Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
09-02-2013, 11:40 PM | #1 |
Drives: 2013 Asphalt FR-S 6MT
265/35/18 tires fitment
Hi all, I am planning to run 265/35/18 tires on my 18x9.5 +38 wheels, currently using coilovers
What kind of fender work is required to run this? Thanks |
09-03-2013, 12:00 AM | #2 |
Drives: on cruise control
none
09-03-2013, 12:09 AM | #3 |
09-03-2013, 06:37 AM | #4 |
The only thing that will be off is your speedometer. Everything should fit fine. After I installed my coilovers with 245/35's, I gained like 6 inches of clearance in the front from the 2mm clearance I had vs the stock spring.
09-03-2013, 10:48 AM | #5 |
Master Troll
Drives: 2013 BRZ Limited
Good info. I also plan to do some 18x9.5 with the same size tire. Is +38 offset ideal versus +40?
Sent from my XT1080 using Tapatalk 2 |
09-03-2013, 10:57 AM | #6 |
Drives: WR blue
Would like to know that too
09-03-2013, 12:22 PM | #7 |
Good to know, I'll be swapping my 245 with someone else's 265... will report back next week
09-03-2013, 12:36 PM | #8 |
Camber is your friend with this setup. We are running same specs, 18x9.5+38 with Hankook RS3 265/35/18. -3* camber up front and -2.5* out back with no fender modifications.
09-03-2013, 12:44 PM | #9 | |
Drives: 2013 Scion FRS
What are you dropped about? 1.5"?
09-03-2013, 12:53 PM | #10 | |
Master Troll
Did you have to add anything to adjust camber that much? Surely the factory setup can't be adjusted like that, right?
09-03-2013, 01:12 PM | #11 |
No idea how low over factory we are. We set up the car to race with a use able ride height. As far as camber goes we have camber plates and bolts up front. We have Cusco Lcas in the rear.
09-03-2013, 11:31 PM | #12 |
Thanks @FT-86 SpeedFactory you gave me the information that I needed!
Similar Threads | ||||
Fitment of Winter Tires on Stock Rims: X-Ice 3 215/55/17 | hyper4mance | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 10-22-2017 11:17 PM |
Borla UEL fitment | TheSlickOne17 | Engine, Exhaust, Transmission | 11 | 05-19-2013 01:18 PM |
fitment question | DanoFA20 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-16-2013 01:25 PM |
TIRES, TIRES, TIRES! @ Pure Automotive Performance | Pure Automotive | Wheels and Tires | 1 | 02-04-2013 02:32 PM |
