Old 09-16-2013, 02:37 AM   #1
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Scion FR-S with 18x8.5 Gram Lights 57xtremes all around?
I am looking for a square setup with these wheels, but all I can really find with these are 18x9.5 or a staggered set up. I need to know if they look good when you go with 18x8.5 because they look fairly flat with this set up.
EDIT: Hey guys, I found some pictures on the internet after "tirelessly" searching. They look good, but I still would like some pics from people who have the square 8.5 setup.
IAmNotTheDriftKing is offline   Reply With Quote
Old 09-16-2013, 02:42 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Ya they'd be flat. That style has no concave till 9.5"
Old 09-16-2013, 02:48 AM   #3
IAmNotTheDriftKing
That is my fear. I don't want 9.5" though(too wide), or stagger(the whole understeer thing). Need pictures though, before making my decision.
Old 09-16-2013, 04:45 AM   #4
OICU812
Just a dude
OICU812's Avatar
Are you tracking the car and looking for square setup for that purpose? Most all wheel selections I've seen "especially higher end wheels" for twins have little to no concave till 9.5" actually aside from some Rota varieties which some in 8.5" do have some concave.
Old 09-16-2013, 04:47 AM   #5
joshontilt
joshontilt's Avatar
Drives: Toyota 86 GTS
Ray's is doing a concave 8.5 +42 - I've ordered them and due to arrive in November
http://www.rayswheels.co.jp/2009/pro...de=GL_57Xtreme
'Face-2' 18x8.5 +42 - same face as the 18x9.5 +40
joshontilt is offline   Reply With Quote
Old 09-16-2013, 05:11 AM   #6
IAmNotTheDriftKing
Now are you telling me, that it will have the concavity of the 9.5" wheel? I mean it won't be as crazy, but you get what I am saying.
Old 09-16-2013, 07:36 AM   #7
IAmNotTheDriftKing
I don't plan on tracking the car. I do autocross at least once a month(usually twice), so any understeer is no good, but the car is also a DD. I am fine with no concave(although it is dead sexy), as long as the wheels look great without.
Old 09-16-2013, 07:58 AM   #8
joshontilt
joshontilt's Avatar
I'm hoping it will be since its the same face but I guess it'll be in proportion. To be honest, I'm taking on a risk as I like the size and offset of the wheel. If it doesn't come out the way I like it, I'll sell them
Old 09-16-2013, 02:08 PM   #9
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Moving the hub 3mm inward isn't going to make that much of a difference when you compare that to an extra inch of wheel and -5mm on the hub on the 9.5. I wouldn't expect anything other than a "slight" concave on the 42mm 8.5.
denkigrve is offline   Reply With Quote
Old 09-16-2013, 02:22 PM   #10
johnnie
Drives: GT86
Who knows maybe the mould is different and they found a way to have a similar concavity with the avalible space. One can always hope. I'm eagerly waiting for the pics.
johnnie is offline   Reply With Quote
Old 09-16-2013, 02:39 PM   #11
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
you running coilovers? i'd be interested in seeing how these look as well. i have the 8.5 +33 in the front and wish they were more along the style of the rear 9.5 wheels. the one thing that held me back from ordering the face-2 style +42 was the clearance to the spring perch (i'm running swift springs; not coilovers). with the +33 offset, there was quite a bit of clearance. once i installed whiteline camber bushings, it cut that clearance down and also made my front wheels flush at the top. with no camber, there was about 5mm poke from the wheel arch.
i'm wondering if there'd be enough clearance with stock suspension +lowering springs, and 1-1.5° front camber with the +42 wheels.
shiumai is offline   Reply With Quote
Old 09-16-2013, 03:22 PM   #12
denkigrve
Random Internet dad
denkigrve's Avatar
If you're running +33 already, +42 will move you in 9mm towards the perch. Do you have 9mm of clearance? Just measure it out, if you do, you're golden.
Old 09-16-2013, 04:04 PM   #13
shiumai
shiumai's Avatar
what kind of margin is typically called for, as a minimum? if i had 9mm of clearance i'd be rubbing with +42. stuff flexes.
Old 09-16-2013, 04:11 PM   #14
denkigrve
Random Internet dad
denkigrve's Avatar
For stock I'm not sure. I didn't start doing wheel upgrades/measurements until after I swapped to coils. If you do end up with some clearance concerns on an 8.5 running +42 (And you're already fine with +33) Just grab a 5mm spacer and you'll be good to go then you're only +4mm closer to the suspension.
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 jadewbj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 378 06-26-2017 06:57 AM
Wheel Directory: Gram Lights 57Maximum 18x8.5 +45 jimbobrand Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 12-22-2013 09:38 PM
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 funcheung Canada Classifieds 7 09-16-2013 06:01 PM
FS/FT: 18x8.5 +38 Gram Lights 57DR JoeBoxer Wheels and Tires 41 12-29-2012 06:56 PM
Essex Competition Brake System (Endurance) fitment on 18x8.5 57Xtremes Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-10-2012 03:08 PM
