Old 06-24-2013, 05:13 PM   #197
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Originally Posted by WolfpackS2k View Post
If the car's factory engineers claim that 260 is the maximum safe temperature they why didn't they include an oil cooler from the factory? Seems to me that this car was built specifically for people to have fun with it, DRIVING IT HARD, be it on mountain roads or on a race track. So why develop it with an inherent flaw like this?
First off, it doesn't sound like we really know the source... it sounds like "someone might have heard from an engineer.....", but I'll believe it when I see the words from the engineer, and it was a mechanical engineer working on the engine/drivetrain, not a audio engineer working on the speaker system who heard from his brother that works in the drivetrain dept. that 260 is the maximum safe temp.
Personally, I don't buy it. 260*f sounds extremely low to be a maximum safe temp, maybe they meant under 260 is "ideal".
Second off, from your screenname, I take it you go to/went to NC State. I graduated from there in 2008.
smbstyle is offline   Reply With Quote
Old 06-24-2013, 05:17 PM   #198
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Pull off a line and drain it... or just mix the old with the new.
This. You can mix oils but the pressure you get (well that I got) with 0w20 makes it pointless IMO. The very little MPG increase isn't worth the effort of changing it just for track days, and then swapping back.
I change my fluid on cars I track and lower OCIs so the oil in the cooler doesn't concern me much.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-24-2013, 06:31 PM   #199
brillo
Drives: 2013 Firestorm FR-S
Based on information I've seen over at Bobistheoilguy.com there are quite a few high performance cars (Vipers,Mustangs,Vettes) running their oil temps up in the 300s without issue. Now that doesn't mean we won't have an issue at the same temp, but it does make me wonder what about our engines could be so different as to make you not want to run the oil temp that high.
We know the car cuts power, so thats a sign that the engineers are a little concerned about oil temp (unless that is common with other cars, I don't know).
Do higher oil temps have an effect on direct injection? Is it something more boxster specific?
I'm still going to run a cooler under the better safe than sorry mantra, but I am curious what else we are missing.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 06-25-2013, 01:03 AM   #200
mtsui
Drives: 135i
so is the Oil Galley a good place to add a oil temp sender? I want to keep an eye on the oil temp before I get oil cooler.
thanks
mtsui is offline   Reply With Quote
Old 06-25-2013, 07:48 AM   #201
smbstyle
smbstyle's Avatar
thanks
car has a oil temp gauge stock. Buy yourself a Scangauge or other OBDII reader to read oil temp.
Old 06-25-2013, 10:07 AM   #202
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Next time we are both at Sebring we should use your scangauge in my car to compare the OEM reading vs the one from the Defi. I placed the sensor right after the cooler so it will be reading lower, just curious how much lower...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-25-2013, 11:17 AM   #203
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I am currently using a Scangauge, but I will be replacing it this weekend with a Defi DIN-Gauge that will be reading off of a sandwich plate. I'll post up what I find.
Quick question: did you install the sandwich plate for your gauges above or below the oil cooler sandwich plate?
BatStig is offline   Reply With Quote
Old 06-25-2013, 12:12 PM   #204
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Above so I would know immediately if a cooler line failed.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-25-2013, 01:45 PM   #205
ayau
Drives: Some rust bucket
Where are you mounting your Defi gauages?
Old 06-25-2013, 02:13 PM   #206
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
You are correct sir! Go Wolfpack!
Ya know, I only run 1-2 track events a year. I don't think its worth it to install an oil cooler (in my case). I'll just make sure the oil is freshly changed a week or so before hitting the track.
Old 06-25-2013, 02:27 PM   #207
BatStig
Some say.....
BatStig's Avatar
It will be sitting right above a new single-din headunit. Credit where credit's due: I'm simply copying what I've seen two other members do:
@MSTiFK8R journal (in Russian): http://www.drive2.ru/cars/subaru/brz...ournal/963959/
@arbnpx journal: http://www.ft86club.com/forums/showt...4&postcount=25
Old 06-25-2013, 04:10 PM   #208
ayau
That looks very clean.
Where do you buy that Defi 3 gauge DIN?
Old 06-25-2013, 04:32 PM   #209
wootwoot
Drives: FRS
The ecu pulls timing and the car loses power when the oil temps get to 230F. I think that is solid evidence that 260F is too high.
Old 06-25-2013, 05:48 PM   #210
BatStig
Some say.....
BatStig's Avatar
I ordered it from www.rallysportdirect.com
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 09:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 05:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 06:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 10:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 01:55 AM
