Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-24-2015, 02:21 PM | #1 |
Toyota Techstream Confusion
It’s been well known for a few years now that the Toyota Techstream software exists and allows both FR-S and BRZ owners to modify some settings on their ECU. But after recently purchasing one and using it, I read through some of the older posts and noticed that there was a lot of confusion about Lite version vs Full version, being able to reprogram or not, and weather you can or can’t reprogram your TPMS ID’s. So ultimately, I’d like to go ahead and clear up what confusion might still exist with this software.
Here are some great links to venture into if you never heard of the software before. http://www.ft86club.com/forums/showthread.php?t=34502 http://www.ft86club.com/forums/showt...ht=tech+stream To recap what again, most of you already know. Toyota Techstream is software released by Toyota that lets you modify certain settings on your vehicle. It works for both FR-S and BRZ cars. I believe that this is due to the fact that the ECU for both cars was made by Toyota. I can only guess this but my suspicion leads me to believe it considering the BRZ has the exact same lock and unlock chime as every other Toyota out there and that it’s also 100% compatible with the Toyota software. Most users of this forum would access this software by wondering onto eBay and purchasing a cheap Chinese knock-off of the cable used by Techstream. This cable is usually bundled with a version of the software, although there’s a good chance that you will find a more updated version on Torrent sites. Here is where gets is confusing for some. In order to use the software with Chinese knock-off cable, you have to edit an ini file after install. The file is named “IT3System.ini” and it resides in the “Program Files\Toyota Diagnostics\Techstream\Env\” directory. The specific line of that file you have to edit is “TISFunction = 0”. Essentially what you are doing is changing the value from a 1 to a 0. This disables the TIS Function. But what is the TIS function? Toyota Techstream is sold in two “flavors”. Full Version: The first is the Full TIS Techstream package which is essentially Toyota selling you a Laptop with the Techstream software preloaded and a special cable. Lite Version: The other flavor is Techstream Lite. Techstream Lite is where you supply your own laptop and buy their special cable, and software, and you’re good to go. Their cable is very expensive, that’s why most users here would just have gone on eBay to buy it instead, essentially getting Techstream Lite to function on their computer for way less than the official route. So getting back to the confusion about the Full version vs. the Lite version. Well in the end, there’s essentially no difference between the two except one is a laptop package, and the other is a “bring your own laptop” package. That, and also that the Lite version doesn’t support vehicles before 1989. Last time I checked, most of us could care less about that short coming considering all our vehicles were made well after that. I’ve attached a table for reference if you would like to see the actual differences compared between both Full and Lite versions of Techstream. What is ultimately means is that you can do everything you wanted to do with Techstream using the Lite version. So anyone who argues and says that the Lite version will only let you view info, is fortunately wrong. As for reprogramming TPMS IDs, it seems that the Toyota software has every intention to allow you to do this. But from what I can gather online, its just not possible. The only reason I can think for this is the knock-off cable doesn’t support this feature. If anyone else can confirm this that would be great. I hope this information was useful to some of you, and if you’d like me to try something with the software that wasn’t done before, let me know and I’ll see what I can do. |
02-26-2015, 09:48 AM | #2 |
Drives: 2014 BRZ, 2008 Impreza
ill try this later. i tried installing it before and i think the driver was not working right but when my friend tried it on his laptop it worked.
02-26-2015, 10:41 AM | #3 |
Drives: 2013 GBS BRZ Limited
@geruta (for some reason cannot 'quote' your post) -
"Most users of this forum would access this software by wondering onto eBay and purchasing a cheap Chinese knock-off of the cable used by Techstream. This cable is usually bundled with a version of the software, although there’s a good chance that you will find a more updated version on Torrent sites." If you get a disk with techstream from ANY purchase on ebay DO NOT PUT IT IN YOUR COMPUTER!!! Shred/Destroy the disk immediately. The one I got with my ELM327 was filled with Malware, viruses, & trojans. |
The Following User Says Thank You to stugray For This Useful Post: | FRSBRZGT86FAN (02-27-2015) |
02-26-2015, 11:53 PM | #4 |
Drives: fire storm frs 6mt
used a master techs techstream today, didnt mess with it because its not mine. just read some codes and such to see what was wrong.
02-27-2015, 12:27 AM | #5 | |
I have two elm 327 bluetooth units personally. Bear in mind I am a computer savvy person. One off amazon (BAFX unit) the other off ebay (one of those slim blue units). Both came with the exact same suspicious looking and I mean exactly the same each with a little panda logo on them. I sand boxed my CD drive and ran them to see why all the amazon reviewers complained about the software, and scanned the drives both CDs had an instance of a PUP.Trojan and Win32.Cryptor essentially designed to steal data and slowdown your computer. Honestly the software they are "including" might be trying to be some sort of interface for reading the codes and such but personally I use Carista on my phone for something as simple as that and adjusting the DRLS and stuff and wouldn't need something as stupid as an included software . But for Tech Stream to get them to work unless its a usb elm 327 you shouldn't need drivers as long as you have a laptop with bluetooth module and such: http://www.iobd2.org/install-elm327-...anner-windows/ http://www.totalcardiagnostics.com/s...ner-on-windows
02-28-2015, 11:04 AM | #6 |
For those of you concerned with malware on the eBay discs, just download off torrentz. Personally, I used the disc supplied with the cable off ebay and cannot attest to any malware nonsense.
My life's work is with computers, not cars. I just work on them for the fun of it. If you've ever downloaded any applications off the net, know that anti-virus/anti-spyware/anti-malware applications will report that many of times, executable applications are malicious or trying to corrupt/steal your data, etc, etc. You have to understand how an AV program scans an executable and determines if it is malicious or not prior to it even opening. It uses "signatures" to track an application. AV vendors cant possibly run and understand every .exe in exsistance and build a completely full-proof database against it. Honestly, in my experience, AV doesn't work. Its effort to try and alert you to potentially malicious software is a shot in the dark at best, just a complete guess. Ive been running anti-virus free for years, because I know what and what not to get into or download. In short, the disc worked fine. But again, if you are concerned, just download off of torentz. And as far as AV in concerned, the best anti-virus is common sense. |
The Following User Says Thank You to geruta For This Useful Post: | stugray (02-28-2015) |
02-28-2015, 01:03 PM | #7 | |
If you think about it, it is a perfect way to spread viruses/trojans - sell a product (globally) cheaper than the competition (even if it is at a loss), then make your $$ of off selling stolen information from the 10% that get infected. OH - And the "just download off torrentz" I have also gotten my fair share of viruses from downloading illegal software from torrent sites. I even believe that companies like Autodesk or Photoshop spread infected versions of their software on the torrent sites to punish those that would attempt to pirate their software. |
01-15-2016, 01:44 AM | #8 |
Drives: 2008 FT86 GTS
I had the known-off techstream cable mini vci. The sellers has released the new Ver. 10.30.029, software on mega.co.nz without Trojaner http://blog.obd365.com/2016/01/14/to...free-download/
The Following User Says Thank You to Liliflower For This Useful Post: | zc06_kisstherain (02-24-2016) |
01-16-2016, 09:03 PM | #9 | |
Drives: 13 FRS Satin
01-16-2016, 10:18 PM | #10 | |
Already have a cable for tech stream separately
02-24-2016, 05:04 PM | #11 |
Drives: FRawSome Hot Lava
Does anyone in Sacramento North CA area or Bay Aria have TechStream? I just need to silence the passenger seat belt buzzer. Can anyone help? Let me know, please!
02-24-2016, 05:07 PM | #12 |
Drives: Whiteout FRS
You can actually go to Toyota dealership and have them disable it.
04-06-2016, 10:36 AM | #13 | |
Made the sound of locking car more loud (with 3 pushed on remote lock button car makes 2 loud buzzes and one horn beep). Changed to open trunk with 2 quick clicks on remote. Silenced the front occupant seat alarm (decided not to silence driver side). DRL decided not to turn off - but turned it off on Camry. On Camry change the settings of open/close doors - now with long push on open button - window is rolling down. Also, when driver door get unlock via remote access - all doors got unlocked. Anyway, I like it and if anyone needs help in Sacramento area - shoot me PM, we might meet and I can customize your GT-86.
The Following User Says Thank You to BabaYaga For This Useful Post: | Bach415 (04-06-2016) |
Similar Threads | ||||
Toyota TechStream Ver GTS_10.10.018 - Diagnostic Tools for FR-S/GT86/BRZ | Trap63 | Scion FR-S / Toyota 86 GT86 General Forum | 225 | 03-09-2024 03:53 AM |
Toyota Techstream | xjohnx | Engine, Exhaust, Transmission | 206 | 08-20-2023 04:01 PM |
*SOLD* Mini VCI OBDII cable for Toyota Techstream [NorCal] | chas3wba0 | Audio/Visual, Electronics, Infotainment, NAV | 1 | 09-03-2014 02:54 PM |
Toyota Techstream on BRZ? | pinoy_dorifto | Engine, Exhaust, Transmission | 6 | 05-15-2013 11:56 AM |
