neutron256, Robftss
Old 07-11-2013, 12:25 PM   #127
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by solma View Post
It a paper on what you want to do, atleast in the supercharger.
http://www.movingmagnet.com/medias/d.../m12-12-16.pdf
It's an intersting paper, and I've added the link to the OP.
However I'm not sure that direct a correlation can be made between their experiment, and this specific setup. I'm anything but an expert on FI, but it seems like there are too many variables not defined in the paper to make a real calculation for what our power needs would be.
By your estimation how much power do you think the motor needs to generate the kind of results seen by the Phantom Supercharger?
Old 07-11-2013, 12:27 PM   #128
neutron256
neutron256's Avatar
Originally Posted by ptuning View Post
18v*94a = 1,692 watts/746 watts = 2.27 hp
I should have been more clear. Not the power of that motor, but the power that would be needed by a motor given this setup to acheive a given amount of boost.
Old 07-11-2013, 12:38 PM   #129
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Watts= pressure(pascals) x volume(m^3/s)
Which assumes 100 percent efficiency. So 2hp is not even close.
Toma is offline   Reply With Quote
Old 07-11-2013, 12:49 PM   #130
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Compressor work equation :
W = Cp of air * Inlet Temp in K * ((Pressure Ratio^0.2857) -1) / compressor efficiency
The result will be per Kg or per Lb of air to be supplied
Power Req = Mass flow * W
Mass flow = abs. pressure * displacement * (rpm/120) / ( Gas constant of air * post comp temp in K)
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 07-11-2013, 01:11 PM   #131
neutron256
neutron256's Avatar
So what is the volume you're using to figure this out? I'm not saying you're wrong, I'm just trying to understand so we can have an accurate target for motor size/power.
Aghhhh Too much math, my brain hurts.
I'll be the first to admit that while I'm a huge science geek I suck at math which is why I would never have made it as an engineer.
So can one of you math/FI wiz's figure out how much power we do need to make this work?
And don't forget to show your work. J/K.
Old 07-11-2013, 01:26 PM   #132
Toma
Well since the goal here is to re invent and rip off Rob's Phantom Supercharger set up. Just feel free to steal his data so far ~140 amps. 24 volts. 1.6 psi at redline of a frs. 200 rwhp. I could tell you airflow.... I have logs. But that doesn't seem like the right thing to do. You could calculate airflow as well.
Old 07-11-2013, 01:32 PM   #133
200hp/tonne
Drives: Raven Fr-S
https://docs.google.com/spreadsheet/...Xc&usp=sharing
Excel sheet to Calculate supercharger power at given boost, inlet temp, engine size etc.
you can even see if intercooling makes a difference.
Engine math is what i have to do for a living...
The Following User Says Thank You to 200hp/tonne For This Useful Post:
neutron256 (07-11-2013)
Old 07-11-2013, 01:39 PM   #134
solma
Drives: Raven FRS
Good question, its multiple variable to know, see the link(even if it not in the same category):
http://www.dragzine.com/news/lose-po...-loss-testing/
you can possibly extrapolate, a least for sure it give an idea that in the horsepower range.
I would imagine that if you start with the mapping of the compressor, look at the efficacy in the rpm you want to run it, and after that calculate the work needed to compress the air, you should have a ballpark. After, I would to do what I do in all my design give a least factor of 1.5-2, it seem a lot, but when you will end up in high temp/humidy/... condition, your efficacy could go down the drain fast.
solma is offline   Reply With Quote
Old 07-11-2013, 01:40 PM   #135
neutron256
neutron256's Avatar
If you take issue with "Ripping off" the Phantom supercharger please feel free not to particapate.
I personally am just using that as a baseline for compairson not trying to make an exact copy. It's a good idea and I hope Rob makes a bunch of money off of it. However it's not completly original idea, and as of yet it's also not available for general purchase.
Please Try and keep language in here polite everyone.
Old 07-11-2013, 01:51 PM   #136
Toma
Funny how there were NONE of you bandwagon jumpers were doing anything with this idea before one man designed, engineered, tested, tweeked and proved it could be made to work.
Most laughed scoffed ridiculed lol.
I digress though. Congrats on your 'open source' undertaking.
Old 07-11-2013, 01:54 PM   #137
solma
Drives: Raven FRS
I am not saying your wrong on your statement, but electric supercharger was invent before Rob's supercharger, here just 1 patent dating 1994 http://www.google.com/patents/US5638796 , and I am quite sure it was patent way earlier that.
So when you call it rip off it little bit harsh.
Old 07-11-2013, 02:04 PM   #138
solma
Drives: Raven FRS
I agree with on this one, but if people would not do that, there would be a super slow evolutive curve in design, i like saying the that piston engine should have been left to train using water vapor.
So to me sometime people needed that little push to jump in new technology and continue finding new and better solution using the same backbone.
Old 07-11-2013, 02:05 PM   #139
Toma
Ahhh. So you guys did a patent search and said.... 'eureka, lets build it!' Or did you see Fentons build? Lol
Its all good. We also do diy turbo kits etc. I think it great actually that they managed to spawn excitement and curiosity and make people think.
I think credit for motivation for this idea and proof of concept should be added to the first post and maybe a link to the Phantom site.
Old 07-11-2013, 02:16 PM   #140
neutron256
neutron256's Avatar
If people want to be negative about this please do your best to ignore them. I agree that this is not a new idea, but I do applaud Phantom for trying to develop it. That said it is a concept of somewhat limited use, and if some of us want to bat around ideas on how it works, how to make it better, or even build our own I don't see anything wrong with that.
From what I can tell we have some seriously smart people here and we might even have some ideas that Phantom might want to incorporate into their product. If they do I’m sure most of us would be excited to see our ideas adopted.
I know that if I get this to work at all (I give it 25% I won't) I will probably end up spending more on it the whatever Phantom's kit ends up costing assuming a kit is made generally available. That's not why I'm doing it. I see it as a challenge, a learning experience, and an intellectual pursuit.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
SloS14 (07-11-2013), solma (07-11-2013)
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 05:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
