Old 09-04-2014, 08:39 AM   #1
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
High beams
I've done some poking around the forums, but haven't seen a topic for it. Has anyone installed high-beam bulbs that are much brighter than stock? I tend to use my high beams a lot more than my horn.
Meet Selina, my Asphalt FR-S MT6.
Like EightSixClub on FB, and follow us on Twitter!
DjDATZ is offline   Reply With Quote
Old 09-04-2014, 08:47 AM   #2
Chimera
Drives: FRS
So are you asking for laser beams for your car to use against others? J/k. Anyways there are topics on this. If you modify the base of some other bulb it will do what your asking here. I forget the details but Google is your friend.
Old 09-04-2014, 02:16 PM   #3
DjDATZ
DjDATZ's Avatar
Okay, I poked around here seeing if someone had done it for out cars, but didn't see a thread specific to it. To the Googles!
Old 09-04-2014, 02:24 PM   #4
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Bi-Xenon?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-05-2014, 05:08 PM   #5
Wizardhat
Wizardhat's Avatar
Drives: 2013 FRS
If you really want bright high beams I recommend getting a HID kit and some aftermarket headlights to install them in. That is what I have and when I use the high beams they are so bright that the light from them reflecting off of the highway signs is almost blinding. It is like having twin suns in your headlights. If you go that route I strongly recommend getting some Lamin-x headlight protection film as the aftermarket unit's outside lens is vulnerable to the clear coat/UV coating peeling off or cracking from sun exposure. The film will keep them looking like new and from sun damage.
Wizardhat is offline   Reply With Quote
Old 09-05-2014, 06:06 PM   #6
sato
sato's Avatar
Drives: Dodge Patitas
If the FR-S/BRZ/GT86 uses 9005 bulbs for High Beams, then look no further than 9011 HIR bulbs. I know some manufacturers use them as OEM, and they are bright as f@ck. My headlamps use them... its a very awesome upgrade (look it up in the interwebs).
They only need a small mod to fit the 9005 housing.
The Following User Says Thank You to sato For This Useful Post:
Poodles (09-06-2014)
Old 09-09-2014, 05:14 PM   #7
Diode Dynamics
Diode Dynamics's Avatar
You could give our new XML2 LED's a try:
They produce 1,420 lumens
Nick C.
John C.
Diode Dynamics
Old 09-09-2014, 07:17 PM   #8
KI_ZN6
KI_ZN6's Avatar
We would recommend running an HID kit with a relay harness for the high beams if you are looking an improvement over the factory halogen bulbs.
KI_ZN6 is offline   Reply With Quote
Old 09-10-2014, 07:49 PM   #9
Poodles
Drives: 2015 Series.Blue
This. The bulbs are a bit expensive, but they're damn close to the brightness of HID.
HID isn't ideal for high beams because:
- HID life is significantly shortened if they're used for short intervals.
- HID's take time to warm up to output full brightness, leaving you without enough light for safe driving. There's a reason not a single OEM uses HID high beams that aren't a bi-xenon low beam.
Those LED's are interesting, but by the numbers they're lower brightness than stock (9005 bulb puts out 1700 lumens)
The Following User Says Thank You to Poodles For This Useful Post:
sato (11-03-2014)
Are high beams functional with LED DRL foglight bezel speedy racer Cosmetic Modification (Interior/Exterior/Lighting) 14 02-19-2014 09:04 PM
Dealer disabled DRLs = no high beams? Moshpit37 Issues | Warranty | Recalls / TSB 9 03-17-2013 02:15 AM
High Beams DC-FRS Cosmetic Modification (Interior/Exterior/Lighting) 13 01-12-2013 10:44 PM
High beams?!?! gmanculb Cosmetic Modification (Interior/Exterior/Lighting) 12 10-02-2012 04:51 PM
Dealer Killed my High Beams travace Issues | Warranty | Recalls / TSB 9 09-26-2012 12:27 PM
