Old 07-21-2015, 08:25 PM   #1
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
External Wastegate Question
This is my first car running an externally gated turbo - prior they were all internally gated.
I have the bottom hose of the external wastegate connected to the pressure line from the front of the turbo housing, and the top of the wastegate connected to a boost controller.
The thing is that when I start the car up, the wastegate is partially open with exhaust billowing out the wastegate pipe. To my knowledge this is not supposed to happen until the proper boost is achieved in the system to push the spring up and allow exhaust pressure to escape. I'm thinking there is something wrong with my wastegate but wanted to pose the question here to make certain.
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast.
TurboBRZ is offline   Reply With Quote
Old 07-21-2015, 08:28 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The top line is vented to Atmosphere. The boost controller goes to the bottom/side port.
The turbo pressure line goes into your boost controller.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Sammakko (07-21-2015)
Old 07-21-2015, 09:05 PM   #3
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
it depends on the number of ports on your boost controller. is it a restrictive type, or a bleed-down type? (2 port or 3 port)
Sammakko is offline   Reply With Quote
The Following User Says Thank You to Sammakko For This Useful Post:
Sportsguy83 (07-21-2015)
Old 07-21-2015, 09:37 PM   #4
Sportsguy83
Drives: Limited BRZ
This was the right question to ask, I only gave half the answer
Old 07-21-2015, 09:43 PM   #5
Sammakko
Bilge monkey
Sammakko's Avatar
it probably also depends on what brand of wastegate he's using?
i abhor external wastegates, personally. well... only when they're dumped to atmosphere.
Old 07-21-2015, 09:58 PM   #6
Sportsguy83
Drives: Limited BRZ
mine's recirc, I dislike dump to atm.
Old 07-21-2015, 10:54 PM   #7
TurboBRZ
TurboBRZ's Avatar
I set it up as per the following image:
The wastegate I am using is the stock one that came with the kit - which resembles the one in the photo above with 2 vacuum ports.
The boost controller I am using is a manual one rather than electronic:
This boost controller is temporary. The tuner I spoke to said he likes to use the STI factory boost controller plugged into our factory harness and control it via the tune - so that's what is likely to happen when I bring it in to be tuned, but for now it's manual.
Old 07-21-2015, 11:15 PM   #8
Sammakko
Bilge monkey
Sammakko's Avatar
try disconnecting ALL lines from your wastegate, and see what happens. does it still open? then you have a problem. the bias spring should keep it closed, at idle.
The Following 2 Users Say Thank You to Sammakko For This Useful Post:
Sportsguy83 (07-22-2015), TurboBRZ (07-21-2015)
Old 07-21-2015, 11:24 PM   #9
TurboBRZ
TurboBRZ's Avatar
I will give that a try first and see what happens.
Old 07-22-2015, 08:57 AM   #10
TurboBRZ
TurboBRZ's Avatar
I did this first thing this morning when I got up - both vacuum lines are disconnected and it's still letting exhaust out the dump tube (I don't like dump tubes either - wish it was a recirc).
So I am assuming this is a problematic wastegate?
Also the engine still idles like crap and dies several times before I can feather the throttle to get it to actually idle a bit later... I'm confused as to what is causing such a troublesome start when there is no boost going into the motor - so it should run like stock?
Old 07-22-2015, 09:04 AM   #11
Sammakko
Bilge monkey
Sammakko's Avatar
yup, sounds like it. is it a 38mm? i have a Tial i could sell you, brand new in box. Vband though.
Old 07-22-2015, 09:06 AM   #12
TurboBRZ
TurboBRZ's Avatar
Yeah 38mm. It's not a v-band one though, it has a 2-bolt flange with hex bolts (which will be a pain in the ass to remove).
I emailed the seller on ebay to let him know he owes me something, whether a partial credit towards purchasing a tial or...?
Old 07-22-2015, 09:15 AM   #13
Sportsguy83
Drives: Limited BRZ
You're running the stock tune with the turbo MAF housing?
The MAF table needs to be adjusted for the bigger MAF housing to fix the idle problems.
The grimmspeed EBCS and similar are the ones used to control boost via the ECU with Ecutek. I have mine setup per their instructions (the port that says to inlet in our cars is VTA). I called Grimmspeed about how to set it up between your setup and the one I ended up going with, and they said your setup is an overcomplication not necessary to control boos with their solenoid and that I should use the configuration below.
Old 07-22-2015, 09:18 AM   #14
STV3
Seņor Member
STV3's Avatar
Did you install the valve seal when installing the waste gate?
STV3 is offline   Reply With Quote
How to size wastegate crazyfrenchbiker Forced Induction 8 04-17-2015 05:06 PM
Fs:SoCal tial f41 wastegate enjetek Engine, Exhaust, Bolt-Ons 2 11-20-2014 11:30 AM
FS: BNIB Precision 39mm Wastegate PW39 pleong Engine, Exhaust, Bolt-Ons 1 05-20-2014 03:33 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 08:43 AM
AUX external mic playing through speakers sw20kosh Electronics | Audio | NAV | Infotainment 9 03-12-2013 02:27 PM
