Old 04-29-2014, 04:25 PM   #1
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
A Good Reason to Stay With Narrow 17s
http://www.roadandtrack.com/special-...transformation
Short version: Even with lighter-than-stock 18" wheels, the larger diameter puts more weight farther from the wheels' axis of rotation, making for slower acceleration and a lower top speed. And simply replacing the Prius-sourced stock tires with a set of stickier rubber (still in stock size) dropped lap times by 2.3 seconds. You don't need huge tires on this car- they reduce steering response and acceleration and top speed. Add 100 horsepower and the story may be different.
FlamingRectumSyndrome is offline   Reply With Quote
The Following 3 Users Say Thank You to FlamingRectumSyndrome For This Useful Post:
BRZ NA (04-29-2014), J. O'Grimm (04-29-2014), MokSpeed (04-29-2014)
Old 04-29-2014, 04:32 PM   #2
gramicci101
Off Topic
18's look better though.
And 265's look sexy. Have you seen @Jive Turkey's setup? Nice.
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
PEWPEW (04-29-2014), suaveflooder (04-29-2014), tinma (04-29-2014)
Old 04-29-2014, 04:33 PM   #3
sshole
This is new and exciting.
For an article posted on August 7, 2012.
sshole is offline   Reply With Quote
The Following 7 Users Say Thank You to sshole For This Useful Post:
ATL BRZ (04-30-2014), drewbot (04-29-2014), DriftEightSix (04-30-2014), gramicci101 (04-29-2014), hmong337 (04-30-2014), Pseud0logik (05-02-2014), suaveflooder (04-29-2014)
Old 04-29-2014, 04:53 PM   #4
Tainen
Drives: First SWP BRZ-L
Still a good point- looking through the wheel subforum, I'm seeing something like 70+% of all the threads are about 18x9.5" wheels to "get flush" and "concave."
I picked up a set of NT03+Ms in 17x7.5 for this reason and a few others- tire choices are much cheaper and plentiful, far less rotating mass, more money to spend on track days and other consumables, etc.
It's just the difference between people that want a nice looking wheel for aesthetic purposes and those that want to go as fast as possible around a track. 265s don't make you faster... in fact, they make you slower in a ton of cases, as others have shown in various threads. But do they look good? Yeah.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 04-29-2014, 05:13 PM   #5
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
I take it you're into stance? If so then this article won't really matter for you.
The point he's trying to get across is many go up in tire and wheel size to attempt to prevent the rear from swinging out so easily and believe this to make the car perform better. When in reality you achieve better results simply by switching to a better tire that is the same size and going up in tire and wheel size actually makes the car slower.
MokSpeed is offline   Reply With Quote
Old 04-29-2014, 05:20 PM   #6
Pete156
I like to eat!
Perhaps someone should qualify that this thread is all about an 86 with relatively stock power. Once you go FI, 215s do not make the car faster cause there is little or no grip at WOT.
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
Old 04-29-2014, 05:26 PM   #7
gramicci101
Off Topic
Haha, not at all! I was raising bullshit objections to a 2012 article, given that most people will never see a track and don't need the super best track tire recommendation. The ones that will see a track already know what range of tire sizes they should be looking for. And Jive Turkey's car isn't stance at all, it's actually very very nice.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 04-29-2014, 05:49 PM   #8
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
True, but if we're arguing practicality then oversized wheels on a lowered vehicle wouldn't really be ideal would it? Given that most people will see speed bumps and dips in the road it would be very very frustrating.
Old 04-29-2014, 06:23 PM   #9
BRZ NA
Drives: WR blue
Wonder what would happened when it's 18" but over all weight same as stock.(with tire)
BRZ NA is offline   Reply With Quote
Old 04-29-2014, 06:39 PM   #10
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i agree with all of this, the car feels peppier in 1-2nd with small 17's. i run a 17x7 in winter.
however, once you go beyond stock suspension and brakes and add a little bit of power, this car needs more tire, period.
further more, in a corner it is now able to carry much more speed vs stock suspension, so i need to compensate with a bigger tire, or else the 225's would just be over worked.
so the argument you're making is really about fun on the street in an otherwise stock car, then yes, you want smaller tires, but if you track it or push the car you'll see the need for more tire...
Jive Turkey is offline   Reply With Quote
Old 04-29-2014, 06:54 PM   #11
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
Isn't this common knowledge by now
Gilwith1l is offline   Reply With Quote
The Following 2 Users Say Thank You to Gilwith1l For This Useful Post:
bkblitzed (04-29-2014), OICU812 (04-30-2014)
Old 04-29-2014, 06:54 PM   #12
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
How much more tire, though?
I'm planning on going from 215's to 225's on 17x8. Still not enough for eventual super charging to below 300 whp?
^GT5 Replay Photo Mode^
Old 04-29-2014, 07:12 PM   #13
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I have 17x9 wheels for my BRZ, and those are my dancing shoes. 215 even on a better compound is not enough tire for autoX in my opinion.
In ST* class at least.
Old 04-29-2014, 07:57 PM   #14
SirBrass
SirBrass's Avatar
What about good old canyon carving and some very occassional track, with some ability to slip the back end on turn in (not drifting, just getting the nose pointed around a little faster)?
What are some good slippery narrow tires? PowderfaceTr. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 02-07-2015 12:14 AM
Orlando Area - Good hotel to stay with girlfriend? Anthony Southeast 15 04-04-2014 02:17 PM
Good deal? Or stay way nmullin11 Scion FR-S / Toyota 86 GT86 General Forum 10 12-14-2013 09:07 PM
FA20CLUB: GOOD REASON TO REMOVE YOUR TURBO KIT RIGHT AWAY.... FA20Club.com Forced Induction 27 06-21-2013 11:19 PM
Is 18 x 7 too narrow Abflug Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-12-2012 10:43 AM
