Old 10-13-2015, 12:14 PM   #1
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
New Member & have question? Read here first!
New member and have a question you wanna ask? Well, you're looking at the right thread! I made simple FAQ and quick reference thread to go to.
As for senior members, if you have any other FAQ you want to add or other good resource threads, LMK and I'll add it.
FAQ
1.
Q: Is FRS/BRZ fast? / Can FRS/BRZ beat *insert a car*?
A: Depends on "who" drive the car & where they race.
2.
Q: Does Cricket ever go away?
A: There's a lot of things been done, said & myth, but simply put it "No"
3.
Q: Can I plastidip *insert a part*?
A: It's your car, do whatever you want.
4.
Q: Can I wrap my car to *insert a color/s*
A: Again, it's your car, do whatever you want.
5.
Q: Is *insert a wheel* fit my car?
A: Check Wheels Directory or Fitment Calculator. You thought about it, someone prob done it.
6.
Q: Which mods give me most power?
A: FI or engine swap.
7.
Q: Can I drive FRS/BRZ in the winter/snow.
A: Stock tires, no. Snow tires (with/without studs) & don't drive like an idiot, yes.
8.
Q: Why FRS/BRZ paint sucks.
A: Government cracking down on VOC (Volatile Organic Compounds) the weaker the paint on new cars is going to get... so take care of the paint!
9.
Q: I have *insert amount of money*, which mods should I buy?
A: There's no one answer to this. It's all comes down to WHAT YOU ARE EXPECTING FROM THIS CAR OR WHAT'S YOUR GOAL FROM THIS CAR. Best, check Member Journals. They're good resource and have a lot of information or check this thread
10.
Q: MT or AT which is better?
A: Both, buy one that fit your needs... or just read here: AT or MT?
11.
Q: I hear a strange electric motor sound after I shut off my car
A: This is a fuel pump leak test and is perfectly normal. See thread
12.
Q: Winter is coming and I want to store my car. How can I do this?
A: There are several proper way of storing your car. Read here: Basic Storage
13.
Q: My windows froze and now they won't work. What can I do?
A: Read your manual. There's a step by step you're should be doing. (Reference thread here)
14.
Q: Where can I find part numbers?
A. You can find it here in this thread plus you can download the PDF: Parts List
15.
Q: Why won't my trunk open with the fob or interior button?
A: Check the trunk lock button on the driver side of the trunk.
16.
Q: Why does my passenger seatbelt warning keep going off with the smallest thing on my seat?
A: It is not pressure sensitive. Anything with a battery (i.e. cell phones) or materials with a high moisture level (i.e. groceries) may trigger the air bag warning light.
17.
Q: Which car cover is good.
A: Choose one - Covercraft Evolution, Covercraft Noah, Rain-x, Touchless Car Cover, Weathershield HP, Coverking or you can read here
Quick Refernce:
Scion FR-S Manual
ichitaka05 is online now   Reply With Quote
The Following 26 Users Say Thank You to ichitaka05 For This Useful Post:
86geek (10-13-2015), BatStig (10-13-2015), BirdTRD (10-14-2015), Chaetagnath (01-22-2017), drewbot (10-13-2015), D_Thissen (11-16-2015), finch1750 (02-17-2016), golfyankee2121 (10-14-2015), go_a_way1 (10-14-2015), Guff (11-23-2015), HotLeopardMama (04-04-2016), Mattstermh (06-20-2016), NyC Zn6 (10-14-2015), Packofcrows (10-14-2015), RedNWhite (05-23-2016), Sarlacc (10-18-2015), sgtcarrot (11-18-2015), Silver Supra (07-07-2017), soulreapersteve (10-13-2015), Tcoat (10-14-2015), toijin (01-21-2017), TorontoNat (01-23-2018), Trap63 (04-18-2016), Ultramaroon (10-25-2015), WhiteFRS69 (11-16-2015), xFury (10-25-2015)
Old 10-13-2015, 10:30 PM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Reference threads:
The Following 4 Users Say Thank You to ichitaka05 For This Useful Post:
Chaetagnath (01-22-2017), finch1750 (02-17-2016), HotLeopardMama (04-05-2016), Stigasaur (01-31-2016)
Old 10-14-2015, 09:36 AM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
@ichitaka05
Aftermarket lights - The installation of some aftermarket lights (HID, taillights, LEDs) has been know to cause problems with the BCM (Body Control Module. Sometimes called BC Unit). The symptoms of these failures have ranged from complete power failure and inability to start the vehicle to intermittent light or other electrical control failure. The failure can occur immediately or after a period of time and is unpredictable. If you have a system failure that could be electrical in nature it is a good idea to check the ECM.
Shorter ver plz lol
Old 10-14-2015, 09:47 AM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Aftermarket lights can fuck your shit up!
In reality, I am not sure it can be much shorter and still make the point. I understand the desire to make things short but we still need to impart some more info than "they can break".
What I meant was to the point. Like...
Q: After installing taillights, my car doesn't start.
A: Aftermarket lights can cause failure the BCM (Body Control Unit). Check ECM to see if still working or more info: ....
Kinda like that
Old 10-14-2015, 10:47 AM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
I will look through the threads on lights and add it to one of them and then you can link to that. Think it needs more attention as it is a very common issue here.
That work for you?
Perfect!
& TBH I didn't know/knew about that issue was a common issue
Old 10-14-2015, 12:37 PM   #6
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
May I suggest a part that states something along the lines of reading the car's manual?
Dunno if it'll be under FAQs or somewhere else...
I noticed the BRZ has the owner's manual listed as a stickied thread so here's a link to the FRS. All people have to do is quickly navigate through the dropdown lists and all manuals that come with the car is displayed.
https://techinfo.toyota.com/techInfo...arch_docs_page
If I may also add another suggestion: google search "site:ft86club.com/forums [keyword search here]" without the brackets and quotation marks. So glad I saw a few members bringing that up a few months back. Saved me from creating many threads.
For example: site:ft86club.com/forums lowering springs
The Twins make me smile
The Following User Says Thank You to soulreapersteve For This Useful Post:
Tcoat (10-14-2015)
Old 10-14-2015, 12:54 PM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
Thought bout the Owner's Manual vs Service Manual... or maybe add both for quick reference. I just went with Service Manual, cuz they might have more question about service more, so I only made service manual quick reference.
As for the forum, I usually do *whatever I'm search* and add "ft86club" and it's usually comes up in first search. Not sure "site:ft86club.com/forums" is necessary needed... but that's just me
soulreapersteve (10-14-2015)
Old 10-20-2015, 03:09 PM   #8
ichitaka05
Site Moderator
ichitaka05's Avatar
New one that gets asked a lot @ichitaka05
Q - "I hear a strange electric motor sound after I shut off my car"
A - This is a fuel pump leak test and is perfectly normal. See thread http://www.ft86club.com/forums/showthread.php?t=16534
Thanks, kinda funny that, I saw someone ask same question on FB FRS/BRZ group
Old 10-20-2015, 05:02 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I want Bodky.
Its probably like Pocky but less tasty.
The Following User Says Thank You to mav1178 For This Useful Post:
ichitaka05 (10-20-2015)
Old 10-21-2015, 09:38 AM   #10
@ichitaka05
Good one to link to the " I have *insert amount of money*, which mods should I buy?" question?
http://www.ft86club.com/forums/showthread.php?t=96518
You will notice that in order to keep the focus on the first post I have deleted all mine that have followed. Want to keep this clean and easy to read.
ichitaka05 (10-22-2015)
Old 10-22-2015, 11:59 AM   #11
ichitaka05
Site Moderator
ichitaka05's Avatar
@ichitaka05
Thanks, I've added the thread
Old 10-23-2015, 03:38 PM   #12
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Oh ichi what about which mods will need tuning etc? Definately a FAQ
Should probably include the mod sticky as well
Instagram: trevor.parque
Old 10-25-2015, 03:01 PM   #13
ichitaka05
Site Moderator
ichitaka05's Avatar
That's a simple answer. ALL of em! Lol
But when I'm next to a PC, I'll add/edit it some in there
Old 11-04-2015, 05:25 PM   #14
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
From a newbie thread:
See question 5 and suspension sub category.
http://www.ft86club.com/forums/showthread.php?t=96158
I suggest numbering the list in first post.
Just to make Tcoat's mission a little bit easier :-)
New Member & have question? Read here first! ichitaka05 BRZ First-Gen (2012+) -- General Topics 6 10-22-2021 05:43 AM
New Member - paint question kberkel BRZ First-Gen (2012+) -- General Topics 21 03-26-2014 09:38 PM
New Member FRSupra Scion FR-S / Toyota 86 GT86 General Forum 22 12-20-2012 11:25 PM
New member brz007 BRZ First-Gen (2012+) -- General Topics 2 06-02-2012 09:37 AM
New Member/ Quick question sikse7en Scion FR-S / Toyota 86 GT86 General Forum 3 11-28-2011 08:57 PM
