Old 02-04-2014, 03:35 PM   #3193
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by swift996 View Post
What's the process for changing the oil on the charger? I know where the fill plug is, where's the drain?
I believe you have to syringe the old oil out.
Or just take it off, flip it upside down and dump that shit out
xxscaxx is offline   Reply With Quote
Old 02-04-2014, 03:41 PM   #3194
swift996
swift996's Avatar
I wonder if you can use an extractor like this:
[ame="http://www.amazon.com/Trac-T10064-Fluid-Oil-Extractor/dp/B006ZOVCAM/ref=sr_sp-btf_title_1_19?s=automotive&ie=UTF8&qid=1391542821 &sr=1-19&keywords=oil+extractor"]Amazon.com: Trac T10064 Fluid/Oil Extractor - 7 Liter Capacity: Automotive[/ame]
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-04-2014, 03:45 PM   #3195
xxscaxx
that would probably be a good option, and way faster.
Here is what they say in the install manual:
7.2.2 Replace Gear Oil
• Remove the Gear Oil Dipstick.
• Using a syringe to draw out the old gear oil, drain the supercharger’s gearbox.
• Using Redline 75W90 NS Gear Oil or equivalent fill with exactly 5.31 oz (157 mil.)
• Check oil level with dipstick.
Old 02-04-2014, 03:53 PM   #3196
choi0706
Drives: t
I wonder if the TVS will fit with an adapter plate on their manifold..
choi0706 is offline   Reply With Quote
Old 02-04-2014, 05:23 PM   #3197
xjohnx
Grip>Slip
xjohnx's Avatar
or it could just be the tune...send him some data logs.
Good call. Went ahead and grabbed some logs and sent them to bill to review. Took it easy on this set until I hear from him everything looked safe.
Old 02-04-2014, 09:30 PM   #3198
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Some of the answers to the below:
No need to change the SC oil for 40k miles or so, but check it. It DOES burn up a little with time, and this is somewhat normal for the SC. Use fluid as per the owners manual (redline 90 IIRC). Use a syringe with a tube to suck the old fluid out and put in the new fluid. DO NOT overfill.
You can run the 75 on 93 non-intercooled. But I recommend the 72.5 for that reason. It is a nice in between step and the Raceseng pulleys are readily available and fairly cheap. Our tunes scale with no re-tune for the pulleys.
Clutch: about 225 tq you will start to have issues. You are unlikely to hit this on pump gas intercooled or non. E85 in the cold weather...different story.
So a 70mm with the "works" yes, about 2-3k all said and done with labor. 72.5 pulley will have 50% of the gains for about $100. So well worth it. Takes about 5 minutes to swap pulleys with hand tools.
Originally Posted by stockysnail View Post
Here a question/thoughts for those of you that jumped from the 75mm pulley to the 70mm pulley.
If I make the jump to the 70mm, sounds like I will need:
-Stronger clutch installed (like act streetlight flywheel and street clutch)
-Intercooler
-70mm pully
-I may also do a meth injection
-I don't want to bother with e85 yet
This means I'll be spending around $2.5k without meth (parts and labor [intercooler 1200, clutch/flywheel $566, clutch install $600, retune $200]) and over $3.5k with meth.
With all that, is the supercharger or engine expected to have a shorter lifespan? I don't want to have the car fail on me in a few years because I overstressed the charger or engine. I want this car to last. I do a few track days a year. I have most all of the less expensive supporting mods like oil cooler as you'll see in my build thread.
Would I need to change the supercharger oil more frequently that recommended by innovate?
Depending on my tax return I may get some or all of this stuff. My guess without looking at taxes is probably I'll only be able to get the intercooler.
Xero-Limit is offline   Reply With Quote
Old 02-05-2014, 02:36 AM   #3199
stockysnail
Just the tip
stockysnail's Avatar
I know you aren't the one that tuned my car, but how safe would you say it would be to do what you mentioned and just buy the 72.5mm pulley and slap it on without doing anything else? If the tune wasn't exactly correct what would I notice when driving?
Old 02-05-2014, 04:29 AM   #3200
Kodename47
Kodename47's Avatar
Drives: UK GT86
It'll be down to whether the map is setup to be able to calculate the extra loading caused by the extra airflow. If a map is load restricted, you could have issues once the airflow exceeds the capped values. I'd assume most tunes aren't limited at the ceiling of the 75mm pulley and I think most timing and fuelling would carry across quite easily.
I guess my point is, ask your tuner or find out a way of checking the maps.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-05-2014, 06:56 AM   #3201
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Anyone selling their used kit? Also I have go tru the pages here but I did not find if 3" exhaust will work well with Innovate? There is any parts that you guys recomment me to buy with stage 2 Kit? Thanks guys sorry if this have been talk before there are 147 pages I tried to find some infor before asking.
kombatlion is offline   Reply With Quote
Old 02-05-2014, 07:44 AM   #3202
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I wish I could just poll this thread instead of the whole forum but is the supercharger whine (which seems pretty loud on his system) more cool or annoying?
Old 02-05-2014, 08:45 AM   #3203
xjohnx
Grip>Slip
xjohnx's Avatar
i've gotten so used to it that I barely notice it unless i'm listening for it.
Old 02-05-2014, 09:41 AM   #3204
sato
sato's Avatar
Drives: Dodge Patitas
I think it's darn sexy
Sent from my C6906 using Tapatalk
sato is offline   Reply With Quote
Old 02-05-2014, 10:52 AM   #3205
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
agreed
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-05-2014, 11:51 AM   #3206
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yes a 3" exhaust will work well with the Innovate. Get a boost gauge and a wideband gauge.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
