View Poll Results: Overlay VS Replacement
Overlay (slightly bigger than recess/hole and cannot fit inside) 24 21.62%
Replacement (direct replacement and fits perfectly inside the recess/hole) 87 78.38%
Voters: 111. You may not vote on this poll
Old 06-17-2014, 12:45 AM   #1
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Toyota "T" Formed Aluminum Steering Wheel Airbag Emblem - Overlay VS Replacement
Hi Fellow 86'ers!
Sorry I needed to start a new thread. But, I need to take a poll and cannot add/edit a poll into my existing thread.
I am in comms with Loden about this possible future Toyota "T" Formed-Aluminum Epoxy-Cleared emblem badge for the Scion FR-S in this thread:
http://www.ft86club.com/forums/showthread.php?t=67840
I need to take a poll to see which would sell more and which is more desired:
1. An "Overlay" - same exact size as the current Loden "86" emblem, which is slightly bigger than the recess/hole in the airbag; BUT, otherwise fits perfectly over the oem Scion badge as it was designed and intended to be used..as an "Overlay."
2. A direct "Replacement" - this would be the exact same size as the oem Scion badge(and slightly smaller than the current Loden "86" "overlay" emblem), which will fit perfectly inside the recess/hole in the airbag; BUT requires you to remove the oem Scion badge.
Thanks
fooddude is offline   Reply With Quote
Old 06-17-2014, 03:00 AM   #2
IgnitionGundam
IgnitionGundam's Avatar
Drives: Silver Ignition Gundam
Do it! its the last piece of my puzzle! Can't wait any longer!!
IgnitionGundam is offline   Reply With Quote
The Following User Says Thank You to IgnitionGundam For This Useful Post:
fooddude (06-17-2014)
Old 06-17-2014, 03:03 AM   #3
fooddude
If it was my my choice, I'd pick the "Replacement"
...but, it's Loden's decision.
We'll see what happens.
Old 06-17-2014, 10:08 AM   #4
tennisfreak
Drives: 2018 BMW M240i
Dont like the idea of emblem "pooching" out so I'd only go with a replacement.
The Following User Says Thank You to tennisfreak For This Useful Post:
Old 06-17-2014, 10:47 PM   #5
SupremeOrigin
Drives: 14' FRS, 90' Miata
I'm in
SupremeOrigin is offline   Reply With Quote
The Following User Says Thank You to SupremeOrigin For This Useful Post:
fooddude (06-18-2014)
Old 06-17-2014, 10:52 PM   #6
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Replacement FTW! I would prefer a genuine Toyota Emblem. The 86 emblem would suffice if that is what will be offered.
AVodka14 is offline   Reply With Quote
The Following User Says Thank You to AVodka14 For This Useful Post:
Old 06-17-2014, 11:32 PM   #7
kodyo
Drives: Scion FR-S
Is the emblem on the current airbag even replaceable? I've never taken it off but I assumed once off it could never be placed back on correctly. If that's not the case, replacement preferred. If you can't revert once done, I'd say overlay.
kodyo is offline   Reply With Quote
Old 06-18-2014, 01:47 AM   #8
IgnitionGundam
We are leaning towards more something like this right?
The Following 4 Users Say Thank You to IgnitionGundam For This Useful Post:
AVodka14 (06-18-2014), fooddude (06-18-2014), SkAsphalt (06-18-2014), trigger happy (06-18-2014)
Old 06-18-2014, 02:42 AM   #9
fooddude
Yowza!
EXACTLY!!!
Where are those from?? (probably exterior emblems huh?)
The Following User Says Thank You to fooddude For This Useful Post:
Old 06-18-2014, 11:11 AM   #10
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
That would be perfect
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
The Following User Says Thank You to trigger happy For This Useful Post:
Old 06-18-2014, 11:13 AM   #11
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
I need this in my life.
MokSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to MokSpeed For This Useful Post:
Old 06-18-2014, 11:17 AM   #12
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Interested
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
Old 06-18-2014, 11:57 AM   #13
cfordart
cfordart's Avatar
Drives: 2014 FR-S
These are actually 3-D and coated as opposed to the flat printed one from the Prius. Much better quality but don't know if Loden can do these...and the cost may be prohibitive in a small run.
This one looks like it would have to have the "hole" in the airbag cleared out to sit down inside the space.
But I'd much rather have this one if it was available. Second choice the flat printed version.
cfordart is offline   Reply With Quote
The Following User Says Thank You to cfordart For This Useful Post:
Old 06-18-2014, 02:02 PM   #14
IgnitionGundam
Originally Posted by fooddude View Post
Yowza!
EXACTLY!!!
I originally wanted these emblems for the outside of my car, but it doesn't come in the right size. I found them online (alibaba & ebay), but now I can't seem to find them there anymore?!
This is the only place I can find them.
http://www.aliexpress.com/item/Toyot...583166971.html
Anyone wanna verify the size for fitment?
Scion FR-S Airbag "86" Emblem Mockup/Replacement leicaboss Cosmetic Modification (Interior/Exterior/Lighting) 168 08-21-2014 09:57 AM
Toyota "T" Formed Aluminum Epoxy Steering Wheel Airbag Emblem Badge Interest List fooddude Cosmetic Modification (Interior/Exterior/Lighting) 22 06-18-2014 02:47 PM
Scion Steering Wheel Airbag Badge Emblem dimensions? fooddude Cosmetic Modification (Interior/Exterior/Lighting) 13 06-10-2014 08:51 PM
Scion steering wheel emblem replacement: any companies planning to make one? fooddude Cosmetic Modification (Interior/Exterior/Lighting) 8 05-13-2014 06:20 PM
Scion Emblem without the word "Scion" for steering wheel Airbag.. 86-tundra Cosmetic Modification (Interior/Exterior/Lighting) 2 01-18-2014 02:15 PM
