01-23-2015, 01:40 AM | #1 |
Drives: 2014 Scion FRS MT
2JZ Swap Kit?
I know its possible to purchase an LS swap kit which includes harness, mounts, driveshaft ect. but is there a 2JZ swap kit that you can purchase?
01-23-2015, 07:44 AM | #2 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
No swap kit, but you can buy Xcessive mounts for the motor. Non-VVTI, front sump only.
The Following 2 Users Say Thank You to slicktop For This Useful Post: | Guff (09-12-2015), SomeoneWhoIsntMe (01-23-2015) |
01-23-2015, 08:08 AM | #3 |
Drives: 2013 Subaru BRZ
Acutally xcessive makes mounts for vvti 1jz and 2jz blocks as well.
Source: own a set of mounts for my vvti 1jz But yeah you kind of have to piece everything together and do the wiring yourself at this point
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
01-23-2015, 09:41 AM | #4 |
do you know if the stock transmission would mount on?
01-23-2015, 09:48 AM | #5 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I hope you're not serious...
For real, if you're asking such noob questions about this swap, this swap is not for you or you've got atleast $25,000 to throw at somebody to do it for you.
The Following 10 Users Say Thank You to hmong337 For This Useful Post: | Chrisgalactic (03-23-2016), flippy (11-24-2015), Manji (01-23-2015), Pure Automotive (01-23-2015), Shit Luck (01-23-2015), SomeoneWhoIsntMe (01-23-2015), Spartarus (09-10-2015), STV3 (01-23-2015), Tcoat (01-29-2015), woode (01-24-2015) |
01-23-2015, 12:16 PM | #6 |
Yeah, that's the thing. There's been a bunch of these swaps done for formula D but there's not a ton of info publicly available on those cars. There's only a handful of people on forums and maybe one or two shops in the process of doing this swap, so there's NOBODY to hold your hand. Unless you're comfortable figuring everything out for yourself, don't attempt this swap.
The Following 2 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post: | Pure Automotive (01-23-2015), Tcoat (01-29-2015) |
01-23-2015, 12:50 PM | #7 |
Emperor JDM
Funny thing. OP just sent me a pm cussing me out ahaha.
The Following 10 Users Say Thank You to hmong337 For This Useful Post: | cdrazic93 (09-11-2015), Chrisgalactic (03-23-2016), fika84 (09-10-2015), flippy (11-24-2015), GotBRZ1691 (01-23-2015), IloveBaldEagles (01-28-2015), Paewrblue (01-25-2015), SomeoneWhoIsntMe (01-23-2015), Tcoat (01-29-2015), woode (01-24-2015) |
01-23-2015, 07:42 PM | #8 |
Drives: 2013 Scion FRS
Thug life
01-23-2015, 07:54 PM | #9 |
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
An engine swap is not a bolt on kiddies.
01-24-2015, 10:56 AM | #10 |
Drives: 85 corolla gts
If you are looking to do a swap like this a lot has to be taken into consideration. Mounts are available, making the trans mount bracket is easy. Now you have to sort out wiring, yes there is an engine harness available for the swap but to do the swap properly there is still a considerable amount of work in that department that needs to be addressed. You will also want to look at your heating and cooling system, the heater core hoses will pose a small but workable issue. In a race car things like heat are not worried about, it gets hot in a race car anyways. Also you will want to look into a proper radiator. Do some digging for other platforms this engine is used in and look at the cooling system issues. Quality fans will be a must, as well as a properly sized radiator. I would also spend some time working on how the airflow enters the radiator area and make sure it goes were it needs to. Now that you have those things sorted you need to look at properly fueling this thing. A typical drop in pump will only support stock injectors. Why go through the trouble of this swap to deal with that limitation. So you will need to factor in a proper fuel system. I could continue on with this list for quite a while. If you are attempting this swap things you need, to be able to do, weld and access to metal working tools, comfortably work with an automotive 12v electrical system and be able to properly read a wiring diagram, good understanding of automotive repair work, ability to properly plumb a fuel system and cooling system, ect.... I will not say this is not a doable swap, as it is completely doable but I will say it is not for the feint of heart.
01-24-2015, 11:09 AM | #11 |
Dismember
Drives: 2013 Red Scion FR-S
In b4 photo of rappers in engine compartment.
The Following 5 Users Say Thank You to EAGLE5 For This Useful Post: | civicdrivr (02-09-2015), Dream20b (10-26-2015), flippy (11-24-2015), PHLonomenal (01-25-2015), Tcoat (01-29-2015) |
01-24-2015, 02:48 PM | #12 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
South of 10k still, will post my cranking/driving videos and final bay shots in about 2-3 weeks. I don't post anything current.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
The Following 4 Users Say Thank You to OmarGC For This Useful Post: |
01-28-2015, 04:05 PM | #13 |
Nice project... Keep it going
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
01-29-2015, 12:18 PM | #14 |
Drives: 2013 FR-S whiteout
If I swap in a 2JZ, can I use my Borla UEL's?
Similar Threads | ||||
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
AT swap to MT | CodyFRS | Engine, Exhaust, Transmission | 25 | 10-30-2013 10:39 PM |
Looking for an STi Swap | Doug@WGP | NY / NJ / CT / PA | 31 | 11-27-2012 12:54 AM |
2UR-GSE Swap | czar07 | Engine Swaps | 9 | 08-29-2012 01:43 PM |
Should I swap? | michaelahess | BRZ First-Gen (2012+) -- General Topics | 8 | 06-12-2012 07:32 PM |
