Old 07-19-2013, 06:31 PM   #2885
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Actually I do own a set of Yakima bike mounts to haul two bikes on top of the BRZ. I haven't used them at all because they're at a friend's and he doesn't have the tools to compress the mounts so I can carry it in my car back home. And I never think to bring the tools to do it myself...
Old 07-19-2013, 06:38 PM   #2886
Blunt
Drives: WRB BRZ MT
Originally Posted by enwave View Post
I can't do it... The symmetry is all gone!
JDM as f**k though.
Blunt is offline   Reply With Quote
Old 07-19-2013, 07:27 PM   #2887
Scoobidude
Drives: DGM BRZ
Fresh tint and rear spats
Scoobidude is offline   Reply With Quote
Old 07-19-2013, 08:22 PM   #2888
0x4552
0x4552's Avatar
Drives: BRZ Limited
Installed my Perrin Catback Exhaust, then got my windows tinted..
Next up, RIMS, Armrest, Kneepads..
On the wish list - Supercharger
0x4552 is offline   Reply With Quote
Old 07-19-2013, 10:26 PM   #2889
v1ru5
Drives: BRZ D4S 6MT L Vortech
Installed Chargespeed knock off side skirts and front lip. Installing these goes much much easier if you pick up 3 packages of 3m 20lb double sided tape and run the tape everywhere.
v1ru5 is offline   Reply With Quote
Old 07-19-2013, 10:29 PM   #2890
go2brz
Drives: 2013 Subaru BRZ Limited in DGM
Installed the new factory "Kicker" Subwoofer w/amp and crossover.
See my report at:
Technical Topics > Electronics | Audio | NAV | Infotainment
go2brz is offline   Reply With Quote
Old 07-19-2013, 11:38 PM   #2891
thill
Debadged the Subaru off.. I like it, am thinking the BRZ badge may need to go as well.. Also washed and waxed the car. I am a huge fan of Optimum Car Wax Spray. Took me about 20 minutes to wax the whole car, and this is from the maker of Opti-Coat.
Tomorrow hope to install the rear diffuser. Also need to get rid of that dorky dealer license bracket on the back...
Old 07-19-2013, 11:40 PM   #2892
Be-Are-Zee
Is that badge just glued on?
Be-Are-Zee is offline   Reply With Quote
Old 07-19-2013, 11:42 PM   #2893
thill
Yes. Came off easy and took about 5 minutes. Was able to get most of the glue off with my fingernail. Also helps it has been over 90 degrees lately.
You may want to have some dental floss handy, it is easy to debadge but you want to make sure you don't pry the letters off and damage the paint if you have a stubborn letter.
Old 07-20-2013, 12:02 AM   #2894
Scoobidude
Drives: DGM BRZ
Where did u get the lip and sides from. And how well do u think the tape will hold up?
Old 07-20-2013, 12:04 AM   #2895
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
Pretty much all badges are these days.
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
Old 07-20-2013, 12:09 AM   #2896
v1ru5
http://www.jonmotoring.com/search.ph...&x=-1137&y=-55
The tape was used to hold the parts into place. They are secured with screws, bolts, and nuts.
You will need American and Metric sockets/wrench, a philips screw driver, flathead, body push pin removal tool (or gettho it up with just a flat head), a right angle drill, jack, jack stands
Old 07-20-2013, 12:28 AM   #2897
Scoobidude
Drives: DGM BRZ
Ok cool I got all that. How hard was it to drill the holes for the side skirts? And did u used anything on the holes to.prevent any future rust?
Old 07-20-2013, 12:41 AM   #2898
v1ru5
Easy to drill with the right angle, and no I didn't use anything for rust
