| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
You are right. my bad this whole time i thought it was 45psi. thats weird though because this whole time ive kept my tires at 45psi and when the light came on i would fill that tire to 45psi and the light would go away. strange?? |
#16 |
I usually fill to 35 psi when the tires are warm and fill to 32 psi (lowest I'll go for street) when the tires are cold.
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#17 |
Drives: white out project fr-s
tpms system has a minimum pressure threshold warning which is usually around 29psi but does not have an over inflation warning, ive seen tires filled up to 50psi.....yea no typo, some ppl are nuts cause they think they have to fill up the tires to what the sidewall says max psi is....but no tire light.
and also when there is a difference of around 3 - 5psi between any of the tires the light will USUALLY come on also. now with the cold weather lowering tire pressures naturally overnight, you could say this is tire light season =) there have been cases where the whole system had to be "reset" because sometimes the system does crazy things like come on when all the tires are properly inflated but all that really involves is recording all the tpms IDs and rewriting the system with those same IDs |
#18 |
Drives: 2013 Asphalt FR-S
Usually, Toyota TPMS warning indicator will come on if any sensor reads 27 PSI or less, or if the difference between any 2 sensors is 5 PSI or more. Light will not come on for over-inflation. Warning indicator will take a little bit to reset. Not quite sure if the FRS has a reset button. I always check my tire pressure every couple of weeks or when the weather changes, so I haven't had to reset it.
Open up the driver's door and look for the sticker either on the lower B-Pillar area (sorry don't know what it's called specifically) or the door itself, you'll find the recommended cold tire pressure. Last edited by Priapus; 10-26-2013 at 12:24 AM. Reason: As 20valvewynn83 has already mentioned, it's called "door jam" |
#19 |
Drives: WRB LMTD '13
You know the sensor reading solely depends on the program right? I could write a code that the light will be on if it is reading below 30 psi and above 35 psi. So the threshold depends on the written program. To whom think they should follow tire pressures noted on the tires. You are nuts. The tires are not designed only for 2000 lbs car. That is why it is marked for max pressures higher than what your car needs. Some heavy cars might need higher pressures. Go with what the toyobaru recommends. Those pressures are calculated based on the weight. If you are getting more pressures, yes your tires are over pressure.
Sent from my SGH-T999 using Tapatalk
| tire pressure | mrnibbs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-18-2013 11:09 AM |
| Tail light definitely kinda eh.. | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-09-2013 02:44 AM |
| Tire Pressure Warning | pinoyplaya | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 12-21-2012 11:55 PM |
| Tire pressure warning on | sa1126 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 10-27-2012 09:26 PM |
| phantom tire pressure warning | eikond | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 06-04-2012 10:04 AM |
