Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
01-06-2016, 08:29 AM | #1 |
Drives: 2013 Dark Gray BRZ
MT Stick does not return to center neutral on its own
Hi guys,
I've noticed past two weeks or so, that the stick is really slow to return to center when I take it out of gear. To the point where out of 5th/6th is like "stuck" for a second or two before it ends up close to center again, and coming out of Reverse it won't return unless I force it to. I can still drive it fine, I just have to move the stick around myself, which seems really odd. Curious if anyone has had anything similar or heard of anything like this. Thanks |
01-06-2016, 08:42 AM | #2 |
If it is cold there the grease could just be thickened a bit. Could also be the return spring has broke or stuck. Both of these would be a pretty easy fix I would think.
The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (01-06-2016) |
01-06-2016, 02:25 PM | #3 |
Drives: 2013 Subaru BRZ MT Limited
I would bet you have a broken return spring. Sounds like it's time to upgrade to some MTec springs.
http://www.ft86speedfactory.com/mtec...l#.Vo1qOvkrKUk
Silver 2006 Toyota Tacoma Double Cab 4WD Longbed, Name: Loki - God of Mischief and Chaos
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
01-06-2016, 03:04 PM | #4 |
Does it still "stick" after the transmission is warmed up ....... ??
humfrz |
01-06-2016, 05:54 PM | #5 | ||
Thanks for the responses.
So, after reading these and having mentioned it to my more car-savvy boss, I am a smidgen more knowledge, and it does seem possible that something is up with the return springs. It's worth noting that it would be BOTH springs, because both right and left sides do it. It feels like the springs are gunked up to me when I play with it. Quote:
I'm thinking I'll try and get the dealer to look at it. Oh, and Quote:
01-06-2016, 06:11 PM | #6 |
It isn't warming up at all in the driveway and even a 15 minute drive may not be enough if really cold. It is possible that it is still just cold related. The fact that it is both ways is sort of telling since the likely hood of both springs getting broken is probably pretty remote (not impossible but it would be weird if they were).
01-06-2016, 06:16 PM | #7 | ||
Tags |
manual, manual transmission, stick |
Similar Threads | ||||
My idea for a center arm rest / console cover / center cup holder | ravenblackfrs | Cosmetic Modification (Interior/Exterior/Lighting) | 67 | 02-13-2016 03:00 PM |
Rattling Sound In Neutral | tekFRS234 | Issues | Warranty | Recalls / TSB | 5 | 07-16-2015 10:23 AM |
Neutral to 1st clunking sound | wallace03 | Issues | Warranty | Recalls / TSB | 3 | 01-10-2013 09:50 PM |
Car rattle at neutral. | IloveBaldEagles | Issues | Warranty | Recalls / TSB | 3 | 12-23-2012 06:55 PM |
Weird rattle when put into neutral | SleekMachine | Issues | Warranty | Recalls / TSB | 1 | 10-18-2012 10:25 AM |
