Southern California SoCal
Old 04-17-2014, 05:02 PM   #1
mystic
mystic's Avatar
Drives: 2020 BRZ PP CWP
Alignment / Corner Balance
Hey folks.
I had a few questions since I'm not so knowledgable about suspension. I am going to have my ST coilovers installed this weekend. The next step would be to have an alignment / Corner Balance. I've read that it's important to have a CB done before an alignment. I'd like to know if this is true? Also, I'm still on stock tires / wheels. I'm waiting for my wheels to become available, which might takes some weeks, even past a month. If I were to get an alignment, or corner balance (or both) and then later change out my wheels and tires, My question is, would I have to have my alignment / CB to be re-done again? Also, the specs on the wheels I'll be getting are 18x8.0 5x100 +40 offset if that helps with anything.
Thanks for your input.
mystic is offline   Reply With Quote
Old 04-17-2014, 05:53 PM   #2
8R6
8R6's Avatar
Drives: FRS
get the corner balancing done after you swap out wheels. waste of money imo to get it on stock wheels/tires unless your race setup is to use stock wheels/tires and you are anal about your car's specifications for the races.
8R6 is offline   Reply With Quote
Old 04-17-2014, 06:39 PM   #3
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Coilovers need to settle anyway.
ApolloSki is offline   Reply With Quote
Old 04-17-2014, 07:01 PM   #4
mystic
mystic's Avatar
Yeah, I just wanted to know what the right approach to take would be, while also trying to save a little money if I had to re-do them again. Thank you
Old 04-17-2014, 07:07 PM   #5
ApolloSki
Stealth
ApolloSki's Avatar
How low you thinking of going? Just be sure and get all your suspension parts in before you get it aligned/cb.
Old 04-17-2014, 07:16 PM   #6
mystic
mystic's Avatar
To be honest I'm not quite sure lol. I'd like to have a 1 or 2 finger gap in between the tire.
Something like this http://tougefactory.com/shop/wp-cont...PoomeFRS_6.jpg
Old 04-17-2014, 07:22 PM   #7
ApolloSki
Stealth
ApolloSki's Avatar
I think I read somewhere that you shouldn't go lower than 1.5 inches. That's like the sweet spot of stance/handling.
Old 04-17-2014, 07:43 PM   #8
8R6
8R6's Avatar
Drives: FRS
at that height, hope u get adjustable lower control arms for the rear
Old 04-17-2014, 07:57 PM   #9
mystic
mystic's Avatar
Definitely in the near future, but I think I can actually have it a tad higher or just go with the 'sweet spot' around 1.5. I'll also be purchasing some spacers because I really don't know how long it'll take for the wheels to arrive and then be shipped from Canada to my door step. Spacers really help the stock wheels stand out. I'll probably also plasti-dip them black next weekend because the two-tone look is incredibly hideous. This should suffice till my wheels arrive
AZP Spring Alignment/Corner Balance Special March 15-April 15 AZP Installs Brakes, Suspension, Chassis 2 03-07-2014 06:08 PM
AZP Spring Alignment/Corner Balance Special March 15-April 15 AZP Installs NY / NJ / CT / PA 1 03-07-2014 11:43 AM
AZP Spring Alignment/Corner Balance Special March 15-April 15 AZP Installs Coating and Customization Services 0 03-07-2014 09:49 AM
Closed Figo NY / NJ / CT / PA 1 10-11-2013 05:53 PM
corner balance in bay area garfull Northern California 10 06-24-2013 11:16 AM
