Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
04-10-2013, 01:29 PM | #1 |
Drives: blue
FRS colors = Prius colors?
With where I live, I’ve seen more Toyota Prius that I need in my lifetime. Because of that, I’ve seen all the factory colors of a Prius. But, I’ve yet to see all the colors of an FRS.
My question is, are the colors on the FRS the same colors they use on the Prius? They look incredibly similar. If this is true, then I've seen all the colors of the FRS. i.e. The Pearl white Toyota uses on the FRS is practically the same as the pearl white on the FRS/BRZ On a side note, there are many BRZ owners in my area. But I’ve seen them ONLY in WRB. Actually, I saw one in pearl white one time. Once. |
04-10-2013, 01:30 PM | #2 |
Drives: 2013 Asphalt FR-S
No, all FR-S colors except Hot Lava are Subaru paint codes.
The Following User Says Thank You to zaptorque For This Useful Post: | raul (04-10-2013) |
04-10-2013, 02:28 PM | #3 |
Drives: 2013 Scion FR-S AT Asphalt
ALL '86s are manufactured at a Subaru plant in Japan.
So, no. They aren't Prius colors any more than they are Camaro, Accord, Mustang, Aston Martin, ect colors. Scott
04-10-2013, 03:14 PM | #4 |
Drives: blue
I swear though, the pearl white and galaxy blue on Prius cars are quite literally the same on FRS.
Wait, I guess then the question is: Do Prius(es) paint colors come from Subaru? |
04-10-2013, 03:19 PM | #5 |
Drives: Silica BRZ 6MT
Fashionable colors are fashionable colors. I'm sure the paint code differs but overal the colors are repeated across industries. I saw a blue maxima the other day I swear was WR Blue.
04-10-2013, 03:20 PM | #6 | |
Scott
04-10-2013, 03:20 PM | #7 |
Drives: 2013 Whiteout FRS
FR-S in champagne... hmmmmmm..
The Following User Says Thank You to m.box.design For This Useful Post: | Calidrifter (04-10-2013) |
04-10-2013, 03:21 PM | #8 |
Red wine
Drives: Subaru BRZ(R.I.P)
If they do not have the same paint code, then they are not the same color.
The Red FRS is a hair darker than the Lightning Red BRZ(I parked next to one so I know). Even though they are both built in Gunma, they are not the same color.. And why do you care if the FRS uses the same paint as a Prius? If you dont want to look like a Prius go buy a WRB BRZ.
04-10-2013, 03:44 PM | #9 |
Automatic Hooligan
The nautical blue on the Prius is darker than GBS/Ultramarine. E8H is actually closer in shade to Toyota 8T5 (Blue Ribbon Metallic) than 8S6 (Nautical Blue).
04-10-2013, 03:49 PM | #10 |
Drives: 2013 Firestorm FRS
um, op you should be banned for even mentioning this.
jkjk! |
04-10-2013, 03:51 PM | #11 |
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
I have both the Whiteout FR-S and Blizzard Pearl Prius. The FR-S (Subaru's Satin White Pearl) is more of a creamy white, and Blizzard Pearl is more brighter but has more Pearl Texture in sunlight. In cases of extreme sunlight, both cars look white with pearl flaking. The time I can really tell the difference is during the sunset when sunlight is not too extreme.
Look closely and you may be able to see how darker the FR-S is Last edited by Veloist; 04-10-2013 at 04:17 PM. |
04-10-2013, 05:02 PM | #12 | |
Drives: blue
I actually prefer the Prius pearl. I think it's gorgeous. All this time, i thought they were the same. But who here owns a white prius and a white frs to juxtapose and compare/contrast? @Veloist, Thanks! That really helps! |
04-10-2013, 06:16 PM | #13 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Edit: see the paint code chart here http://www.ft86club.com/forums/showthread.php?t=6519 |
04-10-2013, 06:20 PM | #14 |
Driver of FR-S 1467
Drives: 2013 scion frs 001467
Unless you look real close my philosophy is black is black and red is red. Changing the tint slightly won't affect my opinion on most cars n colors
Similar Threads | ||||
OEM Wheel Colors | brzadmir | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 02-28-2013 07:51 AM |
Rare colors? | be6sti | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 11-10-2012 05:07 PM |
It getting more colors, wich one would you have? | RaceR | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 06-04-2012 02:51 AM |
Colors | stalon320 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-03-2012 01:28 PM |
Help Choose FR-S Colors | Shin | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 11-16-2011 01:29 AM |
