Old 09-04-2015, 11:34 AM   #1
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
DIY: STI Replica Side Skirts by Bason R
since front lip installation is simple i am not going to post it but some people have difficulty understanding on installation of STI side skirts.
I bought both Front Lip & side skirts from BasonR in Ebay. do not ask me for link. just search seller's name of BasonR or type "STI Front lip" and you can find it very easy.
Requirement Tool:
1. 10mm socket & Wrench
2. Rivet Gun (or you can supply bolts and nuts)
3. screw driver
1. lay down all necessary hardware and refresh your mind where bolt and nuts and go as well as double side tape. lol
2. use supplied double side 3M tape to apply on side skirts where it's going to meet side of body on car.
3. take out Rivet gun and load a bullet!
4. use Rivet gun and install it as picture above
back of rivet looks like this.
Left one is used, right one is before.
5. install bracket with bolt and nuts
6. see your side of car and think about how side skirts are going to be installed. at each end of front and back of side, you can find one each clip on bottom. you'll be re-using these clips to bracket from side skirts
7. since i did not have any 2nd person to hold side skirts, i used container to hold at back. try test fitting and squeeze on back to fit. use side skirts bracket installed to fit under the car. (forgot to take picture but you'll understand about clip and bracket once you see under the car)
my car is stock height and didnt have to lift the car. but if you're super lowered, you might put on jack stands that make your life easier
after installing clips and screws, start peel off double side tape and apply to body. do not push up side skirts and apply to paint!! because your side skirts will sag eventually due to its weight! just pushe side of skirts to make a contact to body and double side will stick!
Note: This is replica!! location of double side tape i applied on side skirts did not make good contact with body of car, so i re-applied.
8. It's Done! do the same on other side.
below is result of Side skirts install! Enjoy!
After install, there is little gap because of double side tape is little bit pulled off from body. I expected this but very unnoticeable unless you go and try to find it. For price of this replica, this is very good fitment. if you cannot deal with little gap, then buy original one for $600 -$800
I probably gonna take off again and re-apply thicker double side tape so it will hold to body well. but cost of double side tape and edgeguard tape will cost me about $30-$40!!!
if you have any question or comment, let me know!
After 2 days, i see little gap as expected
It's not really noticeable so i am just going to leave like this for while
i might have to use thicker/double the layer of tape later
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
yajin (09-05-2015)
Old 09-04-2015, 12:13 PM   #2
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
wrap the hood glossy black + get the rear side lip (w/e its called)
BlackJesus is offline   Reply With Quote
Old 09-04-2015, 12:28 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
yup rear spats will complete the kit. Nice are you going to paint it?
Old 09-04-2015, 01:25 PM   #4
zc06_kisstherain
Drives: SWP BRZ
yeah..i got front lip + side skirts combo deal. i probably going to order rear part. not fan of black hood. lol
Nope. maybe plastic dip it later..
Old 09-04-2015, 02:40 PM   #5
Timmy_Jones
Spun
Drives: 17' Focus RS
I have some of their stuff as well and like it, thanks for the writeup!
Couldn't help but notice it makes the side of the car seem higher up and almost like its lifted. just a strange optical illusion with the black/white.
Timmy_Jones is offline   Reply With Quote
The Following User Says Thank You to Timmy_Jones For This Useful Post:
zc06_kisstherain (09-04-2015)
Old 09-05-2015, 11:08 AM   #6
BlackJesus
BlackJesus's Avatar
ah sorry not the hood. i meant the roof. black hood are ugly af lol. Do a black plasti dip on bottom then paint over that with actual black paint then clear it out for an OEM look. MAKE SURE you have a good layer of plastic dip. 5-7 coats of plasti dip
Old 09-05-2015, 11:46 AM   #7
zc06_kisstherain
Drives: SWP BRZ
i see little gaps now!!! damm it. edited first post
Old 09-12-2015, 07:11 PM   #8
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
I just got these exact same kit for my birthday, no drilling necessary?! Awesome. Any additional tips?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 09-13-2015, 08:43 AM   #9
zc06_kisstherain
Drives: SWP BRZ
no drilling under side skirts.
only fenderliner at front but if you do doubleside tape well, you dont have to.
use double layer of tape because tape does not touch body of car very well.
i re installed on driver side with triple tape and now tape on side is lifted!
little annoying but just use double side tape making sure they stick well.
Old 09-14-2015, 11:59 PM   #10
edigeek
Drives: 2014 White BRZ Limited
You all better pay attention to this thread. I also installed my Bayson R and my experience was good except that the double sided tape, doesn't stick to the body, so you will get an ugly gap between skirts and body. It's not the tape that is bad, it's the goes about 1/4 inch below the edge of the skirt, and the edge is not flat, therefore the tape is kind of in the inside and doesn't reach the body when pushed. I had to take it all out again, and of course, once tape has been put in place, you kind of have to get rid of it. My solution, i bought 3 of these [ame="http://www.amazon.com/gp/product/B002JOVUO0"]Amazon.com: 3M 03614 Scotch-Mount 1/2" x 15' Molding Tape: Automotive[/ame] and put triple tape. The thing is that this tape is thinner than the original one (the one that kits come with is ticker). If I hadn't removed the original tape, I would only need one of the 3m tapes from link. That would be enough for both.
edigeek is offline   Reply With Quote
Old 09-16-2015, 03:29 PM   #11
SmartedPanda
Yeah, same thing happened to me. Driver side was not fitting well with the tape, had to basically take it off again, and buy additional wider 3M Double sided tape.
Also, 3M Double tape first, then weather tape 2nd is a tip we realized when we installed it.
Old 09-17-2015, 10:36 AM   #12
zc06_kisstherain
Drives: SWP BRZ
i re-installed driver side with triple tape. hope it doesnt come off
Old 09-20-2015, 06:44 PM   #13
SmartedPanda
So, after replacing oneside with wider/thicker 3M tape.
You also need a heat gun or even a blow dryer.
My repaired side skirt is a little better a little saggy.
The non-repaired side with the tape that came with the skirt finally sagged too.
Make sure after applying the newer/thicker 3M, hold it in place or go over it with LIGHT pressure, then hit with a blow dryer, then more pressure.
I'll see how it is after 2-3 more days.
Old 09-20-2015, 10:26 PM   #14
zc06_kisstherain
Drives: SWP BRZ
when i re-install driver side, I used heatgun by the way. still some areas of 3M tape got weaker and detached from body again after 3 days. i think only solution is to use Thick and stronger 3M tape. i probably re-install again but i am just gonna leave it as right now. hope someone know better/stronger tape to use
Brand new replica Subaru brz sti side skirts FR-FKN S! Hawaii 3 08-22-2015 08:06 PM
Recommended Replica lip, diffuser and side skirts? SmartedPanda Cosmetic Modification (Interior/Exterior/Lighting) 20 07-20-2014 09:37 PM
FS: replica TRD side skirts painted raven SOLD! please close pleasurevictim Exterior Parts (Aero, Lighting, Etc.) 0 06-18-2014 03:03 AM
Fs: Bayson R STI Style Replica Body Kit (front lip, side skirts, rear spats) ucsmfu Canada Classifieds 6 04-29-2014 12:43 AM
wtb: cs replica side skirts slava Exterior Parts (Aero, Lighting, Etc.) 2 07-24-2013 02:41 PM
