Old 06-13-2012, 09:48 AM   #1
Ess Vee
Ess Vee's Avatar
Drives: White 2011 Camaro 2SS 6MT
Alcohol Injection
The manual says it requires 93 octane fuel, here in socal we only have 91.
To fix this problem, we could just fit an alcohol injection system. Is this suitable for the boxer engine?
Thoughts?
Thanks,
Nathan
P.S. For anyone who may not understand what this is, click here. It's pretty much everything you need to know. Methanol injection is great for cars with high compression ratios (who may also be using a turbo setup). Generally, it makes the car run cooler, safer, and allows more room for higher boost.
Last edited by Ess Vee; 06-13-2012 at 10:44 AM. Reason: little explanation of what alcohol injection is in P.S.
Ess Vee is offline   Reply With Quote
Old 06-13-2012, 09:50 AM   #2
bakerr6
Drives: 2013 raven black fr-s
no reason to, they have made the vehicles to where the performance will not be affected based on 91 octane. Now if you went down to 89 or 87, I believe it would cut the timing back some, which could change the driving style of the car
bakerr6 is offline   Reply With Quote
Old 06-13-2012, 10:10 AM   #3
Ess Vee
Ess Vee's Avatar
Still, 105+ octane DOES sound nice
Old 06-13-2012, 10:33 AM   #4
serialk11r
Drives: '06 AM V8V Coupe
Some people ( @Allch Chcar ) are apparently already working on E85 conversion...they might be able to tell you what components of the fuel system would need changing with a higher amount of ethanol in the fuel. It's possible that nothing needs changing, then you could probably mix the fuel up to like 20% ethanol for example to increase the knock resistance.
The Following User Says Thank You to serialk11r For This Useful Post:
Ess Vee (06-13-2012)
Old 06-13-2012, 10:41 AM   #5
Ess Vee
Ess Vee's Avatar
Much appreciated!
Old 06-13-2012, 05:11 PM   #6
Allch Chcar
Drives: N/A
Read the manual, it says it reduces power(unknown how much) and may knock lightly/occasionally on 91 AKI octane. 91 is the minimum not the recommended AKI octane, I've had to go over this a few times...
Alcohol or water/alcohol injection doesn't involve the fuel system. It's placed in the intake tract to cool the air like a 5th injector. I don't know too much more about it besides that people usually run windshield washer fluid which is part water/methanol.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 06-13-2012, 05:58 PM   #7
serialk11r
Yea I know, I was just suggesting that it might be possible to just up the ethanol content in the fuel slightly to achieve a similar (possibly better) result.
Old 06-13-2012, 08:48 PM   #8
bakerr6
while that is true in the manuals, the california cars are already programmed to be able to be smog legal in CA, which includes maintaining the stock tune for 91. What this means, is that even if a cali car has access to 93 octane, it will still perform the same
Old 06-13-2012, 09:21 PM   #9
arghx7
Drives: car
Minimal benefits on a naturally aspirated application.
arghx7 is offline   Reply With Quote
The Following 2 Users Say Thank You to arghx7 For This Useful Post:
jedibow (07-09-2012), Toyota86.ir (01-10-2016)
Old 06-13-2012, 11:57 PM   #10
serialk11r
Being smog legal is very different from having max performance.
Old 06-14-2012, 12:42 AM   #11
Sonex51
Sonex51's Avatar
Drives: BRZ Limited (Pre-ordered). WR Blue
If I was going to add alcohol, I'd probably want to just add it to an almost full tank of gas rather than add a new injection system of any kind. Fortunately, I'm also at slightly higher elevation most of the time and I'm just going to xFingers that it won't matter.
I will let you go, Ricky. But first, I want you to say..."I... love... crepes."
Sonex51 is offline   Reply With Quote
Old 06-14-2012, 07:40 AM   #12
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Hopefully, this clears up a few things for people about alcohol or water/meth injection...
You generally don't use them on NA cars. Their main benefit is in a boosted application as a sort of chemical cooling and it also effectively raises octane. To use it, you drill a small hole in the intake pipe just before your throttle body for the injector. You have a reservoir to hold the fluid to inject (more on this later), and a pump and a controller. The controller can work based off of MAP or MAF. So you technically *could* use it in an NA car, but you won't get much benefit from it.
I, personally, use the Snow Performance Stage II kit with a low level indicator to help me not forget to keep the reservoir from becoming empty. This is on my MR2 Spyder that is Turbo'd. It's a pretty solid kit and comparable to the AEM kit or other's sold as there isn't a whole lot different you can make such a kit. Maybe the quality of injectors could be different between them?
Now about fluids. Anyone putting windshield washer fluid in place of methanol is either very ignorant or just plain stupid. "oh it works. I didn't hear any knock". BS. It is not the same. If you want to run something that cheap, then you better tune for something that cheap so you'll get basically zero gains. If you want to actually inject the real deal and get the performance benefit out of it, inject the right stuff. Think about it this way, if windshield washer fluid was equivalent to Methanol, then why doesn't it erode your paint when it hits the body of the car?
Basically, if you're too cheap to put the right fluid in a kit, then don't buy the kit to begin with. Last time I bought a 5Gal drum of VP Racing M1, It cost a little under $40. And that 5Gal drum will last you for months (Unless you're doing track days or racing very regularly). I choose to mix mine with distilled water to try to avoid any contaminants that might foul up the injector, but you could likely use regular tap water. I know Snow performance sells their "Boost Juice" which is a HUGE ripoff, but it has that "cool" red color. Methanol is clear like moonshine and so is water. So what is in the boost juice?
... Anyway, I'll just end the rant about bad injection practices here. Hopefully, this post was informative for some.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
The Following 6 Users Say Thank You to lordtakuban For This Useful Post:
Chewie4299 (07-08-2012), dustmann (02-29-2016), Ess Vee (06-14-2012), jedibow (07-09-2012), Jeremiahlee34 (05-09-2016), Sportsguy83 (07-08-2012)
Old 06-14-2012, 10:29 AM   #13
Ess Vee
Ess Vee's Avatar
Thanks for that lordtakuban!
From what I understand, a turbo/supercharger setup might not work as optimally without a methanol injection setup because of the already sky-high compression ratio. You'd be able to run higher boost levels with the benefit of chemical cooling that methanol injection gives.
Gotta definitely keep an eye on that reservoir though. I can't imagine anything good with an empty methanol reservoir. I'd just keep a backup quart in my glove box, or somewhere else in the car that's hidden.
Project: Cleaning up the C5 engine bay
^Check it out^ *link fixed*
Old 06-14-2012, 10:38 AM   #14
Mitch
form follows function
Drives: RIP '13 BRZ
I'll just leave this here: http://fluidmotorunion.rpmware.com/f.../i-466580.aspx
Mitch is offline   Reply With Quote
Sex-deprived male fruit flies seek solace in alcohol, bump into walls and pass out 7thgear Off-Topic Lounge [WARNING: NO POLITICS] 8 06-11-2016 10:45 AM
Gasoline Direct Injection... DoogenBurns Engine, Exhaust, Transmission 5 05-21-2012 02:05 PM
Nitrous Oxide/Meth injection JDLM Engine, Exhaust, Transmission 6 12-17-2011 04:23 AM
Photos of Subaru Boxer 1.6L Direct Injection Turbo DIT Engine from 2011 TMS Hachiroku BRZ First-Gen (2012+) -- General Topics 21 12-01-2011 07:52 AM
dual injection is just a long overdue solution to carbon build up? Hasjwandje Engine, Exhaust, Transmission 19 11-08-2011 05:53 PM
