Old 02-19-2014, 10:34 AM   #15
chandz05
chandz05's Avatar
Drives: CBS BRZ limited MT
Can confirm, this does not work with my S4. Thanks for the suggestion though
chandz05 is offline   Reply With Quote
Old 02-19-2014, 10:52 AM   #16
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I downloaded the firmware update for the Fujitsu Ten headunit from the Subaru Navteq site and this problem seemed to have gone away. I changed the setting regardless as posted by the OP. I have a Galaxy Nexus on Jelly Bean 4.3.3.
krayzie is offline   Reply With Quote
Old 02-19-2014, 11:23 AM   #17
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
This was one of the first things I tried with a Note 3. No luck.
fourvalleys is offline   Reply With Quote
Old 02-19-2014, 12:30 PM   #18
mazz0310
I have a note 3 and I was experiencing a lot of drop/disconnects.
I found to fix my issue I decline to transfer contacts and for some reason I haven't had a problem since (~3 weeks).
If anyone wants to try it out, delete the phone from the car, and delete the car from the phone. Then try to pair it back up and when the phone asks you to accept connetion from the car say yes the first time. Then it will say it wants access to contacts and click cancel.
mazz0310 is offline   Reply With Quote
Old 02-20-2014, 11:22 PM   #19
krayzie
Drive From Home
krayzie's Avatar
Okay I had to set the setting back to Headunit instead of Device, as I lost connectivity today when I restarted the car after stalling in the snow.
I think you guys should download the firmware update for the headunit first to see if it'll fix it.
Old 02-21-2014, 02:10 AM   #20
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
I did a search with google and didn't find the site. Could you please post a link. Thanks
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 02-21-2014, 07:30 AM   #21
krayzie
Drive From Home
krayzie's Avatar
It's this website: https://subaru-na.naviextras.com/shop/portal
Create an account to login, then download the Subaru Toolbox PC-Tool software for your PC. Once the software is installed, plug in the SD Card from the sat nav into the PC, the software will recognizes the card (I think it is encrypted) and there will appear a free update for it (not maps but generalized update).
You can also buy the map update separately (weird I just got the $150 update and it's fine, looks like the $184 updates are US headunit specific?).
Old 02-21-2014, 10:53 AM   #22
deliroast
Drives: 2014 SSM BRZ
This worked for me, had to do the same thing on my Kenwood. Will try the update since contact would be nice
Sent from my SCH-I545 using Tapatalk
M3 > BRZ
deliroast is offline   Reply With Quote
Old 02-22-2014, 09:43 PM   #23
Darkrune
Darkrune's Avatar
Drives: 2017 86
This also worked for me. This plus what was put in the original post. I have had smooth connection since. If the HU functioned as intended it would be even better with the hands free. But, I am super happy I can not have dropped calls or music now. Droid Razrm
Darkrune is offline   Reply With Quote
Old 02-22-2014, 10:24 PM   #24
bedabi
Drives: '13 CBS BRZ
Originally Posted by chandz05 View Post
holy crap need to try this! My galaxy S4 only connects correctly if I turn on bluetooth on the device after turning on the car. Otherwise, it just drops and reconnects continuously until I either power cycle the headunit or the phone.
Thanks. I'll try this.
bedabi is offline   Reply With Quote
Old 02-22-2014, 11:36 PM   #25
t.chk
Drives: Subaru BRZ Limited
I now have plans for tonight. Not the most exciting Saturday night but at least I have an excuse to drive around tonight!
t.chk is offline   Reply With Quote
Old 02-23-2014, 12:22 AM   #26
bedabi
Drives: '13 CBS BRZ
This appears to have worked. I have a Galaxy S4.
Switching to "device initiate" did not. Updating the software did not.
Thanks!
Old 02-24-2014, 03:58 PM   #27
bedabi
Drives: '13 CBS BRZ
Thanks!
No, this didn't work either for me. Thank you for the suggestions.
Old 02-25-2014, 12:38 PM   #28
mazz0310
Thanks!
Glad to hear it worked for a lot of you. I found the issue started after I started to sync Facebook contacts with my phone. I haven't tested it yet but I wonder if it's because there are too many contacts or something.
Anyway I still have contacts in my car even though I don't sync them so I'm not complaining.
Driver door alignment issue--fixed kingping Issues | Warranty | Recalls / TSB 14 03-26-2019 10:46 AM
BRZ Bluetooth Music Connection Issues GH05T Issues | Warranty | Recalls / TSB 29 08-09-2014 06:10 AM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
Ecutek gas gauge issue fixed maj75 Engine, Exhaust, Transmission 1 03-23-2013 12:49 PM
Please help! Bluetooth display issue! bdanisi Electronics | Audio | NAV | Infotainment 4 03-09-2013 11:27 AM
