Drives: Raven Scion FR-S
im getting the VIS Racing AMS Carbon Fiber Hood and i will be getting it painted Raven black to match my FR-S ... my guy said that hes worried the paint won't stay well and may come off but he has to talk to his painter first bc he doesnt like dealing with Carbon Fiber Parts.... any issues that you have noticed or something i should tell the painter to take into account when attacking this job?
ANYONE YOU CAN RECOMMEND TO ME TO PAINT MY HOOD NEAR ME ? I LIVE IN 11378 Maspeth, NY aka Queens
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
![]() Last edited by ScionFR-S; 10-31-2013 at 11:56 AM. |
#2 |
Drives: 13 DGM BRZ Ltd
Take it to another body shop. They obviously have no idea what they're doing if they don't feel confident in their ability to paint a carbon fiber (likely fiberglass with carbon fiber overlay) piece.
You're in NY. I'm sure you can find at least a handful of shops that have been sponsors to one of many tuner cars in the area. |
#3 |
Drives: TRD Ultramarine '13
I've been wondering about this for a while now. I want to get a carbon hood and have it painted to match my Ultramarine, but I'm not sure how hard it is to remove paint from carbon if I ever choose to go back.
Also, what are the differences between these two hoods? They look extremely similar but the VIS hood is almost $300 more than the Seibon one. http://www.carid.com/2013-scion-fr-s...d-3675138.html http://www.carid.com/2013-scion-fr-s...-13005809.html |
#4 |
Drives: 2013 Scion FRS
I had my rexpeed lip kit painted raven and it was carbon fiber to start with. Its easily possible as many others have stated is basically like painting fiberglass. Although since it is carbon fiber depeding on how thin the paint is you may be able to see the texture of the weave of the carbon in certain angles in certain light. But again doubtful. I thought i saw some on my side skirts at certain angles but i really had to be looking for it.
#5 |
Socal Valley 86 Member
Drives: 2000 Toyota Tacoma SR5 & Scion FRS
Carbon is paintable regardless if it has clear coat or no clear coat, I've painted carbon fiber numerous times and you usually you use a primer or base coat(white/ lighter color). Afterwards you shoot the paint you are planning to use. As like others have suggested, go to another shop who won't warrant their work just because its carbon fiber.
Also usually you can't revert back to carbon unless you can sand off all the paint and clear coat to the point where you finally hit the clear gel coat so I wouldn't recommend it at all, its pretty much a permanent process painting carbon, better off getting a fiberglass instead if your painting. Sent from my HTCEVODesign4G using Tapatalk Last edited by niceguy21; 10-29-2013 at 03:57 PM. |
#6 |
Drives: 2JZ FRS
Block sand with 180/320. Prime with urethane primer. Prep 600/800 then base/clear. Blocking and priming first will help keep the carbon weave pattern from showing under the painted section and keep it looking smooth like the rest of the car
#7 |
bump
#8 |
The fuck are you bumping this thread for? You got solid advice from everyone.
#9 |
Newbie Car Enthusiast
Drives: Asphalt 6MT FR-S
^ lol ass
#10 |
#11 | |
#12 |
Drives: 2013 GBS BRZ Limited
For all of you buying carbon fiber hoods:
1 - The hood on this car is the absolute lightest I have ever experienced: Aluminum.... 2 - If you are buying one I assume it is only for the cool CF look, otherwise See #1 (long story short: If you want to paint it......WHY???) |
#13 |
#14 | |
| VS Style carbon fiber hood | BRZ283 | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 02-14-2015 08:30 PM |
| VIS AMS Carbon Fiber Hood-Sold | FR-Shadow | Exterior Parts (Aero, Lighting, Etc.) | 7 | 09-01-2013 04:16 PM |
| Vented Carbon Fiber Hood for FRS and BRZ? | RWDRIFT | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-19-2013 06:46 PM |
| FR-S CARBON FIBER HOOD QUESTION???? SOMEONE HELP ME... | DealerFR-S | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 07-19-2013 02:29 PM |
| Dry carbon fiber hood | ChrisOkc8 | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 08-26-2012 11:58 AM |
