Old 08-14-2013, 09:56 PM   #1
kosoku
Drives: 2013 fr-s
Square vs staggered
Was wondering who was running what.
Please post tire sizes (front and rear if staggered)
kosoku is offline   Reply With Quote
Old 08-14-2013, 10:05 PM   #2
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Square.
18x9 +35 on 245/35R18
Feels great at the track with the wider rubber.
Slick is offline   Reply With Quote
Old 08-14-2013, 10:46 PM   #3
mrk1
Drives: Sterling BRZ Ltd
square, once I tried square I wont do staggered again.
225/45/17
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 08-14-2013, 11:04 PM   #4
John.Hong
John.Hong's Avatar
Drives: 2013 Ultramarine Frs
18x9.5 +35 all around. Feels good man.
John.Hong is offline   Reply With Quote
Old 08-14-2013, 11:35 PM   #5
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Do extra wide wheels make the car feel less or more responsive with all that extra rubber on the road and such little power behind it? I can't decide which makes more sense.
Old 08-15-2013, 12:53 AM   #6
xphiledan
Drives: 2013 Subaru BRZ
Wider tires will make it feel less responsive. I really don't understand why everyone is obsessed with upsizing the wheels and mounting wide tires. Whole purpose of this car is to make it fun, lightweight, tossible. Mounting wide tires & especially staggered setup is going to lose that fun tail happy nature of the car. Car doesn't make that much power. Don't ruin it w the wrong setup.
xphiledan is offline   Reply With Quote
Old 08-15-2013, 12:59 AM   #7
John.Hong
John.Hong's Avatar
Understandable why it wouldn't make sense to add rotational mass. However, if you can invest Enkei RPF1's, they actually stay approximately the same weight as stock wheels. rpf1 wheel in the size of 17 (or 18 i forgot) x9.5 weighs in at just under 18 lbs. With 255/35 it would bring the total wheel weight to just under 40lbs. Stock wheel with tire weighs in at 40.3 i believe. But unless you plan on drag racing with mustangs , the increase in width of the tire will give you incredible amount of grip around corners and push the car to further limits. :happy0180:
Old 08-15-2013, 01:04 AM   #8
John.Hong
John.Hong's Avatar
The people who do stupid wide and negative offset wheels do it for form. Running wheel size such as 17/18 x9/9.5 is functional reasons. Of course if you buy real wheel they will be lightweight for the most part and will stay in the range of the stock wheel weight WITH tire. Imagine sliding one finger on a table top, then imagine sliding all four fingers across the table. More grip with more fingers. Same concept with tires. Given the setup is sensible and functional.
edit: There is also some "form" inspiration that goes into wider wheels
Old 08-15-2013, 01:18 AM   #9
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
That's not the purpose for me. My purpose is to have as much grip as possible! Enjoy you're feel while I'm going faster!
That said I'm running 255/40/17 square on 17x9 et40.
Old 08-15-2013, 01:33 AM   #10
xphiledan
there isn't anything functional by going up to 18's. Even if the overall weight is the same when running 18's, your rotational inertia is still increased - you want the concentration of weight closer to the center bore. and you gain nothing by losing that little bit of sidewall.
vehicle dynamics are a bit more complicated than using your 1 finger vs 4 finger concept. the chassis engineers specifically dialed in spring rates, damper compression/rebound, sway bar stiffness to get the vehicle to behave in a specific way. the wheel weight/tire width is all part of this along with caster/toe/camber alignment specs.
The OP didn't state his intentions for the car. If he's looking to shave down lap times, then it's a completely different discussion. If he wants to spend money to "upgrade the car", I'd spend it on other things.
The entire essence of this car was to have a fun to drive <30k sports car that lets you hang the rear out. Fucking around with the staggered setup is going to lose this purpose.
Old 08-15-2013, 08:20 AM   #11
BlueDubbinTDI
Thanks for the explanation. I really was thinkin about doing 18x9 rear 18x8 front just to get that extra beefy look in the rear. However if I lost any feel or reponsiveness ide be pissed. I was gunna keep wheel weight (without tire) under 22lbs though for sure.
Old 08-15-2013, 08:46 AM   #12
vtmike
vtmike's Avatar
Drives: Scion FR-S
Couple of the more hard core track guys (csg_mike was one of them) said they found 225 width tires to be quickest around most tracks.
Sent from my SCH-I535 using Tapatalk 4
vtmike is offline   Reply With Quote
Old 08-15-2013, 11:50 AM   #13
BlaineWasHere
Grip>Drift
Drives: FRS
My car is an AutoX car. Grip is king. Top speed and rolling resistance don't matter to me at all. What makes you slower is when you up-size the diameter, not width. Plus to my knowledge CSG has not run 255s ever. Actually according to the build I just checked they've not run ANYTHING wider than 225 so how would they even know if wider was faster?
Mike only lists a bunch of 225 tires:
http://www.ft86club.com/forums/showp...0&postcount=27
I really don't see how less grip makes a momentum car faster around any track, but whatever. How much experience do you personally have with different widths???? I know from MY PERSONAL experience my car was faster after the move up from 245 to 255.
Old 08-15-2013, 12:08 PM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
finger tuning is best tuning
my car's on 1 finger wheel gap and 6 finger exhaust diamater.
no two finger ever beat me.
i'm da boss.
Staggered or Square? tdoggy57 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 09-26-2014 08:55 AM
Square vs staggered setup slowbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-11-2013 11:18 PM
Wheel Directory: WedsSport TC105N 17x8.0 +42 / 17x9.0 +35 hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 03-08-2013 01:10 PM
Staggered vs. Square WWEVOX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 01-12-2013 04:57 PM
Square or Staggered? dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 02-02-2012 10:40 PM
