Old 11-05-2013, 12:44 PM   #645
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by SmsAlSuwaidi View Post
Huh?
I was saying fitment issues seem to be a reoccurring them with FA20Club products.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 11-05-2013, 12:46 PM   #646
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
i can vouch for that. my front pipe or overripe has a tweaked flange so my cutback tips are crooked.
lbroskee is offline   Reply With Quote
Old 11-05-2013, 03:34 PM   #647
mike the snake
Having worked as a welder for a couple years, I know that stuff can tweak a bit from the heat caused by the welds, even if made in a jig.
Looking at the pics though it almost seems if maybe the jig has moved around, because if the jig were correct, and solid, that part would have been really hard to remove from the jig, and would have probably made a big "Twang" when it popped loose.
Old 11-05-2013, 03:40 PM   #648
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
Hey guys, I asked Andy at fa20club this question but I think he's busy with some stuff so I'll ask here since you guys know first hand what this kit is/can be capable of. I have an automatic FRS looking for around 350-400 whp & 300 TQ on 91 pump gas around 10-12 psi. I was debating between the 60 trim, gt2871r or the gt3076r turbos. What do you think I need to achieve that power? Would it even be possible? Unfortunately there aren't any e85 stations where I live. I wouldn't say my build is an open ticket, but I understand the costs that go into a 400 whp build.
Thanks for your help!
chiefshayan is offline   Reply With Quote
Old 11-05-2013, 03:46 PM   #649
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
A built engine or meth or e85 to see 300+ on Cali piss
Old 11-05-2013, 03:54 PM   #650
chiefshayan
Yea 91 cali gas is awful, I know Ptuning is using water meth on their turbo kit, so I'm looking into that to get that extra kick and also run a higher psi safely.
Old 11-05-2013, 04:41 PM   #651
Ross
Drives: 85 corolla gts
3071 and meth would be my recommendation. You may have to look a bit past 12 psi though. Others may disagree with me as I am a fan of the larger turbos.
Ross is offline   Reply With Quote
Old 11-05-2013, 04:59 PM   #652
chiefshayan
I'm a bit new to forced induction since I've only worked on bikes. So I get more power from the 3071/3076 but it spools at a higher rpm? 12 psi is my street limit, if I go meth injection I'd be happy to run 16 on a track.
Old 11-05-2013, 05:15 PM   #653
Ross
I would recommend starting by reading this. http://www.turbobygarrett.com/turbob...rbo_tech_basic
Once that is done read the rest of the articles listed under there turbo tech section. There is actually some good info in there. You can get a bit of basic info from here as well.
http://www.3k-warner.de/products/default.aspx
I could simply give you a basic answer but I feel it is better to point people in a direction that they can learn from, as eventually you will have more questions and this could possibly answer those for you as well. Hope it helps.
Old 11-05-2013, 05:44 PM   #654
SmsAlSuwaidi
Boosted
I love you nohomo. I'm thinking of a 6262 or gtx35
Old 11-05-2013, 05:58 PM   #655
jamesm
i've made the mistake of buying too big of a turbo once, i wouldn't do it again. unless you're building a drag car, a gtx35r has no place on a 2.0l engine. but then, others feel differently. it depends on your tolerance for lag i suppose
i wouldn't go any bigger than a 3071r, and even that is a bit of an odd choice given the relatively small increase in performance potential over a gtx28. i'll qualify that by saying i've never driven an 86 with a large turbo, so maybe it's supernatural, but large turbos on small engines generally suck for anything beyond drag racing and dyno competitions.
Old 11-05-2013, 06:04 PM   #656
SmsAlSuwaidi
Boosted
Well when you start passing 15sh psi then efficacy might play a role ? + my car is just going to be a highway pull car and drag racer ( I don't want to say a street racer and get flamed) I tolerated the gtx35 on brothers built Sti and think the higher CR ( later with cams hopefully ) would no be that bad ?
Educate me away
Old 11-05-2013, 06:09 PM   #657
Ross
I would look at the forced performance 35's over the gtx. I feel the 60+ mm wheels may end up being a bit unresponsive. We shall see though as 300 and subzero are using turbos in that size range if I remember correctly. for highway pulls there is always the option to break boost though.
Old 11-05-2013, 07:06 PM   #658
jamesm
Educate me away
the sti has a 25% larger engine than the fa20. but you may very well be fine with it if you're interested in highway pulls. driving around town it'll be very laggy though.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 12:48 PM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 01:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 09:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 02:26 PM
