Old 12-17-2013, 08:46 AM   #2367
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Originally Posted by wrxgoose View Post
that's the same thing my friend john was thinking. if we go with a smaller belt, the pulley has less space to move, and so will be less likely to throw the belt. We're also thinking about some sort of face-plate for the SC pulley, to keep it on there.
I am not so sure a face plate is a good idea.. if the belt is falling off there is obviously an issue somewhere.. putting a face plate on will just mask that problem and could cause another.. also if the face plate is big enough to work and the belt does try to jump ship.. the belt will try to ride up on the face plate and could try to eat at the side of the belt. It might stay on but you will still have a belt that will prematurely fail..
There are plenty of people with both 70mm and 75mm belts that are not having this problem.. I have run both pulleys on the belt that came with the kit with no problems.. yet... 10,000 miles..
I might not be seeing the whole picture and a face plate may be a good solution but I would exhaust all other solutions first..
just my 2 cents..
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 12-17-2013, 09:32 AM   #2368
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I agree.
The charger pulley can't be running straight, as this is the only pulley that has influence prior to the stock set up!
The idle pulley added does not guide the belt, so that can't cause the problem.
Did you verify you have the correct idle pulley for the 75mm or 70mm pulley?
Ryan86 is offline   Reply With Quote
Old 12-17-2013, 10:34 AM   #2369
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by Ryan86 View Post
I agree.
using the idler pulley that came with the kit, and AFAIK, they didn't sell the kit with a 70mm, so it's gotta be the right size. atleast i hope it is.
wrxgoose is offline   Reply With Quote
Old 12-17-2013, 01:13 PM   #2370
xxscaxx
Drives: 2013 SWP BRZ
Have you checked to see if the supercharger pulley is turning freely without wobble? take the belt off, and spin the pulley, and see if it has a wobble in it. Not sure if you answered that prior.
xxscaxx is offline   Reply With Quote
Old 12-17-2013, 01:26 PM   #2371
Ryan86
Road Warrior
Ryan86's Avatar
The Sprintex kit came with a small idler pulley for 80mm pulley (I think the non intercooler is 80mm) then the intercooler kit had a bigger idler pulley with the 75mm pulley.
Old 12-17-2013, 01:35 PM   #2372
xxscaxx
He got his stateside, which means its Innovate, not Sprintex, so I wouldn't think that would matter.
We were only offered non-intercooled with the 75mm pulley, there was no other option for pulley size.
Old 12-17-2013, 02:00 PM   #2373
Ryan86
Road Warrior
Ryan86's Avatar
Our kit came standard with 80mm charger pulley, with a 60mm idler pulley.
The Intercooler kit came with a 75mm pulley and a 70mm idler pulley.
Not saying the kits are identical, however, check the size of your idler pulley, for the 75mm.
Old 12-17-2013, 02:11 PM   #2374
Calum
That Guy
Drives: 2013 asphalt FRS MT
Sounds like they are trying to maintain a certain amount of belt contact. That's some really good info. I'd love to hear from others with the innovate version of the kit to see if innovate also did this.
Old 12-17-2013, 03:57 PM   #2375
wrxgoose
WUB WUB
okay, so we just swapped the belt (5061010 - dayco) and it took us about 20 minutes to get the belt over the final pulley, and we had to turn the crank to get it to go on.
also, i'm uploading a video right now of the pulleys/old belt, and it really didn't look like there was any wobble, just too much play in the tensioner because of how long the belt is. possible that the belt that comes with it is too long?
[ame="http://www.youtube.com/watch?v=8mohquuVcx4"]Innovate SC pulleys/belt - YouTube[/ame]
Old 12-17-2013, 04:12 PM   #2376
lex tech
Drives: 2005 kia spectra 5, 2004ford tauras
I checked the run out of the pulley and it was fine, the belt ran in the middle if the supplied idler. The issue was when the throttle would close the tensioned would loosen letting slack into the belt, letting it jump a tooth on the super charger. The new belt is about 1/2 inch smaller like mentioned in n earlier post. Now the tensioner doesn't have as much free play and should be fine.
lex tech is offline   Reply With Quote
Old 12-17-2013, 07:48 PM   #2377
TemeCal
Drives: 86
EDIT: I was able to remove the arm, connect things off the car, then reinstall. DISREGARD MY QUESTIONS BELOW. Thanks!
Do any of you guys know if I can install the bypass valve, if I've already installed the supercharger? I removed the strut brace, hoping to give me a little more room. Mounting it is not the issue. The issue is trying to connect the arm from the bypass valve, to the arm from the supercharger (if that makes sense).
There is a nut on the end of arm (from the supercharger). Does anyone know if I can remove that...pull the arm off...connect it to the bypass valve arm while off the car...then mount it?
Just trying to avoid having to pull the blower and manifold.
Thanks!
TemeCal is offline   Reply With Quote
Old 12-19-2013, 01:08 PM   #2378
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Hey guys, if you have a dedicated build thread and I have not posted your link on page one of this topic, then please post your build link and I will add that next to your name on page one. Thanks.
Old 12-19-2013, 04:42 PM   #2379
calispec
calispec's Avatar
http://www.ft86club.com/forums/showthread.php?t=50621
I'll have to get you the number later today..
www.GT86Mounts.com
Old 12-19-2013, 04:54 PM   #2380
xjohnx
Grip>Slip
xjohnx's Avatar
anyone else seeing this thread with 109 pages but can't go past 107?
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
