| Software Tuning Discuss all software tuning topics. |
Drives: 2013 subaru brz black
base timing idle in gear values
couldnt find info on if i needed to recode in the .xml file or maybe i could edit the table values to set a rpm scale higher than the original 2000rpm in Base timing idle in gear above speed threshold for of course a pop tune
attached is an after/before edits |
#2 |
Drives: WRB BRZ
Yes it's fine to rescale the axis,s works fine as long as values are ascending in axis
| Timing Gear clicking? | Maverick28 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 07-05-2021 11:43 PM |
| High Idle (up to 3k) while stopped in gear | Eazy-V | Software Tuning | 23 | 01-24-2020 10:37 PM |
| base timing A | gt7877 | Software Tuning | 5 | 11-08-2019 09:19 AM |
| Base Timing A vs Base Timing B | NoHaveMSG | Software Tuning | 2 | 01-08-2018 04:31 PM |
| Intake Cam Timing advanced 20 Degrees at IDLE | Kris86 | Engine, Exhaust, Transmission | 67 | 08-25-2017 04:28 PM |
