Old 10-26-2013, 03:33 AM   #1
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
My Alignment with Bilsteins
Just install the b14 kit today. Here is my alignment with virtually no adjusting except front toe to 0. Installed front with SPC camber bolts.
Front Driver: Front Passenger:
Camber: -1 9/16 -1 3/16
Caster: +5 7/16 +5 7/16
Lowered: 1" 1"
Toe: 0
Rear Driver: Rear Passenger:
Camber: -2 1/4 -2 1/8
Toe: In 1/16"
Lowered: 3/4" 1"
I really surprise I didn't get more front camber since I already had -1 from the camber bolts. Besides that I am very happy with the coilovers. Ride is really not any stiffer but feels more planted. I will test at a track this next week.
Thoughts on these settings?
Pacific Auto is offline   Reply With Quote
Old 10-26-2013, 03:39 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Basically -2 all around are you running super wide wheels or low offsets?, 9.5-10.0" widths..or just wanted really aggressive?
Guys who are tracking tend to go that deep or that are stance abit, seems most doing auto x or DD are more in the -1.5 f/r
Either way your springs will settle and you'll need to re do alignment a month or so down road then can change if want different so no biggie really..
Old 10-26-2013, 03:47 AM   #3
Pacific Auto
Master Installer
Drives: Scion FRS
Stock wheels with PSS 17/45/225's.
I go to a local time attack almost once a week.
I will play with them as they break in.
I just hope the more camber in the rear won't cause understeer.
Old 10-26-2013, 04:21 AM   #4
ayau
Drives: Some rust bucket
Front camber looks about right with only camber bolts. They don't really gain much camber under compression unlike the rear suspension. You could always add camber plates to the front if you need additional camber.
Old 11-01-2013, 02:32 AM   #5
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Lowered: 1" 1"
Toe: 0
Toe: In 1/16"
Lowered: 3/4" 1"
Sorry my brain can't compute the fractions
What does a 1/16" toe equate to in degrees?
Fizz is offline   Reply With Quote
Old 11-03-2013, 12:51 AM   #6
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
It is around 0.30 degs.
hanabie is offline   Reply With Quote
Old 11-03-2013, 01:44 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
1/16" = .0625"
Tire diameter = 25"
1/16" toe-in = sin-1(.0625"/25") = 0.14 degrees
DIY Alignment FRSFirestorm DIY (Do-It-Yourself) Guides 41 01-31-2020 08:06 PM
Bilsteins, quick help? Pacific Auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-20-2014 02:11 PM
Just got an alignment.. Scalzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 06-01-2013 11:39 PM
Big O For Alignment? djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-19-2013 06:21 PM
where to get alignment? FML Hawaii 2 08-08-2012 02:36 AM
