Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-15-2015, 09:08 PM | #1 |
Drives: GT 86
J2 Lower Control Arms
Has anyone installed a set of these http://control-arm-shaft-kit.dvautop...w-jmjokrollrjm or have any feedback on them .
Did a search and stuff all came up . Looking to try and take a bit of twitchyness out of the rear of my 86 and thinking a set of LCA's might help am lowered app 1" . Running 245 40 17's . |
08-16-2015, 06:40 AM | #3 |
Because compromise ®
Drives: Red Herring
What do you mean by "twitchyness"? Rear toe has a huge impact on rear end stability. Do you know what your rear toe is set at? Why do you think lca will help?
The Following User Says Thank You to Captain Snooze For This Useful Post: | kodyo (08-17-2015) |
08-17-2015, 09:30 PM | #4 |
Drives: GT 86
Rear toe is meant to be set at 0 but maybe need to get it checked again.
What's the best toe setting for the rear with the drop I have ? I think the LCA's would help as far as traction goes being S charged as well but still learning |
08-17-2015, 10:38 PM | #5 |
Drives: Scion FR-S
If you can't get toe zeroed with the stock setup, buy some toe arms. I recently bought some SPC toe arms for the very symptoms you have (twitchyness over bumps).
This place has best deal I could find personally, @$150 for a set, it's a really good deal IMO: http://thmotorsports.com/spc-perform.../i-495481.aspx |
The Following User Says Thank You to kodyo For This Useful Post: | kalamitykode (09-03-2015) |
08-17-2015, 11:30 PM | #6 | |
Drives: Red Herring
08-17-2015, 11:33 PM | #7 | |
Drives: Red Herring
Rear aftermarket lca arms are for mainly for camber adjustment and added strength. You mention traction issues but have not mentioned the tyres you are wearing. If you are already wearing wider stickier tyres (and don't go crazy wide either because compromise) I would recommend controlling your right foot.
Last edited by Captain Snooze; 08-18-2015 at 08:45 PM. Reason: changed degrees to millimeters |
08-18-2015, 11:19 AM | #8 |
Drives: 2014 FR-S
I hope you mean camber because that is an insane amount of toe.
08-18-2015, 05:13 PM | #9 |
Drives: Scion FR-S
08-18-2015, 08:38 PM | #10 |
Señor Member
I think he means millimetres.
A little toe in on the rear will add some stability.
1974 TA22 Celica
2013 86 GT |
08-18-2015, 08:43 PM | #11 |
Drives: Red Herring
My mistake. As @Turdinator said I meant millimeters.
The Following User Says Thank You to Captain Snooze For This Useful Post: | kbye (08-18-2015) |
08-19-2015, 08:24 PM | #12 |
Drives: GT 86
Thanks for the help so just wondering what would be a good DD setup for the alignment?
From what I have gathered so far is about 1.5 camber front and 1 rear but not sure on toe front to rear as like said before still learning about this and my wheel guy just says he'll set it to what I want. |
Similar Threads | ||||
SPC Lower Control Arms(Old and New) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 07-10-2017 09:58 PM |
Is there a need for 400$ lower control arms ? | Simon99 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 41 | 09-11-2015 01:04 PM |
DME Lower Control Arms and DME Toe Arms - Review | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 02-24-2015 11:53 AM |
Lower Control Arms | iLaw | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 01-26-2015 06:33 PM |
WTB: SPC LCA (Lower Control Arms) | AG3NT_5CARFAC3 | Want-To-Buy Requests | 9 | 02-19-2014 01:30 PM |
