Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
View Poll Results: Best Lower Control Arms? | |||
Stance | 33 | 14.60% | |
Whiteline | 32 | 14.16% | |
Cusco | 51 | 22.57% | |
SPC | 34 | 15.04% | |
Megan Racing | 4 | 1.77% | |
GTSpec | 4 | 1.77% | |
ISC | 8 | 3.54% | |
DME | 1 | 0.44% | |
Agency Power | 1 | 0.44% | |
None of the above (post reply of other product) | 58 | 25.66% | |
Voters: 226. You may not vote on this poll |
10-21-2013, 11:05 AM | #2 |
Drives: '13 DGM BRZ Limited
I would think that depends on what you plan on doing. For example, just looking for something to get the job done, the SPC's are probably the best bang for your buck. If you want to slam the car, something like the Stance LCA's may suit you better. Then there are the Whiteline, Cusco, RacerX, etc. versions. I would suggest that whichever one you go with, try to get one that can be adjusted while on the car. It will make your life easier and not give the alignment tech a reason to pull their hair out.
I went with the newer SPC arms that adjust with a cam bolt on the hub connection and have been satisfied with them. They are just plain black and don't offer any bling, but suit my needs. |
10-21-2013, 11:08 AM | #3 | |
Regional Moderator
Drives: VADER 86
10-21-2013, 11:29 AM | #4 |
Drives: 2013 Scion FRS
I would have gone with whiteline if they were available when I was doing my suspension but they were not, so the next best one I found was RacerX.
They have a group buy going on now that puts it at a very reasonable price. They come black but for 35 bucks more you can have it powdercoated any color you want. Just my .02 but again its all on what you want to do.
10-21-2013, 11:43 AM | #5 | |
Drives: DGM BRZ
I went with the SPC's because they were affordable and got the job done. They don't offer a huge range of camber adjustability like the others but they work for my needs currently. Like the other member mentioned, I too would have gone with the Whitelines if they were available at the time. |
10-21-2013, 12:12 PM | #6 | |
The Cusco arms are a little more difficult to adjust because you have to remove the LCA to subframe bolt, pull the arm down, adjust, and then reconnect. Some have had luck with slim wrenches to make the adjustment, but not all alignment shops may have slim wrenches. While it's true that you should only have to adjust them once if you're not constantly playing with your ride height, they are still a pain to adjust if you have to disconnect/reconnect until you get the desired setting. At that point, it really comes down to how patient the alignment tech is. Get a good tech and they'll play with it until the get the exact settings you want. Get a bad tech that doesn't want to spend all day fiddling with it and you'll get something "close enough". What makes the alignment more of a PITA is that camber and toe affect one another so you adjust the camber, get it where you want and then you have to adjust toe and that may throw off the camber. With something that can be adjusted on the car, just put a wrench on the toe eccentric and another on the camber nut/eccentric and you can adjust both simultaneouly. |
10-22-2013, 12:11 AM | #7 |
Regional Moderator
Drives: VADER 86
Hmmm
10-22-2013, 12:49 AM | #8 |
Drives: 2013 Scion FR-S, Raven, Manual
Surprised you didn't include Racer X Fabrication on the list. I run their lower control arms with the heim joint ends and I love them. With the group buy going on right now I believe they are the best quality arms you can buy for the money.
The Following 3 Users Say Thank You to Zach3794 For This Useful Post: |
10-22-2013, 01:12 AM | #9 |
Drives: FRS(sold), AP2, R35, FJC, ED9
The cusco are a pita to adjust if your in a garage, not so bad if youre on an alignment rack. Just for reference my experience with them is about 1 degree of camber per turn of the rod end. 1 turn out will net you -1 degree of camber. At 1" drop -1.2 degree of camber is as less I could get and still get -1/16 toe in.
10-22-2013, 01:13 AM | #10 |
Drives: 86 ZN6
whiteline!
10-22-2013, 02:26 AM | #11 |
Drives: 2013 FRS, 2008 R32
For my needs, SPC.
Whitelines are beautiful but also expensive. If I was building a track car, whiteline all the way. However, SPC's seem pretty great thus far. |
10-22-2013, 02:45 AM | #12 |
Just a dude
Drives: Scion FR-S 2013
For what you are looking to do 100% stance is best option to get that low and have the benefit of added travel/stroke.
Now that said that's if coils you have actually benefit from that? Otherwise cusco, racerx, WL all seem to be too contenders.
10-22-2013, 02:45 AM | #13 |
racerx fabrication
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post: | Black Tire (01-27-2015) |
10-22-2013, 06:23 AM | #14 |
Drives: Raven FR-S
i went with stance because of the deal i got for them used. it really depends on what you're trying to do, if you want super crazy camber, stance will work. i was playing around with my camber for fun and had like -12 easily in the rear. granted i only set it to 2.5, but just saying the potential is there.
