Old 10-08-2015, 10:28 PM   #1
xingxingtjf
Drives: Subaru BRZ
Unhappy Steering wheel issue---left turn lighter than right turn!!!
Hi Experts,
I had an accident (about the accident: I was on the dragon tail and I went into a ditch on the right side. So I assume there was a big impact on the right side of the car.) with my 2014 brz and after the body shop fix I always have this steering wheel feeling - left turn is much lighter than the right turn. I also took it to the dealer and they did all the check and said everything is fine based on the test they can do. But one of them took a ride and also noticed the same feeling. Then I took it to my mechanic friend and we checked the alignment and turned out the rear lower control arm is bad so I replaced them with the adjustable SPC ones. I feel much better now but still I have the same feeling. My mechanic friend said if suspension now is good the problem probably lies on the steering part. Maybe it is the steering motor.
I took a ride tonight and feel my car always tries to turn left itself especially at speed between 5-10mph. This feeling is very obvious when the road is bumpy.
What do you guys think? Any suggestion is welcome! I have been dealing with this for over 2 months now. I just want the steering to be the way it was. Please help
xingxingtjf is offline   Reply With Quote
Old 10-09-2015, 12:22 AM   #2
humfrz
It sounds to me like an alignment issue. You might try a different alignment shop, just to get a second opinion.
humfrz
Tcoat (10-09-2015)
Old 10-09-2015, 01:12 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
To me it sounds like some alginment issues. Could be a bad ball joint or tie rod, or just a crack wheel. Have you checked your tire pressures?
Did the alginment shop give you a print out? If not I would take it to another shop.
Old 10-09-2015, 09:23 AM   #4
xingxingtjf
Drives: Subaru BRZ
Hey guys,
Thanks for the input. I checked my alignment in 4 different places including Express oil tune, Subaru Dealer, NTB service and Lexus Dealer. I installed my SPC lower control arms in the Lexus Dealer(because that's where my mechanic friend works) and he did the alignment right after the install. So I am pretty positive that alignment or suspension is not the problem. I will probably focus on the steering part and keep you guys updated.
Old 10-09-2015, 09:50 AM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I know how it feels and hate it too.
you have 2 options.
1. just forget about it and drive it as it is. everything is fine except that feeling
2. try to replace suspension parts like ball joints, tie rod like Mr.ac mentioned. i would replace every possible parts at front if i want to get rid of that steer feeling. It's very difficult to diagnosis bad part one by one and time+labor will be a lot here.
I would start replacing cheaper parts first then go into expensive parts.
GL
Old 10-09-2015, 12:50 PM   #6
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Had that on a Saturn once, turned out the impact on the wheel had cause the cross member to kink(all the suspension parts were still straight and fine after the obvious damaged ones were changed) and the bent cross member caused everything to be off (although it showed as aligned, the geometry was off)
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
Tcoat (10-09-2015)
Old 10-09-2015, 12:54 PM   #7
xingxingtjf
Drives: Subaru BRZ
Have you experienced the same thing?
Old 10-09-2015, 03:00 PM   #8
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
A serious race shop should be able to figure it out. fumanchu1 is right that it could be a frame problem. Here's a thought: lift the front and see if the difference in effort is still there, both with the car on and off. If the feel is equal with the car off but different with the car on, you have an electrical problem. You can do it the same with the front on the ground at a stop, but the effort is so high with the car off, it might be hard to tell.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Tcoat (10-09-2015)
Old 10-09-2015, 03:04 PM   #9
evomike
Drives: frs
id put a rack in the car if it was at my shop, bmw actually has a service bulletin if any suspension is damaged the steering rack needs to be replaced. There is no real way you can inspect if the rack is damaged internally and its not something id mess around with, the last thing you want to do is ignore it and have a gear break apart on the highway.
evomike is offline   Reply With Quote
The Following User Says Thank You to evomike For This Useful Post:
Tcoat (10-09-2015)
Old 10-09-2015, 04:58 PM   #10
fumanchu1
This has got to be the thread with the least trolling and most useful information I have ever seen on this forum(don't be fooled by my join date I have been lurking for a long time)
Old 10-09-2015, 09:33 PM   #11
xingxingtjf
Drives: Subaru BRZ
Tonight I noticed something, when it is in the reverse mode, this right turn harder than left turn feeling is even more obvious. I guess I will take it to another shop and tear it apart and see what's wrong
Old 10-09-2015, 11:46 PM   #12
stugray
Drives: 2013 GBS BRZ Limited
You could test the system with the electrical steering assist disconnected.
It is likely just a fuse, but I have never tried it.
It should be harder to steer in both directions with no assist, but see if you can feel a difference in left vs right turning with no assist.
What you are explaining sounds like the steering system is confused and trying to help more in one dir than the other (bias). As if the sensor is off center or has hysteresis.
Old 10-14-2015, 06:47 PM   #13
xingxingtjf
Drives: Subaru BRZ
Hey guys,
The problem is solved!! It is the steering sensor not centered/calibrated. This should have been done by the first body shop. Or this should be detected easily by the dealer. I guess both of them failed this time. Any way, problem solved! Hopefully this thread will help other people too.
The Following 4 Users Say Thank You to xingxingtjf For This Useful Post:
djdnz (10-18-2015), humfrz (10-14-2015), strat61caster (10-14-2015), stugray (10-15-2015)
issue, steering, steering wheel
Left Hand turn fuel starvation on WOT Huehuecoyotl Tracking / Autocross / HPDE / Drifting 105 08-05-2021 07:12 PM
Left turn signal not working. klassick Issues | Warranty | Recalls / TSB 15 09-24-2016 12:47 PM
Clunk on full lock left turn yomny Issues | Warranty | Recalls / TSB 5 11-17-2014 08:27 AM
AT holding 2nd gear to high revs during a long left turn EK_Golfer Scion FR-S / Toyota 86 GT86 General Forum 9 03-01-2013 10:35 AM
"From the first turn of the steering wheel, this car needs to be fun and special" Matador Scion FR-S / Toyota 86 GT86 General Forum 15 12-26-2009 07:54 PM
