior/Lighting) 87 09-06-2013 01:04 AM
Controlled Information Leaks groupb Scion FR-S / Toyota 86 GT86 General Forum 27 02-12-2013 08:20 PM
DIY wired angel eyes to on/off with ignition Roborat DIY (Do-It-Yourself) Guides 10 01-30-2013 04:46 PM
