Old 07-21-2014, 01:33 PM   #15
d1ck
Drives: Black 2013 FRS
Originally Posted by blackhawkdown View Post
Why upgrade the suspensions when stock suspension is kicking your ass? You could put the money to something else?
If you bothered to read my post you would see that the problems arose when I changed my setup and tires.
d1ck is offline   Reply With Quote
Old 07-21-2014, 06:53 PM   #16
Sleepless
Drives: 2016 FR-S
I don't know about AX, but for a track car setup, I wouldn't go with a 1.5 difference between front and rear camber. I generally like it closer to a .5 degree difference. Going from -2.5 to -1.5 in the rear must certainly have changed the relative grip balance between front and rear.
Overall, I think you've made too many changes at one time. I'd at least go back to the stock front bar and put the camber back in the rear or put it halfway to -2.
Sleepless is offline   Reply With Quote
Old 07-21-2014, 09:25 PM   #17
Sleepless
Drives: 2016 FR-S
After thinking about this a bit more, I think you really need to put the suspension back to the way you had it and try that with the new tires before changing the suspension. Tires are HUGE in terms of effect on a car's handling.
Undoing so many changes one item at a time is likely to be a lot of wasted and unhappy time. Put it back and change only one thing at a time (the golden rule of suspension tuning...)
Old 07-22-2014, 05:02 AM   #18
CSG Mike
CSG Mike's Avatar
Go back to how you had it before. YOu're making too many changes at once.
Try 0 toe in the rear.
Old 07-22-2014, 09:12 AM   #19
wparsons
wparsons's Avatar
You like the camber that close on a car that gains a lot of camber in the rear and essentially none up front during compression? That'll shift the grip balance to the rear under load as the rear picks up more grip. Ideally you want the grip balance about equal under load, which means unequal static camber.
I guess it feels safer having a car start to push as it builds cornering forces, but it's harder to control and definitely slower IMO.
flickr
Old 07-22-2014, 11:43 AM   #20
Sleepless
Drives: 2016 FR-S
@wparsons I did not know about the variance in F/R camber gain. Good info. Thx
Old 07-22-2014, 01:02 PM   #21
d1ck
I'm going to remove the Strano Bar tonight and maybe reduce the ride height a bit to bring the rear camber back closer to where it was. I'm not sure what my f/r ride height was before though.
Old 07-22-2014, 01:45 PM   #22
d1ck
Is keeping the stock rake of 1/4" higher in rear a good idea?
Old 07-22-2014, 02:13 PM   #23
CSG Mike
CSG Mike's Avatar
That's more of an aero thing that doesn't affect AutoX much, but yes.
Old 07-22-2014, 02:33 PM   #24
wparsons
wparsons's Avatar
The fronts basically gain 0 camber through compression, while the rears gain quite a bit.
My car is sitting at -2* rear with just a 1" drop, nothing adjusted in the camber. Up front after the 1" drop the camber was still basically 0, it took whiteline bolts and slotting the strut to get to -2* up front.
The camber curve isn't linear, but under load the rears will be at -3* or greater (less?) while the fronts stay at -2*.
flickr
Old 07-28-2014, 02:00 PM   #25
d1ck
Thought I'd post an update for those who offered me advice. I removed the Strano FSB and installed the stock one. The car is much better now. I may actually add a bit more rear toe in as I find the car will over steer much easier now, I just want to be careful not to over do it.
Also,
a short review of the Bridgestone RE-11A:
They have plenty of grip, although are a little soft. I think they're a little slower than the Rivals overall, but there isn't a huge gap IMO. They make lots of noise at the limit too which is nice, however they don't seem to handle heat as well as the Rivals either. I had a re-run for one of my runs (100 second course) and shortly into my second run the grip fell off and I was sliding everywhere. Once cooled they were much better. I run my my tire pressure at 34psi hot F/R. EDIT: Also, they seem to be wearing much quicker than the Rivals as well.
Here are the results from this weekend for anyone interested. (See the last post in this thread.)
http://vinland.ca/forum/viewtopic.php?f=2&t=2990
Old 07-28-2014, 02:20 PM   #26
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I love the KW V3 spring rates ... the softer front made a huge difference in my lap times and overall happiness in steering at my track days ...
yes there is a tinge of body roll, but if you have near -3 camber in the front, you don't need to worry about it affecting your grip ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Alignment / Corner Balance mystic Southern California 8 04-17-2014 07:57 PM
corner balance in bay area garfull Northern California 10 06-24-2013 11:16 AM
Cars balance Atticus808 Scion FR-S / Toyota 86 GT86 General Forum 25 11-19-2012 12:49 PM
More on the CG and balance... Carban Scion FR-S / Toyota 86 GT86 General Forum 0 09-28-2012 08:07 PM
Will FI Ruin the Balance of FRS/BRZ? ZmZMWagon Other Vehicles & General Automotive Discussions 8 04-13-2012 12:19 AM
