Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
10-07-2013, 05:22 PM | #1 |
Aloha!
Drives: Whiteout
Fuel gauge misreading actual fuel in tank.
I've filled up my frs and still the needle reads little above the 3/4 level...I've done the disconnect battery and it returned back to full....several months passed and here we go again, wtf?!
Sent from my iPad using Tapatalk HD |
10-07-2013, 06:29 PM | #2 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
take it to the dealer\
10-07-2013, 07:56 PM | #3 |
Drives: '13 Ultramarine
This happens with mine once in a while. I've noticed it only occurs when topping up the tank if it is already over 1/2 full. If I let it get below 1/2 a tank before filling, the gauge reads full. The first time this happened, I stopped at the next gas station a block up the road, and wondered why it wouldn't take any more fuel.
10-07-2013, 07:58 PM | #4 |
Drives: '13 BRZ in WRB--let's mod!!!
This just happened to me for the 1st time yesterday--must be an issue.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. |
10-07-2013, 08:02 PM | #5 | |
Love Boost!!!!!!!!
Sent from somewhere
10-07-2013, 08:12 PM | #6 |
10-07-2013, 08:24 PM | #7 |
I had a MX-5 that did this from time to time.
Did you continue to put gas in it after the pump "clicked off" ..?? Did it "right itself" after driven a few miles ..?? Can you correlate this phenomena with a particular gas pump .. ?? humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Clembo (10-07-2013) |
10-07-2013, 09:37 PM | #8 |
'Senior' Junior Member
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Both my MX-5 and my FR-S do the same thing. Just drive it and after you park it will read correctly next time you start it up. Saw an explanation somewhere but can't remember the exact reason, something to do with there being dual tanks connected together and how the sensor works. I never let my cars go below 1/2 tank so I get this often. I know there's nothing wrong so it doesn't bother me anymore.
"You'll never know if you don't try" - Shinroko Momose |
The Following User Says Thank You to Clembo For This Useful Post: | humfrz (10-07-2013) |
10-07-2013, 09:52 PM | #9 |
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
This has already been brought up. For most it was caused when filling up before the gauge was below half.
10-07-2013, 11:17 PM | #10 |
Drives: 13 Asphalt FRS AT
Recently happened to me as well after topping off at 3/4 tank. Worked fine after running down to 1/4 and filling up again. Freaked me out at first since I just had the pump and injectors upgraded.
Sent from my Nexus 7 using Tapatalk 2
10-07-2013, 11:25 PM | #11 |
Odd I never encountered this, and I never let my tank go below half. Had the frs since it's release last year. Knock on wood
Encity's Firestorm MT Car Journal:
http://www.ft86club.com/forums/showthread.php?p=252545 |
10-07-2013, 11:47 PM | #12 |
Old ecutek tunes did this when they were trying to get the lcd to display fuel remaining. Used car with an old tune?
Sent from a Motorola DynaTAC 8000X now Free |
10-08-2013, 12:27 AM | #13 |
This is a manufacture issue. I too have had problems with my fuel gauge misreading.
I was going to post a thread about it but I read a few threads that had covered the issue but not specifically.. Now that I have seen this I'd like to share. After about 6000 miles I started having fuel gauge issues. I like to note that I have always used premium grade fuel from the best location in town and I have never continued fueling after auto-stop. I take over obsessive care of my car and kept the area clean. That being said, the issue I have is when my tank gets even below 1/2 and lower, when I put fuel in, whether it be $10 worth or even $20 the gauge does not move up, yet continues to drop as I use more fuel. This results in driving around with the fuel light on and needle at it's lowest state even with plenty of gas left in the tank. The only remedy I have found to fix it, is if I pump completely full. Then when I start the car the needle climbs back to full. So if I don't fill the tank completely every time, the needle will only drop and never rise. This is frustrating but I am hesitant to take it in because I dread the thought of my car being taken apart. Although I have read about it, I have never tried the battery disconnect. Fuji heavy industries or not, I was hoping for Toyota reliability. |
The Following User Says Thank You to FRSupra For This Useful Post: | Scionshaun (10-08-2013) |
10-08-2013, 08:40 AM | #14 |
Drives: ‘13 FRS
Yup. Mine also. When I picked up my car, the sales people didn't know that it was a premium fuel car, which made me nervous. So I topped it up with 92 octane every other day for a week or two. The fuel gauge didn't like that, and my needle ran down as if I had been driving that first tank without top-ups. Now I only top-up when it's at 1/2 tank or less. And I've started using an ethanol free 90 octane from 76 as well. (Silences the crickets!)
The Following User Says Thank You to NWFRS For This Useful Post: | Scionshaun (10-08-2013) |
Similar Threads | ||||
Stock In-Tank Fuel Filter Degradation | sw20kosh | Engine, Exhaust, Transmission | 96 | 07-28-2014 03:36 AM |
AEM High Flow In-Tank Fuel Pump | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 04-13-2013 12:15 PM |
Actual experienced real world fuel mileage MPG? | R8 | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 07-24-2012 07:50 AM |
“saddle-shaped” fuel tank | ft86Fan | Engine, Exhaust, Transmission | 13 | 06-26-2012 04:22 AM |
