Old 09-17-2013, 03:30 AM   #1
diss7
Drives: AE86, 2x GT86, TE27
Ways to 'soften' stock rev limiter?
So I finally took my car to the track today for some drift practise.
One thing I experienced for the first time (as I was a good boy during break in) is how the ecu pulls the throttle right away for a good second or so (that's what I'm assuming its doing?) when you hit rev limit.
Have never experienced it before, and it is bloody awful, especially for drifting.
I ended up just working around it, but would really rather not have the second o death if I can help it.
Wondering if anyone has a fix? (That's not another flash/tune) local tuner doesn't have ecutek capability yet, and I have another track day on Saturday. :/
Have thought about bee-r limiter and setting this to a few hundred rpm before actual rev limit. But have just been advised ecu may detect misfiring and throw Cel.
Help!!
diss7 is offline   Reply With Quote
Old 09-17-2013, 04:08 AM   #2
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Yeah it sucks as most drive by wire cars use a throttle cut to control the hard rev limit. This mostly effects racers when trying to stretch a gear out.
Next to a Hydra EMS I'm not sure what else you can do since drifting tends to result in long periods on the rev limiter.
Element Tuning is offline   Reply With Quote
Old 09-17-2013, 04:18 AM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Help!!
The stock ECU tune has a big hysteresis value. Depending on the rev limiter that is active, it's either 200 or 350rpm. Which means that the rev limiter kills the engine at the higher RPM value and then doesn't enable it until it drops to the low rpm value. This causes a rather lazy rev limiter behavior.
To fix it, all you need to do is set the ON and OFF RPM very close to each othern (within 50RPM). Or even set them to the same value. This will make the rev limiter softer and more usable. I suspect the calibration team at Subaru decided to set up the stock rev limiter to be feel violent so that it wouldn't encourage drivers to stay up there
FWIW, in our off-the-shelf Openflash maps we reduce hysteresis to 150RPM. Easy to change if you want something softer.
Shiv@Openflash is offline   Reply With Quote
Old 09-17-2013, 04:37 AM   #4
diss7
To fix it, all you need to do is set the ON and OFF RPM very close to each othern (with 50RPM). Or even set them to the same value. This will make the rev limiter softer and more usable. I suspect the calibration team at Subaru decided to set up the stock rev limiter to be feel violent so that it wouldn't encourage drivers to stay up there
Is there anyway I can change this on my setup, with some downloadable software? I already have a flash and a cable, as I've gone FI recently.
Don't really want to have to go into the dealer to make these adjustments; if that is what you're suggesting; which I'm fairly sure you aren't.
Old 09-17-2013, 04:40 AM   #5
Shiv@Openflash
Drives: 2013 FRS
What flash and cable do you have?
Old 09-17-2013, 07:47 AM   #6
diss7
Ecutek. And the Australian flash for the Bullet supercharger and intercooler system and 98 RON fuel.
But, I'm fairly sure I'm locked out of making changes..
Old 09-17-2013, 07:53 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just ask your tuner if he can make the change for you and send you a new file. Or are you just using a base file provided from Bullet? They may be happy to know how you do this and roll it out on all their tunes....
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-17-2013, 09:05 AM   #8
diss7
Yeah it's just the base tune. And local tuner is not able to talk to ecutek :/
Old 09-17-2013, 10:05 AM   #9
mad_sb
Drives: 2013 Asphalt FR-S
They may also need to change the manifold pressure fuel cut resume value if your boosted.
Old 09-17-2013, 11:30 AM   #10
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
We need to talk
448hpsti is offline   Reply With Quote
Old 09-17-2013, 02:02 PM   #11
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by 448hpsti View Post
We need to talk
Ok
So how about that new Miss America?
Old 09-17-2013, 02:10 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Ok
Wouldn't bang. Has pointy elbows.
Old 09-17-2013, 03:14 PM   #13
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Fine, I will take her..........
IceFyre13th is offline   Reply With Quote
Old 09-18-2013, 03:39 AM   #14
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Ok
Well frankly, happy for her and the cultural melting thing, but having lived in NYC, there are way hotter Indian chics out there, fwiw.
I would have to guess there's something behind the shiv(my dads name incidentally ) and the deity derived company name? Or not?
So you're an ecutek shop?
I've looked at your 335 stuff before I sold that car.
Good to see you here.
Ways you COULD get of out a ticket Muskokan Off-Topic Lounge [WARNING: NO POLITICS] 11 09-10-2013 07:42 AM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 11:15 PM
Stock rev limiter. Mine seems to be different. Thorpedo Engine, Exhaust, Transmission 10 06-13-2013 10:21 PM
Stock rev limiter. Mine seems to be different. Thorpedo Scion FR-S / Toyota 86 GT86 General Forum 0 05-30-2013 04:04 PM
anyone running the HPs with a pressure less than 35 to soften the ride? BRZnut Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 11-26-2012 01:36 PM
