Old 06-14-2012, 03:09 PM   #1
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Please post a reply in this topic if you have new information.
I need your help to complete the data in this list!
Need to determine how much your car has lowered?
Distance between hub center and top of fender opening
Front is 14 7/16" and rear is 14 5/8"
Need to convert the metric spring rate to standard?
http://tinyurl.com/kg-to-lb
Want to install your own coilovers or springs?
Strut Replacement/Coil Spring Install DIY
Need to determine your spring rates?
ridetech.com/info/spring-rate-calculator
Want more information on basic suspension tuning?
http://www.rapid-racer.com/suspension-tuning.php
Code:
SPRINGS             Front/Rate     Rear/Rate      Part #        MSRP
OEM Toyota 86       0.0"/2.3k      0.0"/3.3k      TBD           $---
OEM Toyota GT86 (EU)0.0"/2.3k      0.0"/3.3k      TBD           $---
OEM Scion FR-S M/T  0.0"/2.3k      0.0"/3.8k    F:SU003-04144   $83.90
                                                R:SU003-04147   $83.90
OEM Scion FR-S A/T  0.0"/2.3k      0.0"/3.8k    F:SU003-04145   $83.90
OEM Subaru BRZ M/T  0.0"/2.7k      0.0"/3.5k    F:20330CA010    $79.70
                                                R:20380CA010    $79.70
OEM Subaru BRZ A/T  0.0"/2.7k      0.0"/3.5k    F:20330CA020    $79.70
                                                R:20380CA010    $79.70
Code:
Eibach Pro-Kit      1.0"/3.6k      1.0"/4.9k      8210.5.140    $359
Eibach Sportline    1.4"/3.8k      1.4"/5.3k      4.10582       $359
Espelir Active GT   0.5"/3.2k      0.5"/5.0k      4536190109385 $TBD
Hotchkis Sport      1.0"/3.3k      1.0"/4.7K      19445         $221
Intrax              ---            ---            ---           $---
Mach V              0.7"/TBD       1.0"/TBD       TBD           $239
Race Comp Yellow    0.8"/4.5k      0.8"/4.5k      RCE-BRZ       $349
RS-R Down           0.5"/2.8k      0.5"/4.5k      T065D         $TBD
RS-R S/Down         1.0"/3.2k      1.2"/4.5k      T065S         $TBD
RS-R Ti2000 Down    0.5"/2.8k      0.5"/4.5k      T065TD        $TBD
RS-R Ti2000 S/Down  1.0"/3.2k      1.2"/4.5k      T065TS        $TBD
Swift Sport FRS     1.0"/3.0kg     1.0"/4.5kg     4T909         $399
Swift Sport BRZ     1.0"/3.8kg     1.0"/4.5kg     4F912         $399
STi Pink            0.6"/TBD       0.6"/TBD     F:ST20330AS000  $210.97
                                                R:ST20380AS000
Tein H-Tech *NOTE*  0.9"/2.9k      0.7"/4.8k      SKSA0-G1B00   $TBD
Tein S-Tech *NOTE*  1.2"/3.3k      1.0"/5.0k      SKQ54-AUB00   $280
TRD (same set on CO)0.6"/3.5k      0.6"/5.8k      MS260-18001   $548.00
*Red/bold links denote link to review topic on FT86club.com
Code:
COILOVERS           Front/Rate     Rear/Rate      Part #        MSRP_
AirREX Kit Basic    0.0-3.0"/--    0.0-3.0"/--    S-JP09006     $3575
AirREX Kit Digital  0.0-3.0"/--    0.0-3.0"/--    S-JP09006     $5155
Amuse Hi-Tech       TBD-TBD/8K     TBD-TBD/8K     TBD           $TBD$
Apex'i N1          +1.6-2.4"/10k  +0.8-2.0"/8.0k  264CT090      $TBD$
Blitz Damper ZZR    0.0-2.0"/6.0k  0.0-2.0"/4.0k  TBD           $TBD$
BC Racing BR-Type   TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
BuddyClub D1 Damper     TBD/9k      TBD/7k      BC02-D112ZN6    $1549 **(solid upper mounts)
BuddyClub RSpec Damper  TBD/9k      TBD/7k      BC02-RSD12ZN6   $1799 **(pillow ball, w/ upper camber adjust.)
Cusco Spec-A        0.2-1.4"/4.5k  0.4-2.0"/5.0k  96560JCB      $1707
Cusco Zero-A       +1.0-1.4"/5.0k +1.0-2.0"/5.0k  96560NCN      $2374
Cusco Zero-A w/PB  +1.0-1.4"/5.0k +1.0-2.0"/5.0k  96560NCP      $2640
D2 Racing RS        0.5-3.5"/7.4k  0.5-3.0"/5.0k  D-SC-06       $1525
DG-5                TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Fortune Auto 500    TBD-TBD/6.0K   TBD-TBD/7.0K   TBD           $1149
Fortune Auto 510    TBD-TBD/8.0K   TBD-TBD/8.0K   TBD           $1499
Ground Control Kit  1.0-1.5"/6.7K  1.0-2.5"/7.7K  TBD           $TBD$
HKS Hipermax IV     0.0-2.8"/6.0k  0.0-3.0"/4.0k  80230-AT001   $2250
HKS Hipermax IV GT  TBD/8.0k       TDB/6.0k       80230-AT001V  $2350
JRZ RS1             TBD-TBD/CSTM   TBD-TBD/CSTM   TBD           $TBD$
KSport Kontrol Pro  0.5-3.5"/7.5k  0.5-3.0"/6.3k  CSC080-KP     $1600
KW Variant 3        0.8-2.0"/6.1k  0.8-2.0"/7.1k  35258004      $2299
ISC Basic C         TBD/10k        TBD/7k         S018B-C       $1150 **(Includes Solid Top Plates)
ISC Basic S         TBD/10k        TBD/7k         S018B-S       $1150 **(Includes Solid Top Plates
ISC N1 C            TBD/10k        TBD/7k         S018-C        $1250 **( Includes Front Camber Plates with pillow-ball upper mounts and thrust bearings.)
ISC N1 S            TBD/10k        TBD/7k         S018-S        $1250 **( Includes Front Camber Plates with pillow-ball upper mounts and thrust bearings.)
ISC C-R             TBD/12k        TBD/8k         S018B-R       $1150 **(Available with solid top plates with rubber bushings)
ISC S-R             TBD/12k        TBD/8k         S018-R        $1250 **(Includes Solid Top plates with rubber bushings, Top Camber Plate with pillow-ball upper mounts, and Thrust bearings)
KW Street           TBD-TBD/CSTM   TBD-TBD/CSTM   TBD           $TBD$
Megan Street        TBD-TBD/8.0    TBD-TBD/6.0    MRCDKSFR12    $999
Megan Track         TBD-TBD/10.0   TBD-TBD/8.0    MRCDKSFR12TS  $999
Nitron NTR          TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Ohlins BTO         +0.2-1.2"/9.0k +0.2-1.0"/7.0k  TBD           $3674.88
PRS Soft            TBD-TBD/6.0K   TBD-TBD/6.0K   TBD           $TBD$
PRS Medium          TBD-TBD/8.0K   TBD-TBD/8.0K   TBD           $TBD$
PRS Hard            TBD-TBD/10.0K  TBD-TBD/10.0K  TBD           $TBD$
RS*R iSport Soft   +0.6-1.6"/5.0k +1.2-3.2"/6.0k  SPIF065S      $TBD$
RS*R iSport Std    +0.6-1.6"/6.0k +1.2-3.2"/7.0k  SPIT065M      $$1799
RS*R iSport Hard   +0.6-1.6"/7.0k +1.2-3.2"/8.0k  SPIF065H      $TBD$
Sachs (no model)    TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Stance (no model)   TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Standard ENR        0.0-3.0"/CSTM  0.0-2.8"/CSTM  SC01I2        $4595
Standard R3         0.0-3.0"/TBD   0.0-2.8"/TBD   SC01R3        $1795
Standard R7         0.0-3.0"/TBD   0.0-2.8"/TBD   SC01D7        $2095
Standard R7-TA      0.0-3.0"/TBD   0.0-2.8"/TBD   SC01T7        $2095
Suivax Standard     TBD-TBD/7.0k   TBD-TBD/5.0k   TBD           $TBD$
Suivax 86 Edition   TBD-TBD/8.0k   TBD-TBD/6.0k   TBD           $TBD$
Tanabe Sustec Pro Z40  1.8"/5.0k   1.8/5.0k       TSE4166       $2,190.00
Tein M/Flex *NOTE*  0.2-1.8"/8.0k +0.2-2.8"/9.0k  GSQ54-F1SS1   $TBD$
Tein Street *NOTE*  TBD-TBD/TBD    TBD-TBD/TBD    TBA           $TBD$
Tein T/Flex *NOTE* +0.1-2.2"/7.0k +0.1-2.5"/7.0k  DSQ54-61SS1   $TBD$
TRD FRA Set      0.6"/3.5K   0.6"/5.8K   MS260-18001           $3289
XYZ Super Sport     TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
*K-Sport SCS080-KP (FR-S) and CSB200-KP (BRZ) are identical
*AirREX S-JP09006 (FR-S), S-JP07010 (BRZ) and S-JP01027 (GT86) are identical
WingsofWar is offline   Reply With Quote
The Following 126 Users Say Thank You to WingsofWar For This Useful Post:
200hp/tonne (05-29-2013), ahausheer (09-10-2012), ajay (09-12-2012), AJUSA.com (08-03-2012), akahenry (10-24-2013), Akai (09-10-2012), Allch Chcar (01-11-2014), Anthonytpt (02-07-2013), azian_advanced (08-19-2013), BatStig (06-14-2014), benjoke (06-18-2012), Bonburner (09-28-2016), Boxer 86 (09-10-2012), Bristecom (10-05-2012), brybot (08-19-2016), buzznasa (06-26-2013), Calum (01-19-2013), CaptainSlow (10-16-2012), Choco (01-21-2015), Christina_Marie (10-20-2012), chutrain (09-11-2012), CkOne (12-08-2018), Cotnoir (06-18-2012), cto424 (11-18-2012), cwpbrz-ji (11-28-2015), CxG (10-29-2015), D-VO (02-22-2013), danthedirt (10-23-2012), Darkparadox911 (07-23-2015), DetroitJake (07-30-2012), DieselDog (04-08-2015), diirk (09-21-2012), Drift-Office (06-27-2012), DriftEightSix (09-10-2012), driver01 (07-30-2012), EN2_Squirrel (09-21-2013), Enraged21 (04-10-2013), Ess Vee (06-14-2012), feldy (03-17-2014), fernan2 (10-04-2013), finch1750 (05-10-2013), flippy (04-17-2015), Fly Guy (06-15-2012), Frs x3 (10-31-2013), FRSapex (09-03-2013), ft86Fan (09-04-2012), ft_sjo (04-27-2013), FutureFT86 (10-29-2012), garf (04-17-2013), gonzo (10-23-2012), gtengr (11-30-2016), Guff (06-18-2012), Gyzm0 (01-26-2016), Hachiroku (06-14-2012), Hags86 (08-22-2013), hmong337 (08-25-2013), ill86 (06-24-2012), JACK 8URT0N (08-07-2013), JDM-dono (06-19-2012), jedichimp (09-10-2012), JMon85 (04-05-2018), Josue Cafe FR-S (08-12-2015), junior_reyez (03-06-2014), Kakawate (10-24-2013), Keenercarguy (10-20-2015), Khyron686 (03-02-2014), kwood9000 (09-08-2012), LivingLegend (06-26-2012), lucchesi423 (06-20-2012), lxs (03-30-2014), MALAJSTD (04-01-2017), manonastick (09-04-2013), MattR (06-14-2012), MaXimus (04-22-2014), mit_peid (05-17-2013), MJones_RB (04-30-2016), Mo7ammed (05-05-2013), MoarGeesPlease (09-11-2012), Mooseknuckle44 (03-31-2014), Moto-P (09-17-2013), Motopythons (06-17-2012), Mr. (06-17-2013), mugen79 (07-03-2013), nikitopo (10-18-2015), Obja (10-07-2012), Pin Flare (03-04-2013), Pooverdam (12-02-2014), RaceR (09-10-2012), raul (04-26-2013), Rulin (12-09-2014), RYU (09-10-2012), sal (09-10-2012), Scooby South (06-27-2012), SG-RS1 (09-01-2015), shawnperolis (04-21-2013), ShikoBariki (04-20-2013), ShoNUFF (01-12-2013), Sideways? (05-22-2014), Sigh-on-Rice (09-21-2012), Slartibartfast (12-14-2012), slim blanco (08-17-2014), Snoopyalien24 (09-10-2012), solidONE (04-12-2020), soonami77 (10-02-2013), sosick (05-11-2015), stockysnail (04-29-2013), Style (08-23-2012), Sugi (12-22-2014), Tad_07 (09-12-2012), tnt (08-19-2012), TofuJoe (08-21-2016), Totality (07-05-2014), TouchMyHonda (03-24-2013), travelmonkey (06-19-2013), Tristor (02-28-2018), Turbowned (09-10-2012), unsurety (08-05-2014), usptwins (12-30-2012), Valentino (05-17-2015), VersionUp (06-22-2012), VIXEN (07-16-2013), whataboutbob (11-02-2012), wheelhaus (09-10-2012), WRB-DZA-BRZ (09-10-2012), zAnSh1n (09-10-2012), zoomzoomers (06-03-2013)
Old 06-14-2012, 03:24 PM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
1st post handed over to WingsofWar because I don't have time to maintain this topic anymore.
The Following User Says Thank You to DarrenDriven For This Useful Post:
Old 06-14-2012, 03:35 PM   #3
DarrenDriven
NW Region Moderator
Intrax, Tokico and Suspension Techniques emailed, waiting for a response.
I called H&R and they have springs in R&D that should be available in two months.
Old 06-14-2012, 03:47 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
RaceComp Engineering "Yellow" springs will be a 20mm drop F/R with 250in/lb rates front and rear. They are due out in July. (which can't come fast enough, I want these springs!)
I believe they will be also releasing "Black" springs which will have milder drops and rates. But no info on those yet as far as I know.
Old 06-14-2012, 03:49 PM   #5
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
You should add RS*R iSport coil overs. I went directly through RS*R.
The front +/- is 0/-40
The rear +/- is -5/-50
Max adjustable range is:
F: +10/-40
R: +25/-80
Spring rates are:
F: 6kg
R: 7kg
Item code from their site is:
SPIF065MP
Price SHIPPED to my door after assembly in Japan was $2600
denkigrve is offline   Reply With Quote
Old 06-14-2012, 03:53 PM   #6
denkigrve
Random Internet dad
denkigrve's Avatar
Tein already has the Flex and mono-flex listed. No dates yet though.
Cusco also has their coil overs, and I know a few vendors have them or can get them soon as well.
Old 06-14-2012, 03:53 PM   #7
DarrenDriven
NW Region Moderator
Thanks Draco-REX, I added them to the list.
Old 06-14-2012, 04:02 PM   #8
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
jdm TRD springs 15mm drop priced around $500
wow that's only half an inch drop
86_ZN6 is offline   Reply With Quote
Old 06-14-2012, 04:06 PM   #9
DarrenDriven
NW Region Moderator
I was able to find the Flex info on Tein's site, but nothing about the Mono Flex. I am adding this stuff to the list right now...
Old 06-14-2012, 04:15 PM   #10
DarrenDriven
NW Region Moderator
I wasn't able to find any information on these... only the TRD coilovers:
http://www.trdparts.jp/english/86_pe...s_chassis.html
Can you point me to the info on the springs?
Old 06-14-2012, 04:20 PM   #11
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
that's the same one i was talking about
i believe those are not coilovers, but rather a shock and spring combo set but not really sure
you can purchase them as a set or separately
Old 06-14-2012, 04:23 PM   #12
DarrenDriven
NW Region Moderator
Ahhh... it appears that the shocks are threaded-adjustable coilover type and the fine print indicates that they are shipped with the height at 15mm. That doesn't necessarily mean that the springs are a 15mm drop, right?
Old 06-14-2012, 04:28 PM   #13
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
yeah i was reading it again and yes you're right. they can adjusted to a lower height.
but i read somewhere that you can use the springs on the stock shocks. but you only get that 15mm drop.
that's why they are selling the springs separately
Old 06-14-2012, 04:44 PM   #14
DarrenDriven
NW Region Moderator
I'm gonna leave the TRD info as TBD until we actually get better info, but they are up on the list now.
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
