Old 09-02-2013, 09:54 PM   #225
FRSRAVEN
That's the whole point. I know runner lengths being different will run the turbo less efficiently and not make as much power, but it's not always about maximizing potential. Do you know the power loss that one would experience with the uel header instead of the el? I would like to know if its justifiable to go with the uel for the sound or if it's not worth the difference.
IMO, its not that big of a concern. Runner length for turbo applications is key. You want the shortest runners possible, so the exhaust gasses don't loose heat and velocity. I would imagine a UEL would be more suited to a turbo manifold (in this application), as there is no concern to keep the runners the same length, and as a result it would be possible to end up with shorter runners overall. Actually, I guess it depends on where the turbo will be mounted. But I digress.
On a turbo application, header design is less crucial then NA. The power difference is likely to be negligible. I'm sure a tuned EL manifold would probably make more power. But how much more? Certainly not night and day. Just look at the NA options. The UL/UEL headers all make ~around the same power.
But if you want to go EL, then go EL. I'm pretty sure everyone on this board who chooses a UEL is doing it for the rumble. Which IMO, is far more important then a marginal HP gain. (if you like the rumble that is).
FRSRAVEN is offline   Reply With Quote
Old 09-03-2013, 11:23 AM   #226
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Frs300 View Post
when cams are released i will have @King Tut come help me put them in if he is willing and knows how or we will find someone around here to to help us. I already know where im going to get cams from if and when they ever get relesed
I have pulled the head off a WRX and STI motor with the motor still in the car which takes removing the camshafts, so I am confident we could swap out your cams. We will probably have to remove some of the turbo kit though to get it done.
Old 09-03-2013, 05:00 PM   #227
FAER
Drives: Silver BRZ
any of the first round of UEL turbo kits made it on the car (or that batch there in)?
FAER is offline   Reply With Quote
Old 09-03-2013, 05:19 PM   #228
Ross
Drives: 85 corolla gts
Just snatch the engine to do the cams. Would make life much easier. My personall opinion, as pulling this engine should not take long at all.
Ross is offline   Reply With Quote
Old 09-03-2013, 08:41 PM   #229
white devil
Go Gators!
white devil's Avatar
Drives: FRS White-out "blown up"
17 days to go!
"What do you mean I voided my warranty??"
FA20 Turbo + HRI Tune + FA20 Flex fuel + FA20club intake + SRT headerback exhaust + FA20 headers + KW3's + Hotchkis front and rear sway bars + Cusco strut tower bar + Perrin oil cooler + Perrin pulley & brake stop thingy + GFB water & alternator pulleys + Crawford air/oil separator
white devil is offline   Reply With Quote
Old 09-03-2013, 08:56 PM   #230
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Still waiting on mine, will def post vids and pics the first day of install.
Ny Brz is offline   Reply With Quote
Old 09-03-2013, 11:17 PM   #231
Andy@FA20Club
Drives: FA20Club.com
[ame="http://www.youtube.com/watch?v=SAvnvXKzApM"]FA20CLUB AUTOMATIC FRS BRZ TURBO KIT - YouTube[/ame]
Andy@FA20Club is offline   Reply With Quote
Old 09-03-2013, 11:18 PM   #232
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
Mine shipped today and will be installed by end of the week. I think I will be one of the first round uel kits.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 09-03-2013, 11:29 PM   #233
Ny Brz
Hella Flush
Ny Brz's Avatar
Lucky guy, can't wait to see how it sounds.
Old 09-04-2013, 12:52 AM   #234
Frs300
Frs300's Avatar
Drives: Pile of junk
@pixel67 remove me from the list please
Frs300 is offline   Reply With Quote
Old 09-04-2013, 01:05 AM   #235
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Old 09-04-2013, 01:43 AM   #236
Frs300
Frs300's Avatar
@Sportsguy83 i went on a rant..its all good now
Old 09-04-2013, 09:25 AM   #237
FA20Club.com
Drives: 2013 White Out FR-S
life is tough guys Brandon has allot of personal life things going on far more important than this forum i wish him luck and we are trying to help him in our little ways. but this is a great guy who is taking care of him family while getting mini screwed with by other things going on in his life. if i had a place for him he could join my staff as soon as his enlistment finishes up.
FA20Club.com is offline   Reply With Quote
Old 09-04-2013, 10:14 AM   #238
peteralfonso
Drives: Scion FRS
Need some advice. My stock engine just randomly started getting rod knock. Took it to the dealer and they took it apart to find metal shavings all over the oil pan and cylinder 4 is demolished. Since I am stock it is being covered under warranty. Yeah I should probably hold off on installing the turbo but I see this as an opportunity to get some free labor installing a clutch and engine mounts. I need to know if you guys think this clutch will support my end goal of 300whp. Based on its torque capacity and the results listed in the OP, it looks like it will be able to handle my goal. Here is the link to the clutch ACT SB7-HDSS
This is the only clutch that is in stock at a local shop, I need to pick this up today if I want to get it installed while its all apart. Thanks guys!
peteralfonso is offline   Reply With Quote
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 12:48 PM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 01:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 09:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 02:26 PM
