Old 06-05-2012, 03:05 PM   #1
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Official Component Weights & Weight Reduction Thread
Hi Guys,
I'd like to start an official weight reduction thread. I put it in this section because I figured most people interested in weight reduction were going to be those tracking their car. If the mods deem it more appropriate elsewhere, by all means please move it.
I'd like to break it up by vehicle area, and hopefully come back and consolidate the data occasionally so it's all in one place. I've broken it up along the same lines as the forum is segmented. I'm thinking we can collect all OEM data here, as well as weights for aftermarket parts. That way people can quickly reference it to make decisions when making modifications, without having to dig all over the place in separate areas of the forum.
I'll start it off with some data we've gathered on the OEM components. I have more on the way as we pull our project car BRZ apart. I took all weights on one of our postal scales, and have included photo validation where possible. I'd encourage everyone else to do the same to prevent discrepancies and arguments. Let me know what you guys think. Thanks.
Complete Car
OEM BRZ Premium 6MT, full tank of gas, as delivered from dealership= 2,750 lbs.
Wheels/Tires
OEM 17" wheel & tire combo= 41.4 lbs.
OEM Lug nuts (5 pieces, or one wheel set)= 0.2 lbs.
Brakes
OEM front Brake pads= 1.8 lbs.
OEM front brake dust shield and three bolts= 0.4 lbs.
OEM front brake disc= 17.0 lbs.
OEM front brake caliper bracket= 3.8 lbs.
OEM Front Brake Caliper= 7.8 lbs.
OEM Rear brake caliper= 2.8 lbs.
OEM rear brake caliper bracket= 3.0 lbs.
OEM Rear brake disc= 13.2 lbs.
OEM rear brake pads= 0.8 lbs.
Suspension and Chassis
Engine, Exhaust, Drivetrain
Other under hood
OEM battery= 29.6 lbs.
OEM battery tie-down= 0.4 lbs.
Super B 10P Lithium-Ion Battery= 3.9 lbs.
Interior
Driver Seat= 43.6 lbs.
Passenger Seat= 39.2 lbs.
Rear seat bases (2)= 6.2 lbs.
Rear seat back (1-piece)= 15.0 lbs.
Rear side plastic panels= 3.0 lbs. (driver and passenger are same)
Front floor mat= 1.2 lbs.
Rear floor mat= 0.4 lbs.
Cup holder insert= 0.4 lbs.
B-pillar plastic (covers seat belt attachment)= 0.4 lbs.
Exterior, body panels, lighting
OEM Front plastic fender liner= 1.2 lbs.
OEM front driving LED lights= 0.2 lbs.
Miscellaneous
OEM spare tire with liner foam= 25.8 lbs.
OEM trunk tools, jack, tow hook= 5.8 lbs.
OEM trunk rug/liner mat= 2.4 lbs.
Owner's Manual= 2.8 lbs.
OEM front license plate bracket and hardware= 0.4 lbs.
JRitt is offline   Reply With Quote
The Following 206 Users Say Thank You to JRitt For This Useful Post:
200hp/tonne (05-29-2013), 37 (08-27-2013), 448hpsti (09-29-2013), 70NYD (06-15-2012), 8686 (08-09-2014), aagun (08-22-2014), acj47 (12-22-2014), adamg (03-18-2015), adprokid (06-14-2012), airmanmurphy02 (10-23-2013), akahenry (05-29-2015), Akai (06-18-2012), Ako (06-15-2012), Alfalasy (04-30-2014), Anthony (07-23-2013), Anthonytpt (03-18-2013), Asterisked Accolade (06-15-2012), AtlasMick (04-29-2014), avusblue (07-09-2012), axelo (07-19-2015), BadCompany235 (06-18-2012), BAE (07-21-2012), BioRage (06-15-2012), Black Tire (02-09-2013), BlaineWasHere (07-10-2012), Blokatos (04-30-2016), Bonburner (07-18-2012), Bruninho8 (06-15-2012), Bullnettles (05-28-2013), Carban (10-03-2012), CBR600RR (08-07-2012), cbryant514 (08-07-2017), Chenslee (06-15-2012), Choco (02-23-2015), civicdrivr (06-15-2012), cmspooner (06-17-2012), cobrabyte (07-13-2012), colHolm (07-05-2013), createluck (12-12-2013), CSG Mike (08-14-2012), CxG (09-20-2018), CY86 (11-13-2018), DAEMANO (07-31-2013), DantKR (06-14-2012), Dave-ROR (06-05-2012), davey90 (06-20-2012), Deslock (06-17-2012), Dimman (06-05-2012), disgruntld (01-31-2013), DocWalt (04-18-2022), dphan (02-14-2014), Drift&Drag (04-21-2014), driver01 (06-15-2012), Efferalgan (04-12-2014), EJ. (03-04-2016), ESBjiujitsu (06-05-2012), exmayol (06-14-2012), F-Bomb (06-15-2012), Fascist Fish (06-05-2012), Fastbrew (04-27-2015), FatFree (01-17-2017), fc3s_johnny (07-20-2013), finch1750 (07-08-2013), Fly Guy (06-09-2012), FR-S/GT-86 (06-15-2012), Franisco (06-19-2012), FRSBRZGT86FAN (10-25-2015), FrX (06-11-2012), fstlane (05-10-2014), FT-86 SpeedFactory (02-03-2013), FT86Z (12-08-2015), FT_86_SM_GP (08-03-2015), Gaiakai (06-16-2012), Ganthrithor (03-23-2013), Getagrip (06-16-2012), GhostOp86 (03-30-2015), grst1 (06-14-2012), GT86drifter (09-03-2013), GTB/ZR-1 (12-18-2012), gtengr (05-25-2018), Guff (08-13-2012), Hamza (02-28-2021), Hawk77FT (05-09-2013), IBill4You (07-16-2015), ill86 (07-04-2012), itdansharpe (07-18-2014), JACK 8URT0N (06-15-2012), Jayde (06-14-2012), Jayp (06-16-2012), jedibow (06-21-2012), jehu (08-14-2012), jliongh (09-24-2016), JohnATL (09-18-2012), jonnyozero3 (02-27-2013), juliog (03-30-2013), JustBoostin (10-16-2013), kavanagh (12-20-2013), Kristian (09-24-2016), Kyon (06-15-2012), lazyluka (02-18-2014), LeeMaster (03-25-2013), limitedblkwrx (11-11-2014), LivingLegend (06-14-2012), Loki2x (12-26-2012), Lost (07-01-2012), MannyO (01-12-2014), ManOfStiehl (06-15-2012), MarkRacerX (06-05-2012), MattR (06-15-2012), melia (12-23-2013), Metallic BRZ (06-06-2012), mike2100 (08-10-2012), MileMonger (01-29-2017), Mini Cooper S (08-25-2014), miodculae (03-17-2013), mit_peid (12-10-2012), MoarGeesPlease (06-14-2012), Monkey_Boy (06-14-2012), Mr. (06-14-2013), Mr.Impreza (10-03-2015), MSTiFK8R (08-01-2012), Nardi330 (06-16-2012), Nasty Sausage (06-10-2014), NJ10 (05-20-2015), Noble713 (06-15-2012), Obja (09-19-2012), old greg (06-05-2012), Pascal_TTH (01-20-2013), peazs (06-15-2012), Pekingduck (03-30-2013), pgranberg11 (10-08-2018), phm14 (06-10-2012), Pointmutation (02-15-2016), PoorMansRacing (12-05-2013), ProjectD (03-28-2013), Pseud0logik (09-04-2014), pyro530 (06-15-2012), qoncept (07-22-2013), Quantum (06-15-2012), R2RO (02-20-2013), R3NIK (03-01-2015), Racecomp Engineering (06-15-2012), RaceR (06-05-2012), ranisron (02-26-2013), raven1231 (07-29-2014), Reflex (06-19-2012), RehabJeff86 (11-30-2013), RobStar86 (06-16-2012), RWD_only (06-15-2012), s0sl0w (05-04-2015), Satu23 (06-16-2012), sc0urge (12-29-2013), Sccabrz192 (06-05-2012), ScionFR-J (06-11-2013), Scooby (06-05-2012), Scooby South (06-05-2012), Shankenstein (02-01-2013), ShoNUFF (12-27-2012), Sigh-on-Rice (05-28-2013), silverbullet (03-21-2013), Simpleviet (02-26-2013), SirBrass (03-03-2014), sirus (06-16-2012), Slartibartfast (06-15-2012), smg1138 (10-26-2017), Snoopyalien24 (06-15-2012), solidONE (03-22-2013), Sonex51 (06-16-2012), SP86 (04-04-2014), sparks (06-06-2012), SpeedR (01-28-2014), staples323 (12-01-2020), StarsGarrador (09-13-2012), Staticfrost (06-11-2012), Sterling Doc (09-26-2013), stevo_12v (08-26-2013), supra2nv (02-27-2014), Tama-Y (06-10-2013), tbwoodlee (07-24-2013), Thobjo (04-14-2015), tonylop33 (07-27-2013), TorontoNat (12-12-2017), Toyota GT 86 (02-04-2013), track_warrior (08-17-2012), TRD_07 (06-18-2012), tripjammer (06-14-2012), Tristor (05-11-2018), TSY (03-09-2013), Turbowned (06-15-2012), Tye300 (08-22-2014), Tylub (01-28-2014), ultra (06-19-2012), UncleFester (06-21-2012), VacantSky (01-21-2014), Valentino (10-11-2015), veewonwon (06-15-2012), Verge (06-14-2012), Wasabi (02-14-2013), WatchmaN (01-12-2013), Wepeel (03-30-2013), WingsofWar (06-05-2012), WRB-DZA-BRZ (06-15-2012), yayforaddison (06-14-2012), Z.Tune (06-18-2012), ZetaVI (06-14-2012), zoomzoomers (09-13-2012)
Old 06-05-2012, 03:20 PM   #2
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
I love you! lol. Ill be spending a lot of time here. i plan on ditching a lot of the fat once i purchase mine!!!! great job keep it coming!!!!!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 06-05-2012, 04:08 PM   #3
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Shit, man. You're not going to have much of a car left at this rate.
old greg is offline   Reply With Quote
Old 06-05-2012, 04:21 PM   #4
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Excellent....Great WORK....with the Stock Wheel/tire setup @ 41.x lbs...my 17x9 with 245's ..are 45lbs...I can live with that..
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
ESBjiujitsu (06-10-2012)
Old 06-09-2012, 08:27 AM   #5
Scooby South
Conedancer
I will be able to add to this considerably myself today... as there will be some things I will be doing to the car...
Bill
Old 06-09-2012, 10:18 AM   #6
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Great thread. We found similar results. Removing jack, tools, spare tire, rear seat back, rear seat bases, rear trunk mat & pass floor mat dropped 70 lbs.
Boosted2.0 is offline   Reply With Quote
Old 06-10-2012, 12:02 AM   #7
Scooby South
Conedancer
The Good news is ... mine weighs the same as yours...
Old 06-10-2012, 12:05 AM   #8
Scooby South
Conedancer
mine on the scales weight 2669 with less than a quarter tank of gas... no trunk Junk...and my new wheels/tire combo..
Bill
Old 06-11-2012, 04:42 AM   #9
crimespree
Drives: 86
good work,
light weight battery and spare removal are an easy practical start for an almost 30kg drop. half way to a noticeable gain, i.e. a passenger..
crimespree is offline   Reply With Quote
Old 06-11-2012, 05:04 AM   #10
Ashe
Drives: Scion xA
The below Comment is just an observation, not directed towards any person or groups of persons.
I've always found it humorous when you get someone worried about shaving every last ounce from a vehicle but they don't have any issue with ordering the Super Sized fries with an Extra large shake when they go out for their mid-morning snack.
Point of example: Back when I first got into AutoX'ing my xA there was a guy who swapped a bunch of smaller items (Like the stock stereo) to save about 4 LBS. He proceeded to tell us that if we didn't do likewise we were putting ourselves at a disadvantage because our vehicles weighed more. Meanwhile this guy must have weighed at least 250 lbs and ate like a ravenous goat.
My point being yes, weight savings is a good thing, but you have to look at it as a % of the vehicles running weight with driver. If you weigh 250 lbs removing 4lbs is not going to have as much of an effect as the same weight reduction for someone who weighs 150 lbs. Or to quote someone else in that thread "You would shave more weight by going on a diet than getting rid of your Stock Headunit"
Anyways crimespree's comment about a "noticeable gain" made me remember that thread.
Ashe is offline   Reply With Quote
The Following 7 Users Say Thank You to Ashe For This Useful Post:
Dadhawk (06-15-2012), FT86Z (12-08-2015), GPhilly (02-22-2022), juliog (03-30-2014), mgarcia707 (08-15-2018), Nasty Sausage (06-10-2014), PWBRZ (04-01-2015)
Old 06-11-2012, 08:33 AM   #11
JRitt
JRitt's Avatar
Good to verify our scale is reading at least somewhat properly!
Nice. Definitely post up all your specifics. Thanks!
good work,
We dropped 25 lbs. with our lightweight lithium-ion battery. We're finishing up a custom mount for it now. I'll add a pic and weight to my pics above. Race buckets are going to be another very nice reduction. I weighed an old Sparco Roadster seat that I had in my Z06...weighed in at 16 lbs. for the fiberglass version. We're making some custom lightweight aluminum seat rails that will only be a few pounds. Overall, a 20lb. drop in seat weight (per side) seems likely...so that's another 40 lbs. that can be shed.
It shouldn't be a big problem to get down into the 2550 lbs. range without ripping the car to shreds. That's about what my '98 Integra Type R weighed, and that car had very similar HP. These cars are going to be very lively at that fighting weight, even on a stock (and reliable) engine. Therein lies the beauty. I keep telling myself that this is going to be the RWD Type R I always wanted, or what I wish my NA Miata was...a particularly nice balance of power and weight.
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing
www.essexparts.com
The Following 5 Users Say Thank You to JRitt For This Useful Post:
jliongh (09-24-2016), Roadliner (04-16-2014), stevo_12v (07-28-2013), tripjammer (06-14-2012), Tristor (07-30-2018), ultra (06-19-2012)
Old 06-12-2012, 09:58 PM   #12
crow
Drives: fr-s
big props to JRitt for this amazing thread, i can see the parts and proof of the weight claims, really a master piece of information if you take your 2751lbs number for a stock full tank of gas you can achieve 2550 or lower pretty easily and have a blast with it at that weight this really has solidified my desicion on getting this car i'm eagerly waiting from the call from my local dealer to pick it up i can't wait...
i know this car was no designed to drag and I actually don't visit the drag strip much, but i can see how i can have a good night with some decent times at one with just some simple weight reduction and just run with 1/4 tank of gas and not even have any engine modifications
crow is offline   Reply With Quote
Old 06-14-2012, 07:41 PM   #13
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Amazing. Made it a whole lot easier for the rest of the guys on forum.
Old 06-14-2012, 08:08 PM   #14
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Good work!!
SUB-FT86 is offline   Reply With Quote
diet, heavy, light, reduction, weight
So what is the official weight? brillo Scion FR-S / Toyota 86 GT86 General Forum 76 05-03-2020 05:11 PM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 05:09 PM
2012 Geneva - Toyota GT86 in Black, Blue, White, Orange. Official weight & 0-60 Shown Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 124 05-28-2012 12:20 PM
Official JDM BRZ weight and MPG ayau BRZ First-Gen (2012+) -- General Topics 50 02-08-2012 02:04 AM
