04-09-2015, 03:42 PM | #1 |
1st86 Driver!
Database Error on Vendor List
Admins, just wanted to give you a heads-up I get a database error when I go to the "Official Vendor List" in the Classifieds. In case it is a factor, I do have the number of items per page set to max rather than the default.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
04-12-2015, 02:09 AM | #2 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Still having this issue?
- The Ancient BRZ Sacrament by Zaku |
04-12-2015, 01:29 PM | #3 |
1st86 Driver!
yep, with both the name of the state list.
04-16-2015, 03:21 AM | #4 |
I get these database errors all the time on Internet Explorer, but I try different browsers and everything works fine
04-16-2015, 02:30 PM | #5 |
1st86 Driver!
I get it with IE, Chrome and Firefox. Oh well...
The Following User Says Thank You to Dadhawk For This Useful Post: | Guff (04-16-2015) |
04-16-2015, 09:20 PM | #6 |
Drives: BRZ LZR
The Following User Says Thank You to Guff For This Useful Post: | Dadhawk (04-17-2015) |
04-20-2015, 10:18 AM | #7 |
Drives: 2015 BRZ Limited
I used to run VB's back a lot back in the day (up to V4.0) and used to modify them with all the fancy addons and "hacks" as the community referred to them. The issue is likely being caused by an errant call in the php, maybe a funky { somewhere along the line or a call to a table that isn't fully installed or is missing a line).
Might be worth trying to reinstall the hack (if it's using one to generate that page) or rebuild the custom page with the information again. Prior to the DB error you can see that the tables seem to break down (hence the solid black line followed by more sponsor info) so that might give an idea of where to start looking (the relevant VB template file that represents that custom page or revisit the showthread.php file and verify that the hack is installed correctly if that is what it's using to generate the custom pages).
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS |
The Following User Says Thank You to dar3d3vil For This Useful Post: | Dadhawk (04-30-2015) |
Similar Threads | ||||
BBK Fitment Database? | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 163 | 04-06-2023 12:55 AM |
Dyno Database | E92M3Guy | Engine, Exhaust, Transmission | 33 | 04-17-2013 10:20 AM |
