Old 08-15-2013, 05:00 PM   #1
86TruenoFRS
Drives: Rocket Bunny v1 FRS
Issue with BC BR extreme low coilovers
ok so I installed my BC extreme low coilovers this past weekend and so far im having an issue that that is almost unbareable... I had them built w/ 10k springs front and rear. my issue is my car bounces like crazy in the rear. this isnt my first eperience with coilovers so i know there is an issue. Its like there is no dampening going on in the rear. Ive adjusted dampening several times and nothing has helped... Its like i purchased a set of $200 ebay coilovers. If anyone has any insight i would greatly appreciate it. I installed them myself and it was a pretty straight forward install. Idk if there is something i could check or adjust to help this issue...
86TruenoFRS is offline   Reply With Quote
Old 08-15-2013, 05:21 PM   #2
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I have no experience with suspension but I know that the stock spring rates are far less than 10k. 2.3k front 3.8k rear is the stock setup. Is the fact that your spring rate is so much higher the reason that your car is jumping? Why did you increase your spring rate over 300%? Your new setup seems awful stiff.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 08-15-2013, 05:34 PM   #3
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
not familiar w/ bc products aside from seeing the name everywhere, but do they revalve their shocks to match w/ the higher spring rates? i would be doubtful but again, i'm not familiar with the brand
asdf is offline   Reply With Quote
Old 08-15-2013, 05:36 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Have someone watch the car from the outside. You need to determine if the bouncing is from the suspension traveling up and down, or if it's the car bouncing on the tires.
Personally I think 10K rates is crazy high for street use.
Old 08-15-2013, 05:38 PM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@636 @SLICVIC and a few others can chime in
Old 08-15-2013, 06:03 PM   #6
86TruenoFRS
I spoke w/ @636 and he said his is bouncy as well. but i would like to hear what SLIVIC has to say...
Old 08-15-2013, 06:05 PM   #7
86TruenoFRS
I ran 10k springs on my previous car (s2000) and the ride quality seemed so much better. I was running Megan Racing Street series on the s2k so it wasnt like I was running high end coilovers
Old 08-15-2013, 06:27 PM   #8
CSG Mike
CSG Mike's Avatar
You did buy Ebay coilovers...
Sounds like you need far, far more damping in the rear. Keep adjusting the damping up and hope that it works.
Old 08-15-2013, 06:30 PM   #9
Vten
Drives: Too heavy
I have bc br with swift 8/8k springs Upgrade, there's a time that I wish I opted for a softer spring rate. So I can imagine 10k would be super stiff....
Vten is offline   Reply With Quote
Old 08-15-2013, 08:43 PM   #10
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
uh.. i guess mine is bouncy. It really depends on personal opinion? i have 10k all around , dampening on full stiff all around. Kinda too soft for my fitment thinking about doing 15K maybe idk
SLICVIC is offline   Reply With Quote
Old 08-16-2013, 12:49 AM   #11
Turdinator
Señor Member
Turdinator's Avatar
OP, have you checked whether the car is sitting on some sort of bumpstop in the rear?
1974 TA22 Celica
2013 86 GT
Old 08-16-2013, 01:46 AM   #12
636
636's Avatar
Drives: '23 CWP BRZ
He said its LIKE he bought Ebay coilovers, re-read it.
And, I just don't know if you're used to having such a light car with such stiff springs, It's normal. Rode like this on my civic with 24k.
636 is offline   Reply With Quote
Old 08-16-2013, 02:41 AM   #13
qijian
Drives: FRS
its normal. I had buddyclub rsd 10k/15k on my civic and its stiff... still is. Riding in my FRS is like rolling around in a cloud compared to the vic.
qijian is offline   Reply With Quote
Old 08-16-2013, 04:06 AM   #14
Jarumie42172
Drives: 1992 BMW E36 325i, 2013 Scion Frs
Same I have the same extreme drop with 10k my dampening is set to 25 all around and yap my car is bouncy too, thinking its from the stiff springs is all.
Jarumie42172 is offline   Reply With Quote
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
RS*R SUPER DOWN SPRINGS AND COILOVER AND MORE! ExtremeAutowerks Brakes, Suspension, Chassis 32 12-23-2013 03:39 PM
BC Racing Extreme Drop Coilovers 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 10-16-2013 12:42 PM
BC BR Extreme Low Coilovers install pics 86TruenoFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 08-22-2013 02:44 PM
Stance coilovers lowering issue Dispect Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-07-2013 12:05 AM
