Old 08-08-2013, 10:10 PM   #1
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Wheel Directory: Rota Grid 18x8.5 +44
I was going to wait a few months for wheels, but Wheeldude in Fremont, CA
had too good of a price to pass up. Luckily I am local so I was able to visit the shop to
see the color and finish for myself since this was definitely important to me.
I spoke directly with Tommy Duong who is a member of their sales team.
He was very helpful and patient. I had many questions to ask and concerns to
put to rest. Being well versed in the details of wheel fitment, he addressed all of my inquiries.
I even asked to cut open the boxes to inspect the finish and color.
Tommy and one of the shop hands brought them out right away and
allowed me to pull them out of the boxes to see the wheels in the light.
I was delighted to see that the 8.5" width Rotas had a bit of a concave
face which is something I certainly appreciate. As much as I am a function over form
kind of guy, I'm glad Rota made these with some shape to the face.
If I'm not mistaken, 8.5" TE37s simply have a flat face.
Regardless, I was certain that this was the wheel set that I'd be buying. One swipe of
the credit card later, the boxes were loaded up and I was on my way. It was nice to
spend the rest of the day at work playing with the lugs and hub-centric rings.
Working with Wheeldude was simple and straightforward. I appreciate that they
were able to give me an additional 10% discount for their July Sale that I just barely missed.
The bronze looks great with the (now discontinued) Galaxy Blue Silica.
TL;DR:
Rota Grid Sport Bronze 18/8.5/e44
Weight: 21lbs
Rice Rating: 4/10
Customer Service: 9/10
Vendor Responsiveness: 9/10
Pricing for Value: 10/10
I would buy from Wheeldude again and I would suggest others do so as well.
I'm hoping to get these up and mounted in a few days with Hankook Ventus V12 (235/40/18)
Party hard!
EDIT:
Wheels and tires mounted. The front offset is spot on. It will likely be more aggressive when I drop an inch around xmas time. I need to stop dumping cash into this thing for a bit.
I'll try to get some shots in the sun.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 08-22-2013, 01:56 PM   #2
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Originally Posted by TRD_86 View Post
Very nice wheel. Could you post a rear shot at the tires ground?
Like this? Or do you mean from the side?
φφκα
Old 08-25-2013, 05:25 PM   #3
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by souleffecx View Post
are these stock tires? are they the same size as stock FRS tires?? i want to get new wheels but want to stick with stock tires if possible.
These are by far nothing close to stock
They are a size up stock are 17 these are 18 and are also wider
Old 08-26-2013, 02:00 PM   #4
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
It's great that you're interested in getting new wheels. They definitely make a huge impact on your car. I highly suggest reading and understanding the most you can about the variables that go into deciding which wheel and tires would be most appropriate for your needs.
Start here: http://www.modified.com/tech/0205scc...#ixzz1iskzOt00
See where that takes you. Also, don't forget to research tires since making sure you stay on the road is more important than how good your wheels look.
I'm sure you are going to have more questions even after reading the article above but you can find out so much with a search of the forums or just making sure you're reading over the different wheel threads as they come up.
φφκα
Old 09-27-2013, 09:49 AM   #5
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Smile Wheel Directory: Rota Grid 18x8.5 +44
Update:
After Drop.
On my lunch break. .
She looks kinda slammed, but not really. .
I always sit next to the window to watch my car.
And im pretty sure that I am not the only one who does this.
Now you might call us a silly bunch.
Here is a pic that was taken by my iphone.
I did not take many high quality pics cuz this car was not 100% done. lol.
Now I got 18X8.5 +44 Rota wheels with 225/40 tires. And I am thinking to get 18X9.5 TE37 w/ 245/35.
This body kit does need a drop and 18'' rims to make it looks good.
Newest Update:
Before Drop:
Please see attachment.
Hav already ordered KW V3, Cusco LCA, and Whiteline control bolts.
18X8.5 +44, 225/40R18 Square
Actually those rims looks ALOT better than pic shows(Maybe because they are flat black and are too dark to be showed in pics).
Going to drop my car later.
May need 25mm spacers on the rear and 10mm-15mm on the front after drop.
Wats ur opinions?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-27-2013, 10:05 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
Car will look perfect with no spacers Up front on that drop you don't get much camber from a drop up front so it should stay pretty much flush. The rear could use probably 15 maybe 20mm spacer. Why not got staggered so could be flush all around?
I have 8.5/9.5 +45. Front looks flush, Rear pokes slightly I think it should look perfect front and rear once I get around to some mild drop springs.
Old 09-27-2013, 10:21 AM   #7
Figo
Figo's Avatar
I just want to kick the rear out easier. So I run Square and just 225 tires rear, also thats why Im gonna run -2 camber front.
Old 11-19-2013, 12:25 AM   #8
ET86
Perfectionist
ET86's Avatar
Drives: 2014 Scion FRS
Lookin' good. I agree wheeldude is the best service is top quality.
ET86 is offline   Reply With Quote
Old 12-03-2013, 03:11 PM   #9
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 12-17-2013, 12:34 PM   #10
Figo
Figo's Avatar
Old 12-17-2013, 12:34 PM   #11
Figo
Figo's Avatar
Originally Posted by Thornley View Post
Mind if i ask where you got these things up?
wheeldude.com
Originally Posted by charged86 View Post
very nice look
Thank you.
Old 12-18-2013, 03:29 AM   #12
alex88
alex88's Avatar
Drives: whiteout frs
Look great. Have you by chance weighed them prior to mount ?
alex88 is offline   Reply With Quote
Old 12-18-2013, 06:13 AM   #13
nyfries
Drives: 14 FRS Whiteout
really like your setup and I also would like to know this. Would be cool if its lighter than stock oem ones
P.S would be super awesome if you also take side shot of your ride in daytime
nyfries is offline   Reply With Quote
Old 12-18-2013, 10:17 AM   #14
Figo
Figo's Avatar
I did not weigh them by myself.
But I ask wheeldude and they told me that 20.5lb each, for the 18X8.5. Not bad.
Wheel Directory: Rota RKR 18x8.5 +44 / 18x9.5 +44 Hindi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 99 06-08-2015 09:07 AM
Wheel Directory: Rota RKR 18x8.5 +38 / 18x9.5 +38 jsc1234 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 05-30-2014 11:06 PM
Wheel Directory: Rota RT5 17x9.0 +30 b-25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-03-2013 03:21 PM
Wheel Directory: Rota GR-A 18x7.5 +48 pro_djke Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-03-2013 03:06 PM
Rota Grid 18X8 Cjymiller Want-To-Buy Requests 0 07-31-2013 01:40 AM
