Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-18-2013, 03:34 AM | #1 |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
POWER Mods for NA setup
i wanted to gain some knowledge. can you tell me what else i can do to get more power? No turbo, sc or spray please. also no e85 tune.
so far i have installed... light weight 17 inch rims seibon carbon hood (vented) (not much lighter) vis racing carbon trunk (maybe a pound lighter i could feel the difference) rear seat delete no spare tire ect... ralco light weight pulleys (set of 3) injen intake j2 cat back exhaust j2 downpipe agency power headers ecutek tune WHATS NEXT???? i was looking at a throttle controller. also the tranny mount and diff mount braces. |
11-18-2013, 03:36 AM | #2 |
Drives: GT86
Nothing.
The Following 2 Users Say Thank You to ft_sjo For This Useful Post: | BlueDubbinTDI (11-19-2013), enjoi23 (11-20-2013) |
11-18-2013, 03:41 AM | #3 | |
Drives: 2015 WRX
Also, 1lb difference in the weight of a trunk lid is statistically insignificant. The likelihood of you feeling the difference in the performance of your car over one pound is akin to saying you can feel the difference when you have to take a poop or not. You're only going faster when you have to poop because of the sense of urgency. |
The Following 3 Users Say Thank You to Malt For This Useful Post: |
11-18-2013, 04:23 AM | #4 |
Because compromise ®
Drives: Red Herring
Lithium ion battery. Remove sound system,interior trim and carpet. Carbon fibre one piece seats. Drain windscreen washer fluid. Don't eat.
The Following 11 Users Say Thank You to Captain Snooze For This Useful Post: | Bonburner (02-17-2016), Carwhisperer (11-19-2013), Chrisgalactic (10-11-2015), CK_Bladesmith (11-18-2013), enjoi23 (11-20-2013), fazm (11-20-2013), flippy (11-19-2013), Mike Brz (02-17-2016), PoWn3d_0704 (11-18-2013), Starkiller (11-18-2013), suaveflooder (11-18-2013) |
11-18-2013, 04:37 AM | #5 |
Add lightness!
Drives: 17' WRX
Get real headers.
The Following 15 Users Say Thank You to industrial For This Useful Post: | 20valvewynn83 (11-18-2013), ATL BRZ (11-21-2013), Boofneenee (11-18-2013), Calum (11-18-2013), Carwhisperer (11-19-2013), Celica00 (11-18-2013), CK_Bladesmith (11-18-2013), enjoi23 (11-20-2013), flippy (11-19-2013), FR-Sizzle (11-18-2013), GT86_PRAGUE (08-10-2015), Laika (11-20-2013), Mike Brz (02-17-2016), PoWn3d_0704 (11-18-2013), SirBrass (11-21-2013) |
11-18-2013, 04:48 AM | #6 |
Drives: 86
More things you could add:
- 4.4/4.55/4.7 final gear (stock is 4.1). Increase of ~8/11/14% torque to the wheels. - BBKs and coil overs (most are lighter than OEM). - Lightweight clutch/flywheel. Edit: AFAIK all the Seibon (wet) CF hoods are heavier than OEM.
11-18-2013, 05:57 AM | #7 |
Drives: AE86, 2x GT86, TE27
Under drive pulleys
Lighter flywheel Remove aircon Strip interior Do those 4 things. Car will be much faster than all the stuff you have done already. |
11-18-2013, 11:19 AM | #8 | |
Drives: car
Here's the Cusco short-ratio gears [ame="https://www.youtube.com/watch?v=PRXa4YGMbOA"]CUSCO update from SEMA 2013 including technical data for Toyota frs 86 and Subaru BRZ - YouTube[/ame] |
11-18-2013, 08:08 PM | #9 |
Guy on internet
Drives: Slowly
Final drive, close ratio gears, CF/aluminum drive shaft, motor/tranny mounts, REAL header.
I'm on the same boat, trying to get every once out of my NA set up. If I want FI I would've kept my WRX. |
The Following User Says Thank You to pche For This Useful Post: | Mike Brz (02-17-2016) |
11-18-2013, 08:32 PM | #10 |
Drives: Asphalt Scion FR-S
Remove your spleen, you don't need it.
11-18-2013, 08:41 PM | #11 |
Drives: Red Herring
LS V8 swap. Fits your criteria.
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post: |
11-18-2013, 08:54 PM | #12 |
Señor Member
For power rather than weight loss i would look at a different set of headers and intake. Then you could look at a larger TB. If money is no object HKS do a stroker kit and cams. Both are mild improvements and way expensive but they are out there. There was also a thread where Kelford was quoted having said they can make billet cams if you want.
For weight loss I would do a light flywheel and clutch combo. A small diameter multiplate clutch is also worth it if you can find one. Carbon drive shaft obviously. All depends how serious you are and how much you’re prepared to compromise on daily drivability.
1974 TA22 Celica
2013 86 GT |
The Following User Says Thank You to Turdinator For This Useful Post: | Mike Brz (02-17-2016) |
11-18-2013, 08:56 PM | #13 |
Seriously, at this point there is very little NA support from after market companies, most are just bolts on. Until cams, valvetrain and some other wizardry is developed, you'll be hard pressed to hit 200whp on just pump gas! |
The Following User Says Thank You to mswhong For This Useful Post: | Mike Brz (02-17-2016) |
11-18-2013, 09:33 PM | #14 | |
No rice, no life
Drives: 2013 Asphalt FR-S
OP: Honestly this engine can't do much NA without e85. It would be a better use of your money to just go turbo/SC if you're aiming for anything over 200whp. Otherwise you're spending a lot of money for very small gains. And don't go ripping out the interior and otherwise "adding lightness". Unless this will be a strict track car, you will come to hate it on the street. It's what happened to my old Porsche. The thing started to give me a headache every time I drove it because it was loud and uncomfortable. The BRZ isn't exactly a luxo-barge, but it's still perfectly comfy in stock form. |
Similar Threads | ||||
N/A power output potential as race setup? | rice_classic | Engine, Exhaust, Transmission | 67 | 12-17-2013 07:03 PM |
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 1 | 10-07-2013 09:40 PM |
More Power VS. other Performance Mods | Darryljr11 | Mid-Atlantic | 38 | 08-11-2013 08:53 PM |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
