Old 06-01-2023, 09:52 AM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
'22+ brake pads same as '13-'20, right?
Looks like gen2 brake pads are same as gen1, but double-checking!
My first track days with the '23 won't be this weekend, will drive a friend's '17 86 while '23 waits for new oil pickup tube screen...
Old 06-01-2023, 11:11 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The pad shape and size is the same, but I think they may be a slightly different compound.
Old 06-01-2023, 02:37 PM   #3
nomtimesthree
Drives: GR86
The EBC pads I’ve been running are listed as gen 1 non brembo application. Fit and works as it should. I believe the calipers are the same PNs as gen 1.
nomtimesthree is offline   Reply With Quote
Old 06-01-2023, 04:50 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Thanks guys, it finally occurred to me to check CSG part numbers for my pads (duh) and yeah, they are the same for '22+ and '13-'20 non-Brembo. Cool, I'm in bizniss...
Old 06-03-2023, 04:57 PM   #5
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Gen2 OEM calipers are the same as the Gen1 base calipers (not the Brembos). You'll definitely like the new Gen2!
CounterSpace Garage is offline   Reply With Quote
Old 06-06-2023, 11:25 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ran pads I ordered for my '23 in my bud's '17 86. I would say "no problem" but somehow I knocked the friction material off the pad backing plate on one of the new pads! So I ran 3 new front pads with 1 old DTC60 pad with ~0.080" remaining for most of the weekend, being very easy on the brakes. Ran the old pad down to ~0.060" then swapped in another DTC60 at ~0.080" for last practice session and time trial with full max braking, no prob... Time-trialed in damp conditions, beating one rival in that run group, but main competition got to go out later in the dry, so I got P2, I'll take it!
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails oppiee Canada Classifieds 4 10-07-2019 06:27 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
