Drives: turbo frs
Dear all
What happened if retard base timing A ? Someone do this tune 😂 for pops ? Is it right? ![]()
Drives: turbo frs
Lift stock oft tune
Right modify tune |
Drives: brz 2017 hksv2
no,
base timing A is useless almost in ecutek is called Ignition timing vvt Off it is only in use when vvt is not enabled, just few seconds during cold start basically, or if you have vvt problems |
Drives: turbo frs
They don t make sense. It wont even start with a rev limiter like that, and that launch control is set at more than 9000 rpm
Be careful in doing things if you still haven t understood them yet Go read the guides of steve99 |
#6 | |
Drives: turbo frs
Thnx This is not my tune This someone tune I told him this wrong 😂 |
| Cam timing on Dyno | aruxe | Software Tuning | 74 | 06-11-2019 04:32 PM |
| Base Timing A vs Base Timing B | NoHaveMSG | Software Tuning | 2 | 01-08-2018 04:31 PM |
| Engine timing? | MJferg | Engine, Exhaust, Transmission | 3 | 05-13-2017 08:38 AM |
| Don't know how to set timing. | MJferg | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 12-27-2016 10:36 PM |
| Ignition Timing and AFR | JB86'd | Software Tuning | 15 | 03-16-2015 12:23 PM |
