Old 03-27-2013, 07:02 AM   #1
victorb
Drives: Black 86
Fuel Trims - Long term and short term
Hi Forum Members,
I would like to ask help, inputs and opinions regarding our 86 stock ECU trims, air/fuel mixture and adaptation.
In my other cars, short term fuel trims greatly varies but long term stays put. In the 86, the long term varies a lot...why is this?
My car is stock with just an axle back greddy sp elite. Milage is 1,550kms, Manual. I checked and monitored the following data:
Idle 1,500rpm 2,500rpm
Short term fuel trims -1% to +3% -4% to +4% -6% to +3
Long term fuel trims -2% to +3% -4% to +6% -3% to +1
ignition advance +12 deg +18% +42 deg
Coolant temp 190'F-205'F
Octane is 100. Its called blaze here in the Philippines. Its without ethanol and uses organic additives as a substitute to ethanol. (i believe it sugar cane alcohol instead of corn?). Using this fuel is a good sign? as my ignition is on an increasing pace?
I think the car mostly runs on the rich side with light to moderate loads say -6% to +3% longterm and short term trims.
I will be installing a drop in HKS filter soon and I hope the ECU leans out a bit in order to generate more power =)
victorb is offline   Reply With Quote
Old 03-27-2013, 07:10 AM   #2
ft_sjo
Drives: GT86
http://www.ft86club.com/forums/showt...ght=fuel+trims
Old 03-27-2013, 11:04 AM   #3
andrew20195
Drives: 2013 Subaru BRZ
Which method is used to get the 100 Octane number? (R+M)/2 or RON?
BTW, sugar cane alcohol is mostly ethanol.
At any rate, based on the other threads it's looking like the twins may have a poor tune from the factory, much like older Subarus I've read about.
andrew20195 is offline   Reply With Quote
Old 03-27-2013, 11:06 AM   #4
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
you running ecutek?
Huehuecoyotl is offline   Reply With Quote
Old 03-27-2013, 11:36 AM   #5
mad_sb
Drives: 2013 Asphalt FR-S
Ha Ha,
Yeah, I posted this thread a while ago. There are a few reasons.
1. There are 4 different long term trim bins that will be used depending on the maf reading so some of what you are seeing is the reading going from one long term trim bin to another
2. Stock Ecu holds closed loop for a relatively long time (so, slow transition to open loop)
3. Stock maf scaling seems to be crap for most cars crap
Old 03-27-2013, 11:49 AM   #6
victorb
Drives: Black 86
Its RON. I am only thinking they used sugar cane alcohol because it said 'no ethanol, with organic additives'
Lets see when I install the HKS drop in. hope to see improvements
Old 03-27-2013, 02:18 PM   #7
andrew20195
Organic additives could be considered things like benzene, toluene, xylene, etc., which they pretty much have to be using if they aren't adding ethanol.
Good luck with the filter! You may need a custom tune to really have a smooth running car, though.
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
Forced Induction - is there a long term reliability problem for the 86/BRZ Dazza Forced Induction 32 09-26-2012 12:39 AM
2013 Subaru BRZ Limited Long-Term Test - InsideLine brianc BRZ First-Gen (2012+) -- General Topics 0 08-01-2012 07:18 AM
Insideline getting an FR-S, BRZ long term test cars Gaiakai Scion FR-S / Toyota 86 GT86 General Forum 20 07-10-2012 04:47 PM
