Old 04-01-2013, 07:36 PM   #1
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
DIY: 5lb Shorai Battery Install
There are several options out there for lightweight batteries. I didn't really like any of them. Most seemed overpriced, underpowered and/or overweight for what they offered. During the course of my research, I came across the Shorai lithium-iron battery... It's very light, cheaper than lithium-ion and packs quite a bit of power. Like a freaking unicorn of lightweight batteries. I have no idea why everyone isn't running these.
So I pulled the trigger...
Ordered a Shorai LFX36A3-BS12 Powersports Battery (A better battery with the correct orientation would be the LFX36L3-BS12) ~$270
Also ordered...
[ame="http://www.amazon.com/gp/product/B004DDI0DE/ref=oh_details_o08_s00_i00?ie=UTF8&psc=1"]Braille Battery 1821 Universal Mount Kit / Rubber Tie Down [/ame](I have replaced the actual rubber tie with the metal SPT tiedown, works great!)
[ame="http://www.amazon.com/gp/product/B0002ZR4UC/ref=oh_details_o09_s00_i00?ie=UTF8&psc=1"] Brass SAE Automotive Battery Terminal Set for Hawker Odyssey Batteries [/ame]($12)
I found out I needed these to finish the install...
[ame="http://www.amazon.com/gp/product/B0071GWVIU/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1"] KnuKonceptz 1/0 Gauge Crimp Style Ring Terminal [/ame]($8)
[ame="http://www.amazon.com/gp/product/B004Z0YB5Q/ref=oh_details_o02_s00_i01?ie=UTF8&psc=1"]KnuKonceptz KCA Kable 0 Gauge Power Wire Black [/ame]($4)
1/4" Nylon washers from Lowes, see picture ($1)
The specs on the battery are amazing...
And the battery weighs exactly 5.2 pounds. More capacity than stock and 24 less pounds!
Installation was a bit tricky but once I eyeballed it enough I figured it out.
There was no way to make it fit with the stock mounting hardware and using just the stock battery hookups. I decided to make about a foot long extension for the negative terminal. I crimped the huge connectors with a set of lockjaw pliers then made a double crimp compression using a chisel and hammer. Those connectors aren't going anywhere!
I also needed to buy some 1/4in nylon washers (I sandwiched them between stainless fender washers) for the stock battery ties because the new battery is so short I ran out of threads. Using that hardware with the braille rubber tie, everything went in perfect.
I installed some thick rubber weatherstripping along the base of the battery to offer a little extra security. I can rock the car with the battery though so I don't think it's going anywhere. I zip tied the OEM negative hardware where you see it along one of the preexisting wiring harnesses.
Retained all the stock hardware for the winter months when the big battery might have to go in.
I'll update this thread when/if the battery gives me a hard time. I've started the car just fine all day today. Fires right up like stock. There are some s2k guys that have been running this battery for 2 years with no troubles. If anyone has any questions, let me know!
This battery is also used on the awesome TRD griffon car too.
industrial is offline   Reply With Quote
The Following 26 Users Say Thank You to industrial For This Useful Post:
Anthony (09-06-2013), Anthonytpt (10-25-2013), B L U E S L A T E (10-04-2013), Black Tire (04-09-2013), botbs (02-25-2018), EAGLE5 (04-05-2013), EN2_Squirrel (06-01-2013), etc (09-12-2016), GT86_PRAGUE (05-13-2015), hamzam (07-12-2015), Irace86.2.0 (06-18-2022), jliongh (09-24-2016), Joveen (01-07-2019), kanundrum (04-10-2013), Laika (04-01-2013), Lawnik (04-03-2013), new2subaru (03-10-2016), normancw (04-06-2013), PineappleFriedRice (08-07-2013), Pistol (05-04-2014), ProjectD (06-01-2013), Raven86Project (02-23-2021), ShadowSeraph (01-29-2014), suaveflooder (05-12-2014), TRD_07 (04-10-2013), Tristor (08-30-2018)
Old 04-03-2013, 10:00 PM   #2
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Thanks for the writeup. I have my lfx21 coming in. I managed to find 6" j-hooks =)
Let us know how the battery holds up. Might have to invest in the Shorai charger...
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
The Following User Says Thank You to markmatley For This Useful Post:
industrial (04-05-2013)
Old 04-05-2013, 06:34 AM   #3
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Had a few 30 degree mornings. The car seemed to have an easier time starting than with the stock battery. Been dding like its a normal battery, nothing strange to report.
The Following User Says Thank You to industrial For This Useful Post:
Anthonytpt (04-05-2013)
Old 04-10-2013, 04:10 PM   #4
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
I feel more comfortable doing this mod knowing that the professionals involved in the TRD Griffon project went with this battery. On the other hand seems like no reported issues from "Industrial" which is also good to know.
TRD_07 is offline   Reply With Quote
Old 04-10-2013, 10:59 PM   #5
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Very nice find, thanks for sharing
OjiGeorge is offline   Reply With Quote
Old 06-01-2013, 01:51 PM   #6
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
Thanks for sharing. Very nice find indeed.
ProjectD is offline   Reply With Quote
Old 08-07-2013, 05:52 PM   #7
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
It turns out that Shorai makes another version of this battery, the LFX36L3-BS12, that is exactly the same, except it has the opposite polarity of the one in this DIY.
If you used that version, you would not have needed to make adaptor/extension cables, and it would have been a drop-in fit.
http://shoraipower.com/lfx36l3-bs12-p130
[ame="http://www.amazon.com/gp/product/B005P975X6/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1"][/ame]
Last edited by neurokinetik; 08-13-2013 at 06:35 PM. Reason: 6" J-hook kit is useless
neurokinetik is offline   Reply With Quote
The Following 13 Users Say Thank You to neurokinetik For This Useful Post:
Anthony (09-06-2013), autobrz (10-04-2013), gkubed (01-09-2020), GT86_PRAGUE (05-13-2015), illmatic (08-07-2013), industrial (09-06-2013), jliongh (09-24-2016), mfbmike (09-06-2013), nunonuna (06-29-2017), smg1138 (06-02-2017), SuperTom (07-10-2018), Tristor (09-21-2018), YouShallKnow (02-05-2015)
Old 08-13-2013, 07:00 PM   #8
neurokinetik
So the drop-in fit wasn't exactly true. I ended up fabbing my own battery tie-down out of aluminum T-channel because the Braille one was not going to work with the battery mounted in the stock orientation. I knocked this together in about an hour, and it is way overkill for the job. But, much like Industrial's solution, if you grab the tiedown or the battery and try to shake it, the whole car moves.
I'm going to make a couple of revisions to this to simplify it, make it lighter, and also Plasti-dip it for additional safety.
End result though, I was able to use the factory j-hooks, and battery terminals.
The Following 7 Users Say Thank You to neurokinetik For This Useful Post:
8686 (08-14-2013), Anthony (09-06-2013), BigHugeFatGuy (11-13-2019), GT86_PRAGUE (05-13-2015), ProjectD (05-11-2014), TRD_07 (08-13-2013), Tristor (09-21-2018)
Old 08-24-2013, 11:56 AM   #9
neurokinetik
Revised the battery tie-down. This version is pretty close to the same weight as stock, if not lighter. Materials needed to make one like it are around $10.
http://stores.ebay.com/8020incgaragesale
I am using the equivalent of the 2020 metric T-slot profile, and you can get an 18" long piece for less than $5 off ebay. Just add the appropriate size button head cap screws and you've got all you need. Use a chop saw (or even a hacksaw - just make sure your cuts are square) to cut the pieces to size (one 8.5 inches, one 3, and one 1), and tap the ends of the two short support pieces to match the cap screws. Mark your locations and drill four holes in the long section: two for the J-hooks, and two access holes to tighten the button head cap screws.
I've got the J-hooks on the wrong ends in the picture, but you get the idea. I'm probably going to plasti-dip this thing, but haven't bothered yet.
EDIT: Did a half-assed Plastidip job on the tiedown. Looks ok for what it is, and the dip provides insulation as well as even better grip on the battery.
The Following User Says Thank You to neurokinetik For This Useful Post:
FrX (08-27-2013)
Old 08-27-2013, 03:31 PM   #10
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
How has this battery performed so far?
kiichiro is offline   Reply With Quote
Old 09-04-2013, 05:55 PM   #11
neurokinetik
Industrial would be better able to answer, but I've had no issues so far. Car is daily driven. I do not plan to run this battery year-round, even though I probably could.
Old 09-06-2013, 07:25 AM   #12
jimmy4thenguyen
Drives: Whiteout FRS
looking for a lightweight battery as well. is your car a DD? also, let us know how it performs in the winter!
jimmy4thenguyen is offline   Reply With Quote
Old 09-06-2013, 08:37 AM   #13
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Thanks for posting this. Somewhere I saw someone claim they were running a 3.5lb Shorai battery, so I've been planning on getting one ever since, but haven't started researching them yet. Thanks for reducing my workload.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-06-2013, 08:49 AM   #14
Anthony
Weight Nazi
Anthony's Avatar
Cranking the car is the biggest load you'll require from a battery, right? I'm pretty sure it is. So wouldn't a lightweight flywheel + lightweight pulleys reduce the requirements for the battery?
Whenever the time comes, I'll be trying to go with as small a battery as I possibly can.
The Following User Says Thank You to Anthony For This Useful Post:
gkubed (01-09-2020)
Bad battery 5hairpins Issues | Warranty | Recalls / TSB 3 02-25-2013 10:01 AM
Help with Car Battery Synack Off-Topic Lounge [WARNING: NO POLITICS] 0 01-13-2013 10:05 PM
Winter: Electric car & battery warmer install JSUB BRZ First-Gen (2012+) -- General Topics 2 12-26-2012 10:55 AM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
